Question about Daewoo DVDS151 DVD Player
What is the TV channel set to to play a dvds151 dvd player?
Posted by dgruelle on
Mick
  • 325 Answers
Almost all Dvd players are connected to a television by either a scart or a HDMI lead.
When you plug the scart into the back of your television (make sure its in properly) then turn the power on. on your dvd player.
This should automatically come on as scart leads send a voltage up the scart telling the tv to change to that source/av.
If it is connected via a HDMI cable then if you look at the back of your telly it will tell you what HDMI input number it is. then all you have to do is press the AV/ SOURCE button on your remote to select that number.
Hope this Helps
Little Dish Fitter
Posted on Sep 01, 2009
Can't find dvd channel on my tv...
hi does your dvd player have scart lead connection if yes select av1 or ext1 thanks
shaun
Mar 06, 2017 | Zenith SY2569X TV
Video channel
if your DVD player supports a HDMI cable a single cable is enough for both audio and video channel.
but both your player and TV must support HDMI.
Aug 12, 2008 | Samsung DVD-V4600 DVD Player/VCR
Dawoo DVD Player
change mode on tv to vidio. the input jacks are dead otherwise
Jun 29, 2008 | Daewoo DVDS151 DVD Player
DVD Player structs after playing 10 minutes of video
the heat from the infra red laser heats up the disk to the point it is hot to touch at which point the read lens cannot read the laser reflection thru the heat noise. cool it down, keep a small fan blowing thru it or play shorter movies.
Jun 20, 2008 | Daewoo DVDS151 DVD Player
No sound
the DVDS151 has its own built in volume control that is easy to hit the buttons near the bottom of the remote and accidently turn the volume down.
even tho your tv volume is set high it won't pass the sound to the tv if it is on mute or turned down.
Mar 18, 2008 | Daewoo DVDS151 DVD Player
Daewoo dvds151 dvd player
Did you find the solution. I have the same problem
Dec 08, 2007 | Daewoo DVDS151 DVD Player
Daewoo Dvds151 DVD Player
According to the manual for the Daewoo DVDS151, page 14 the initial password from the factory is 3351. Try this and let me know if it works.
Please let me know if this works. [email protected]
Nov 15, 2007 | Daewoo DVDS151 DVD Player
Daewoo DVDS151 DVD Player Problem: Password protected
I purchased one of these back in October of 2003 as a backup for my current DVD I just opened the box yesterday, and I need to find out if it will play a PAL DVD and convert it to NTSF for the USA.
According to the manual for the Daewoo DVDS151, page 14 the initial password rom the factory is 3351. Try this and let me know if it works.
I need to
Nov 12, 2007 | Daewoo DVDS151 DVD Player
Black and white picture only...
You have you're video cord in the wrong jacks. If you are using composite make sure it's in the yellow jack and make sure the player is NOT set to progressive scan.
If you are using component, make sure the cables are in the RED, GREEN, and BLUE jacks, but make sure you have the CORRECT red jack (not the right channel audio out...).
Nov 08, 2007 | Daewoo DVDS151 DVD Player
Disc Tray: Daewoo DVDS151 DVD Player
Some have a little hole in the front, you pull the power and use a paper clip. Bend it out so its fairly straight then you poke it into the hole and it unloads the mechanisim. If there is no hole you may have to remove the cover.
Apr 21, 2006 | Daewoo DVDS151 DVD Player
Daewoo DVDS151 DVD Player Logo
123 people viewed this question
Top Daewoo Televison & Video Experts
 Grubhead
Grubhead
Muntejaya Ginting
Muntejaya Ginting
Are you a Daewoo Televison and Video Expert? Answer questions, earn points and help others
