Question about Microsoft Windows XP Professional
I have a dual monitor setup,get things to open on the screen they
I have a dual monitor setup. I want to know how I can have icons on the right screen open the program to show up on that monitor and not the left one.
Posted by dsczepanski on
  • dsczepanski Sep 01, 2009
    Programs are only going to open on the primary monitor and then you will have to drag it over to the other monitor?
    How would you do it from the command line? Can I create a .bat file to do this? I haven't had to set a computer up this way before. I hate Big department heads.
Anonymous
    Problem Solver:
  • 12 Answers
Try to set your right monitor as primary monitor in display properties.
Posted on Sep 02, 2009
Anonymous
    Sergeant:
  • 336 Answers
What is your video card? How new is the driver for that video card? I will need to know this in order to assist you further.
Ryan Frame
Creative Energy Associates Technical Center
Posted on Sep 01, 2009
  • Anonymous Sep 02, 2009
    Well I need to know what your video card in order to give you the proper instructions on how to assist you.
    Ryan Frame
efs_perpends
    President:
  • Microsoft Master
  • 1,997 Answers
Standard xp instructions here. Set right screen as primary.
Beyond that, controls depend to some extent on what graphics card you have installed.
You could try adding a quick launch icon to the toolbar on the second monitor, and see if that works in xp. If that doesn't work, you may have to open them from a command line and specify which monitor to use.
A simple way to do so is to get a copy of Ultramon. See here. You can download a 30 day trial and check it out.
I hope this information allows you to resolve this issue. If you need further assistance, please post back with a comment to this thread.
If I've managed to answer your question or solve a problem, please take just a moment to rate this post....thanks!
Change direction mouse crosses dual screen setting
If you are referring to a dual monitor setup, there is an option on the resolution screen to choose monitor 1 and 2 and there relative positions.
- Right Click on the Desktop
- Click Screen Resolution
From here you can change your home screen and switch the monitor 1 and 2 position over by drag and dropping.
How to change orientation of monitor
I'm a little unclear of what you are asking.
1) Screen has turned on monitor?
Press the CTRL key, and ALT key down at the same time.
Now tap on the Left Side Arrow key, until the screen is oriented correctly again.
2) Screen on monitor has shifted left, right, top, or bottom?
Use the controls on the monitor to set it correctly again.
3) Using dual monitors?
Right-click on an empty space on your desktop screen.
Left-click on Properties at the bottom of the list.
Left-click on Settings.
The monitor 1 icon is supposed to be your Primary monitor.
The monitor 2 icon is the Secondary monitor.
Ordinarily the Primary monitor is on the LEFT side, and the Secondary monitor is on the RIGHT side.
Just as shown in the Settings window.
If you wish to move a monitor to the other side, go to the monitor icon you wish to move.
Put your mouse cursor on the monitor icon you wish to move.
Left-click, and hold the left mouse button down.
Now drag the monitor icon you wish to move, to the other side.
Not doing it for you?
Then post in a Comment with more exacting information, as what it is that you wish to do.
Regards,
joecoolvette
1helpful
Second display shows only blue blank screen but I can see the pointer
This is an extended display. You can move open windows, icons, or folders over to the second screen. This is called a dual-monitor setup. You can also set the second monitor to duplicate what your primary monitor is showing.
1helpful
Sony vio vgnsz23gp how to connect to another monito. has stanby only
first ..for to work make sure you have the ge force driver installed for the video card ..and not just the automatically installed one from the windows..
than connect the monitor in the vga out for secondary monitor ..and get to the video card control panel ..in the windows control panel ..and enable the second monitor ..and set it as clone ..or in dual mode..which will not place the icons on it ..but will be an extension ..
This can be set and enabled also if you run the nvidia desktop manager from the control panel ..and set it clone ..if you want the same thing displayed in the same time ..or extended to the second one..(dual ) which will have some options ..
For the dual mode the good thing is that you can run separate applications in monitors..by opening them and drag them to the other monitor ..it will act like and extension of yours..
If you go to desktop properties.by click right on desktop ..and choose properties..than settings ..and in there monitor ..you can actually identify them and drag them to switch places to correspond to the actually position ..and after that the mouse will naturally get from one to the other if you point to ..
