Question about Samsung i85 Digital Camera
My camera wont turn on! I left it charging for a 2 whole days and nothing wont even connect to my hp. Wont even turn on when plugged in on the wall charger and the camera lense is always down wont come up when turned off.
Posted by lovexox on
Dave Lundmark
  • 797 Answers
Repair or sell as parts or repair or as is on a site such as Ebay.
When you cannot start the camera, then there is not much else to do.
It sounds as if there is something wrong in the circuits or the power end of the unit. In any case not good news.
Posted on Sep 01, 2009
My Nextbook model: NXA8QC116B wont turn on even when fully charged.
Unplug the battery and connect again might fix the problem.
Nov 04, 2015 | Cell Phones
Why wont my sanyo vc-e760 hold a charge
Since you've already tried different batteries, you have a couple of other options...
  • Instead of plugging the USB cable into the camera's wall charger, plug it into the USB port of a computer, or even into a USB phone charger.
  • Try another wall charger.
  • Try another USB cable.
Here's the PDF manual for your camera, if you need it: http://us.sanyo.com/dynamic/extranet/servicers/VPCT1495.pdf
(Page 16 contains info about charging the camera)
Aug 04, 2014 | Sanyo Cameras
My camera is a vivitar pink (MID0050609) and it wont turn on, unless i plug it it to my charger and when i do the light on the left is red and it just blinks then flash a blue screen turns on that says...
MSDC is not a problem code. It is normal, the camera is informing you that it's connected to a computer. At this point you should see a new "drive" show up in my computer to transfer pictures.
Have you tried turning the camera on when plugged into a wall charger? If it turns on using the wall charger it might need a charge over night. If the camera will still not turn on after a charge the battery is dead and needs to be replaced.
Mar 12, 2011 | Cameras
Tom tom wont turn on.
turn device over and look for tiny reset button near to power connect strip. then use a blunt safety pin to reset,this should allow you to then turn it on,this works on 500 ,700 ,900 , 510 , 710 , 910 , hope this helps .
Jun 06, 2009 | GPS
Battery wont charge
This camera not charged via PC, you can charge the battery only with wall charger(comes with box).When camera is plugged to PC, you can´t use it as a camera, only as a memory card.You can watch your stuff in PC( PC recognise a camera as a flash memory, no more).
So, this is normal..Charge your camera with wall charger(Full charge Red light not flash!, if light flashed camera is charging) Unplug and use as usually!
Regards
Alex
Vivitar 7300X
Nov 22, 2008 | Vivitar DVR 7300x Digital-8 Camcorder
My zune wont charge at all even when its plugged in
OK this seems weird but if you have like a Nintendo Wii or a PlayStation 2 or 3 take you sync cable and plug your zune into the usb port on the system because sometimes the battery is just so dead that it dosent have enough power for the computer pick it up. mine done this a few days ago and i left it plugged into my Nintendo Wii over night and it started working again
Nov 11, 2008 | Microsoft ZUNE JS8BRPBDLUG MP3 Player
Not working
wher do I get a new battery?
Jul 17, 2008 | Optimus DS-5080 Digital Camera
I have an HP 735 photosmart digital camera and it wont turn on The window lights up and it makes a noise as if it will send the lens out but nothing happens then the window light goes out.A few days ago I...
even tho my batteries were fully charged they wouldnt work in the camera till I got new ones and charged them When I put them in the camera worked!
Jun 24, 2008 | HP Cameras
Wont turn on
Possible failed battery showing fully charged but actually not -or even charger.No reset] Disconnect from the wall socket- re connect and tell us if the battery is now charging. If show full- replace battery. Also tell Sony customer support
Jul 31, 2007 | Sony Cyber-shot DSC-T10 Digital Camera
Open Questions:
Samsung i85 Digital Camera Logo
Top Samsung Cameras Experts
Pieter Vleeshouwers
Pieter Vleeshouwers
halotheracer
halotheracer
Are you a Samsung Camera Expert? Answer questions, earn points and help others
