SOURCE: Wiring diagram needed RV rooftop coleman
Motor1258,
Thanks for the response, to be more specific, the nine pin connector was damaged, but I was able to connect the wires back to main unit panel. I am ready to hook to the hunter thermostat and do not know which wires to connect to. This is my problem and I do not want to short something out. Hope this helps, I want to get it installed again. Thanks again for caring....Jerry
SOURCE: replacing a stereo into a 2005 Saturn Ion
not sure if your still looking for a solution or not but here you go. that orange and white wire is normally the wire that controls the dimmer within the stereo. when you dim the dash light the factory radio lights dim and that wire is suppose to make the new radio do that also. in my past i have found that only about 30 percent of the aftermarket radios actually do that when hooked up. give this a try and let me know. good luck
SOURCE: need wire diagram for harness on clarion db 245
Here's the wiring manual link
you'll need to click on the rating stars to enable the download button, but it's worth the messing around because the file is legitimate.
You'll find the wiring diagram on the right hand side of the second big page.
I hope that works for you.
Testimonial: "thanks a lot for the assist . I can enjoy my music again."
SOURCE: I have an old clarion DRB5176 cd player but i got
there is one on ebay at this link below 7.99 http://cgi.ebay.com/CLARION-16-pin-wire-WIRING-Harness-DRB4375-DRX8175-cl6-/200330020811
SOURCE: For the Clarion DXZ945MP CD Player for car audio,
3amp yellow battery for deck
15 amp yellow is another battery wire
purple right rear + speaker
purple/black right rear -
green left rear +
green/black left rear -
white fr left +
white/black fr left -
grey fr right +
grey/black fr right -
blue auto antenna
blue/white rem amp
brown phone mute
orange/white illumination
red accessory
hope this helps
pls rate cause people arnt rating