The normal behavior will be that once a aplication opened and dragged to the second monitor ..when you make it ful screen should extend only in that one ..but some players will make trouble and only will get to full screen in the primary one ..To avoid that use the latest free BS player ..
2helpful
2answers
Hello! I have a processor intel pentium dual cpu e2160 @1.80 Ghz and for display a graphic card NVidia GeForce 7300SE/7200 GS, DAC Type Integrated RAMDAC 512 mb. I use my VGA monitor connected to the...
Hello ghinea18, sorry you can't do that because this will cause hardware conflict, that's why motherboard bios automatically disable integrated graphics if you install video card using pci express x16 slot - Nvidia GeForce 7300SE. do you know if your video card has dual vga or dual dvi connection?
You can try dual display, im not sure if this card supports dual monitors because nvidia online specs does not show full specs on 7300se series. \
Good Luck!
1helpful
3answers
I have a problem with displaying power point presentation
Hello, Chris.
I'm not certain if this was already tried, but here goes:
If you look at you keyboard function (F) keys, you'll see a symbol or the words "CRT/LCD". On my laptop, it is F8, but could be different on yours.
When you connect an external screen to your laptop, if the laptop information doesn't show on the external screen, press your Fn key plus that function key with the symbol or words.
Normally, when you press once, twice and three times, you toggle through various options: your laptop screen only, your external screen only and both screens.
Hope this helps.
2helpful
2answers
I have a projector connected to my lap top. The only picture I get on the projector is the picture of my desktop WITHOUT the icons. I cannot see anything else through the projector. If I open a document...
Hello and thank you for using Fixya's services.
* Refer to "second monitor" as being the projection screen..
When you set up your dual screen, you have three possible configurations:
1. You can have the desktop with all icons, toolbars, etc. on one monitor and the other screen merely is a companion to the main monitor. This means you would have to click and drag the programs you open to the other side of the monitor.
In your case, this is how it is configured and is generally called an "extended desktop.
2. Another configuration is to disable the main monitor and just view the projector as your main monitor. Most likely, we will want to avoid this one (but if this happens you will understand what happened and why the screen is blacked out on main monitor.)
3. This would be the ideal configuration for dual screens as both the projector and the monitor have the exact same thing showing on them. To set your dual monitors up this ay, follow these instructions.
Open the display (by following pictures previously or from control panel) and uncheck mark the box that says "extend my windows desktop into this monitor." Hit apply and okay. This will set the montitor and projector to be exactly the same.
http://www.microsoft.com/windowsxp/using/setup/hwandprograms/monitors.mspx
Please let me know if you have any questions.
3helpful
2answers
Dual monitor setup
Assuming you are using Windows Vista:
All you have to do is connect your laptop to a monitor via a VGA port (located on either the side or at the back of your laptop - it's the port with about 15 holes).
Once connected , you will need to configure how your 2nd monitor will function - as an extended or duplicate monitor. To set this you will need to go to Display Settings > and select your option.
2helpful
2answers
Dual Monitor
To arrange multiple monitors
This procedure applies when two or more monitors are connected to one computer.
  1. Open shortcutcold.gifDisplay in Control Panel.
  2. On the Settings tab, click Identify to display a large number on each of your monitors, showing which monitor corresponds with each icon.
  3. Click the monitor icons and drag them to positions that represent how you want to move items from one monitor to another, and then click OK or Apply to view changes.
note.gif Notes
  • To open Display, click Start, click Control Panel, and then double-click Display.
  • The icon positions determine how you move items from one monitor to another. For example, if you are using two monitors and you want to move items from one monitor to the other by dragging left and right, place the icons side by side. To move items between monitors by dragging up and down, place the icons one above the other. The icon positions do not have to correspond to the physical positions of the monitors. You can place the icons one above the other even though your monitors are side by side.
Nx 5000 dual screen problem
What program are you using for the dual setup? Place a shortcut in startup. usually an external monitor is used in place of the laptop LCD. The Monitor may need to be #1 and the laptop LCD#2 http://www.intel.com/support/graphics/intel852gm/sb/cs-009064.htm?iid=search& This site may help too. Good Luck, Tim
Microsoft Windows XP Professional Logo
Top Microsoft Computers & Internet Experts
Ekse
Mandeep  Singh
Mandeep Singh
k24674
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
