Televison & Video Logo
Question about Alba Televison & Video
How do I play dvds on my alba aelkdvd1988 TV.?
Posted by Linda Younie on
2 Related Answers
Leon Robinson
  • 747 Answers
SOURCE: hi got an alba dvd/tv
you have 2 fuses one for tv and one for dvd im thinking one of thouse fuses is bad.
Posted on Feb 07, 2011
vinceisaac
francoise cleofas
  • 2432 Answers
SOURCE: is it possible to enter the service menu on alba aelkdvd1988 portable tv i'm trying to see if i can get the usb port to read a flash drive with movies on
you can see in the menu the video support read by the player. also in the front panel of the unit their is a tag what format can accept like divx or mpeg etc.
Posted on Sep 07, 2012
I have a Alba LCDW16DVDHDF Tv/dvd player. it's locked to play American dvds. i would like to reset it to play all region dvds. Do anybody know the code to do this? Many thanks.
If you wish to get some details; visit the site linked here. Pull up older posts.
http://electronicshelponline.blogspot.com/ Unlock procedure and to override the password lock and to set the device region free procedure of many popular brand TVs and other devices are given. Search the site by type in this key phrase "How to unlock television"; in the search box at the top left of the display window, to get gathered related posts.
New alba remote not working
If it is universal remote control, you have to set it up again with the set-up code to your device; as the battery replacement will make the remote to a reset by itself. If it is its original remote control, you should check the polarity of the inserted batteries, first; because any one of it has reversed, the remote won't work. If it is found OK; in case of original remote control, you should check its infrared emission first. If you wish to get some details; check the site linked here. Viewing it in "Mosaic" or "Magazine" will make surf easy Pull up older posts. Surf the site with patience.
If you wish to get set-up codes most popular brand TVs with universal remote control, check the site linked here. It has set-up code list & set-up procedure to many popular brand remote controls. See it in "Mosaic" or "Magazine" view. It will make surf easier.
http://electrohelponline.blogspot.com/
Try this link too
http://remotesearch.blogspot.com/
Unable to set up remote control
Programming procedure is too much to type in here by this window, and is not practical. If you wish to get details; check the site linked here. It have set-up code list & set-up procedure to many popular brand remote controls. See it in "Mosaic" view. It will make surf easier.
Alba Tv Codes
093,011,082,074 are the codes to check. If you wish to get more details, check the links given below. Setup code list and setup proceedings to many popular brand remote controls are given. Pull up older posts there. You can also make a search by type in the brand name of your device into the search box; can be located at the top right of the display window. More than Nine Lakh viewers cannot be wrong.http://electronicshelponline.blogspot.com/
Is it possible to enter the service menu on alba aelkdvd1988 portable tv i'm trying to see if i can get the usb port to read a flash drive with movies on
Alba led16911dvd
my dvd combi works fine but only plays the dvds in black and white and the dvd part of the remote doesnt work
Hi got an alba dvd/tv combo and dvd player not playing dvds, showing no disc when dvd is inserted,any soulutions
Will play region one dvdon this dvdv player
According to the spec sheet, the Alba 113 dvd player is a region free device. This means that it should play dvds from several different regions. So, to answer your question, yes, it should play region 1 dvds. Good luck! Der Strom
Unable to play dvds
Older DVD players play either - or + type The disk is not bad it is just not the right type for your player Get your self some DVD-R and DVD+R disks burn a movie on each and see which your DVD supports.
Alba 3450 tvd
some dvd players do not have the REGION CODE set until the1st disk is put in. The region then is set to that disks region.
Top Alba Televison & Video Experts
Ernest
Ernest
ADMIN Eric
ADMIN Eric
Are you an Alba Televison and Video Expert? Answer questions, earn points and help others
