Question about Kodak EasyShare Z760 Digital Camera
Kodak Z760 easy share camera. The camera will not turn on, lens does not come out. Battery is fully charged.
  • btgt89 Sep 01, 2009
    This did not fix my problem..But thank you for trying.
    President:
  • 2,761 Answers
It could be something more serious, but the problem you describe is frequently due to corroded battery contacts inside the camera. Remove the batteries and wipe the camera contacts firmly with a clean cloth (heavy corrosion may require cleaning with a fine wire brush, steel wool, or fine sandpaper). Remove any residue that may have fallen into the battery compartment during cleaning, clean the contacts at both ends of the batteries, and reinsert them in the camera. This cleaning cures the problem about 90% of the time, and I hope it works for you.
Posted on Sep 06, 2009
    Sergeant:
  • 151 Answers
For this problem try the following:
  • Try removing the memory and the battery
  • Try using the camera w/o the memory card
  • If problem still persist call the Tech Number
1800 235 6325 op 12 op 2
Hope this will help
Thanks
Byron
Posted on Sep 01, 2009
6ya staff
SOURCE:
Z740 easy share will not power up,tried new batteries ,nothing at
1. Ensure batteries are fully charged & clean the battery connector point in side the battery compartment.
2. Look carefully between the lens and the camera body for any sand, dirt or any damaged etc.
3. Try turning the camera with the lens facing down and shake to dislodge anything stuck
4. Try removing batteries and memory card, wait 5 minutes and refit the battery only.
5. Now turn on camera( with out card ) and see ,if working then fix the memory card & again turn on the camera. If working then fine .
Otherwise format the memory card and fix back in camera again & try. Make sure before format the memory card take a
back up all photos in your computer then format.
Jun 08, 2010 | Kodak EasyShare Z740 Digital Camera
Kodak z760 lcd screen will not work in the auto
It could have something to do with the batteries/ battery compartment: 1. Make sure you will install a new or fully charged battery/batteries into your camera. Please use lithium batteries Ni-Mh or rechargeable Batteries (2000 M.Amp or higher). 2. Clean the battery contacts. a. Remove the battery/batteries and the memory card from your camera, then wipe the battery contacts with a soft, clean cloth. b. Reinstall the battery/batteries into your camera 3. Turn on your camera without the memory card. (If it works then it?s your memory card that is faulty)
Jan 14, 2010 | Kodak EasyShare Z760 Digital Camera
Have a Kodak Easy Share and when you try to turn on, the blue button turns on and then off and the lens wouldn't open. Has new battery....
Here are the steps:
1. Make sure you will install a new or fully charged battery/batteries into your camera.Pls. use lithium batteries Ni-Mh or rechargeable Batteries (2000 M.Amp or higher).
3. Without the memory card,turn on your camera.
Contact KODAK:
http://www.kodak.com/eknec/PageQuerier.jhtml?pq-path=14563&pq-locale=en_US&_requestid=3490
Dec 01, 2009 | Kodak EasyShare DX6340 Zoom Digital Camera
My camera turns off right after i turn it on. it
Here are the steps:
Unfortunantly KODAK do no longer repair this model. They offer a Trade up option where you for 25-30% cheaper than the listed price can exchange the camera to any newer model provided KODAK has the model in stock.
Contact KODAK:
Nov 24, 2009 | Kodak EasyShare DX6340 Zoom Digital Camera
My Kodak easy share M1063 digital camera wont stay on
This problem is frequently due to corroded battery terminals inside the camera. Remove the batteries and wipe the terminals with a soft cloth (heavy corrosion may require a fine wire brush, steel wool, or sandpaper). Remove any residue left in the camera by the cleaning. Clean the terminals on the batteries in the same manner, and then replace them in the camera. This cures most problems, but if it doesn't work for you, check the Kodak troubleshooting guide at:
http://www.kodak.com/global/en/service/repair/troubleshooting/troubleshooting.jhtml?pq-path=6198
It uses a simple Q&A format to diagnose problems and propose solutions.
Jul 12, 2009 | Kodak EASYSHARE M1063 Digital Camera
Battery will not continue charge after a few seconds
Run the battery all the way down until completely dead and then try recharging. Nickel metal hydride (NiMH) batteries don't develop a "memory" quite like the old nickel cadmium (Ni Cad) batteries, but this seems to work when my cell phone won't hold a charge for more than a day.
Mar 16, 2009 | Kodak EasyShare Z760 Digital Camera
Kodak easy share Z760 6.1 mega-pixels [will not turn on or off]
A few drops of 3 in 1 oil around the rotating swich will usually loosen it up. Just don't over due it.
Dec 04, 2008 | Kodak EasyShare Z760 Digital Camera
Switch will not turn on or off.
a couple drops on 3 and 1 oil will do the trick.
Kodak easy share z612 will not turn on to take a picture
When the battery dies, usually the camera will retract the lens if possible. If the battery is so dead the lens can not retract, I would recommend trying to charge or change the battery. Or try to turn the camera on, and then manually shutting it off if you can.
Nov 16, 2007 | Kodak EasyShare Z612 Digital Camera
Kodak Easyshare Z760 orange light flashing
The flash does not charge separate from the rest of the camera. Try cleaning the flash sensor on the front of the camera or the flash led may be bad.
Secondly, this light functions as a flash sensor which is trying to tell you that you need to use a flash although you may have the flash manually turned off. looks like a bolt of lightning with a circle/slash through it.
May 09, 2007 | Kodak EasyShare Z760 Digital Camera
Kodak EasyShare Z760 Digital Camera Logo
82 people viewed this question
Top Kodak Cameras Experts
Ekse
Vitally Alcher
FIKRET UNALIR
FIKRET UNALIR
Level 1 Expert
Are you a Kodak Camera Expert? Answer questions, earn points and help others
