Question about Olympus EVOLT E-500 Digital Camera
What are the most common problems with digital cameras?
What are the most common problems with digital cameras when they are dropped? If lens is cracked how much is it to replace ? Especially on an Olympus e-volt 500
Posted by gd_diego on
pictureman4u
  • 132 Answers
Best place to buy a lens for that camera in on EBAY....cameras, even digitals, are made to take a drop, but, sometimes it can hurt the camera, over times it shouldn't...buy a new lens, and give it a try.
Posted on Mar 26, 2010
I dropped my camera and when i switch it on, it says lens error.
This is a common problem it seems where people drop their cameras and they need to be repaired by a service center for Sanyo.
Nov 16, 2010 | Sanyo Xacti VPC-T700 Digital Camera
I dropped the camera while it was off. When I turn it on it says "lens error".
This is very common problem when the camera is dropped. You can first try to carefully wiggle the lens while the camera is turning on (lens extracting). Sometimes this is enough, but if the damage is more severe, you'll need to get it fixed.
Aug 05, 2010 | Cameras
Lens won't extend. turned power on and error displayed, LENS ERROR. It stopped working after it was dropped.
This is probably THE most common failure among digital cameras, and one of the more common causes is dropping the camera.
There's a halfway chance of fixing it yourself, described here:
http://camerarepair.blogspot.com/2007/12/fixing-lens-error-on-digital-camera.html
Jan 26, 2010 | Casio EX-Z150 EXILM DIGITAL CAMERA
Lense error
Very common problem with the Coolpix, unless under warranty the camera is not economical to repair.
Jul 02, 2009 | Nikon COOLPIX S10 Digital Camera
Lens Error
This is probably THE single most common failure among digital cameras. There's a halfway chance of fixing it yourself, described here: http://camerarepair.blogspot.com/2007/12/fixing-lens-error-on-digital-camera.html
Jun 30, 2009 | Casio Exilim EX-Z77 Digital Camera
I DROPPED THIS CAMERA & SINCE THEN IT DOESN'T POWER ON
Lens errors are fairly common. Usually it's sand or grit interfering with the lens extension mechanism. Or the camera's been dropped with the lens extended. Or the camera has been powered on, but the lens had been blocked preventing its extension. Or the battery ran down with the lens extended ...
Here's some things that you can do to try to correct it. They only seem to work for less than 50% of the lens errors, but if the camera is out of warranty, they're worth a try:
Apr 06, 2009 | Canon PowerShot A85 Digital Camera
Having problems with my canon ixus860. When I turn the camera on, the lens can not protract in or out. It's says lens error on screen. Is this a common problem? I don't believe I have dropped this camera...
Oct 12, 2008 | Cameras
Hp photosmart m425 lens error 22
This is probably THE most common failure among digital cameras. There's a halfway chance of fixing it yourself, described here: http://camerarepair.blogspot.com/2007/12/fixing-lens-error-on-digital-camera.html
Feb 14, 2008 | HP Photosmart M425 Digital Camera
Canon digital camera power shot A510
The E18 error is fairly common. Usually it's sand or grit interfering with the lens extension mechanism. Or the camera's been dropped with the lens extended. Or the camera has been powered on, but the lens had been blocked preventing its extension.
Here's some things that you can do to try to correct it. They only seem to work for about 50% of lens errors, but they're worth a try:
Feb 08, 2008 | Canon PowerShot A510 Digital Camera
Olympus EVOLT E-500 Digital Camera Logo
Top Olympus Cameras Experts
Steven Wander
Steven Wander
Jax Planet
Jax Planet
Are you an Olympus Camera Expert? Answer questions, earn points and help others
