Question about Samsung Audio Players & Recorders
My new Sound Mates do not work. Specifically - the right bud does produce sound. The Left works fine - no problem pairing w/ my Samsung Galaxy. Where do I turn for replacement please?
Posted by jim holland on
5 Related Answers
Anonymous
SOURCE: no sound through ps3 hdmi
hi i had a problem, but had no pic, but did have sound, rang sony, and they said buy a new hd cable, went out and bought one, and it worked fine!!!
Posted on Jul 04, 2008
Anonymous
  • 682 Answers
SOURCE: I have a pair of
open circuit in wire needs to repair in workshop or replace with new one.
Posted on Jul 18, 2008
Anonymous
  • 98 Answers
SOURCE: turn signals wont work
also could be the actual turn signal lever, i have an extra if you want it, [email protected] also have anyother part you would need good luck
erik,
Posted on Sep 11, 2008
pstockton83
  • 272 Answers
SOURCE: my skullcandy earphones are busted
could be caused by the way you wrap them up the cords should never be wound tightly it causes a short and it just so happens that earphones are made of light weight wiring to make them seem to disapear when wearing them so what to do is instead of winding them when your done simply fold them loosely so to speak
Posted on Feb 25, 2010
Anonymous
  • 7 Answers
SOURCE: Left Headphone not working
well maybe because, you to cheap to by good headphones
Posted on Jun 07, 2010
How do I connect a blue tooth device that is already paired in my Samsung intensity 2?
Disconnect it first. means power off. unpair the device restart devices pair it again.
Oct 11, 2017 | Samsung Intensity II SCH-U460 Grey Verizon...
Jvc gumy ear bud headphones purple
When you pull the wire up does it increase the right ear bud volume/ sound? If it does, then it means the right side ear bud has a short within the head phones circuit which is aka the wire that leads to the musical device in which the ear buds branch off from.
If the right side ear bud does not produce an increased volume for sound by picking the wire up or pulling it in towards you or to the left side of your body or musical device then it means that the right speaker is blown.
I know that all head phones come spiced together aka they are stuck together and have to be pulled apart in order to get both head phones seperated from each other so that they can be worn in the ears. If you pulled the wire apart to much or too quickly then that is what ruined the right head phone.
I suggest that regardless if the ear phones begin to work by pulling the wire up,side ways, or into towards your body that you return them back to the store since after awhile the problem will eventually continue to happen causing the right ear bud to completely blow. Once you return the ear phones be cautious with the new set when you seperate the ear buds from each other since they are very touchy and have to be handled with delicateness when seperation is taking place.
Please let me know how it works out for you. I have had many ear buds and I tell ya something; they are very easy to blow one side when seperating. I had to learn after a few pairs that I was ruining the speakers by the way I was seperating my wires. I kept thinking for the first 3 pairs that the store was selling blown ear buds until I began having same problems with another few stores so I said to myself "well the solution is to figure out what I am doing wrong in order to blow one side of my ear buds every time". After few seconds it was not that obvious that all I had to do for assembly was to pull the wires apart in order to get both ear buds to go into my ears.
Jan 22, 2014 | JVC Gumy Ear Bud Headphone - Peppermint...
Left ear bud does not work
yes a coil can burn out in secounds i think you have better have the unit looked at by an technition
Apr 21, 2010 | Sony Bud Style Headphones
Sound in left headphone only sometimes works
you can warranty them on there website. they will probably send you a new pair.
May 07, 2009 | Skull Candy SC-INK'D/Blk Consumer...
HOME THEATER SAMSUNG HT-Q100
Your systemn is designed and built to perform 2.1 sound. If you want 5.1 sound you can do 2 things, connect another pair of speakers to the same speakerterminal as your front speakers, however this produces 5.1 stereo sound and not 5.1 surround sound.
You can buy a new system that has the proper connections.
This set will not have the proper decoding software to produce 5.1 surroundsound. sorry.
Jan 16, 2009 | Samsung HT-Q100 System
My left earbuds on my JVC gummy earphones went out.
I have this problem all the time with my JVC earbuds. This may sound a little gross but it will work. I put the ear phone in my mouth and **** on the end of it pretty hard. What I have found is that sweat or even wax will plug the little hole and prevent the sound from coming out.
Nov 16, 2008 | JVC Gumy Ear Bud Headphone - Peppermint...
27 people viewed this question
Top Samsung Audio Players & Recorders Experts
Muntejaya Ginting
Muntejaya Ginting
ThaMp3Doctor
ThaMp3Doctor
Are you a Samsung Audio Player and Recorder Expert? Answer questions, earn points and help others
