I just had this same problem, The fuses were not attached to anything. I stumbled upon a black button, that looks sort of like a gromet. Push that, it's a reset button. If it clicks, there you go. It could mean something else is wrong, but that should be a starting place.
Look from the left as you face the dryer. At the rear, look for the bulge where the drum is. Towards the top of it, you will find what looks like a black grommet. Press that - there is a switch inside it.
It will have tripped off because of a heat build-up. Go through the whole dryer & remove ALL of the lint and fluff from wherever you can find it, specially at the bottom of the front, where the door opens. You may also need to clean out the condenser at the bottom right corner of the front. This is a very messy job & you will need lots of towels to catch the water. While you have the front cover off, also remove the cover to the fan on the left & clean the crud out of there too.
I have a Electric Mayatg Dryer Model No :SDE305DAYW that tumble but doesn't dry
Now how was that helpful anyway? 2 different dryers, no answer, just a statement. Any idea what IQ stands for?
