Question about Philips Televison & Video
It is locked on one channel - Philips Televison & Video
Posted by kalle717 on
Anonymous
  • 178 Answers
Go thorugh your inital setup in your menu and have it re-scan the channels.
Posted on Sep 01, 2009
Can i get ur help or not am still waiting on a reply on my question about my philips tv
videos
9k= 1:54 How to lock and
unlock ISF modes
on Philips TVs?
TV Calibration with Darko YouTube - Feb 15, 2016 z 0:45 How Do You
Unlock A Philips
TV?
Wen Wen YouTube - Aug 14, 2017 9k= 2:23 PHILIPS HIDDEN
SECRET SERVICE
MENU/MODE
Carl Cosmos YouTube - Apr 15, 2016 2q== 1:09 How to unlock your
Philips
iTech Unlimited: Unlock... YouTube - Jan 30, 2015 z 1:20 ********* a locked
Philips 25u604 TV
for composite in.
CNLohr YouTube - Dec 23, 2012 9k= 0:28 How to Access
Hotel mode on
Philips TV
Carl Cosmos YouTube - Aug 31, 2016 9k= 1:14 how to unlock a
hotel tv/remove
hotel mode, use
HDMI on hotel tv
draai een keer in het rond... YouTube - Nov 16, 2016 9k= 0:46 HOW TO UNLOCK
PHILIPS MONITOR
CONTROL
Vrushank Maharajwala YouTube - Apr 30, 2013 z 2:45 Unlock Hotel TV
inputs
Channel88 YouTube - Dec 20, 2016 z 1:47 How to make your
hotel television,
like LG TV, allow
you to change ...
Margebird YouTube - Mar 24, 2016
How to lock / unlock a channel in Philips TV? - Philips - Canada
https://www.philips.ca/c-f/.../how-to-lock--unlock-a-channel-in-philips-tv
  1. Cached
How to lock / unlock a channel in Philips TV? Press the 'MENU' button. Press the cursor right. Press cursor down to select CHANNELS. Press cursor right. Press cursor down to select CHANNEL LOCK. If the PIN code is correct, the channel list reappears. Select the channel with the cursor up/down and press the 'OK' button ...
How to lock / unlock a channel in Philips TV? ' Philips
https://www.usa.philips.com/c-f/.../how-to-lock--unlock-a-channel-in-philips-tv
  1. Cached
Locking/Unlocking channels in Philips TV ' Philips
https://www.usa.philips.com/c-f/.../lockingunlocking-channels-in-philips-tv
  1. Cached
Published: 2017-03-02 ' Make sure remote control is in TV mode by pressing 'SELECT' button repeated until 'TV' lights up green.
Jun 21, 2018 | Philips Televison & Video
My 42 FD 9954 Philips flat TV monitor has a channel lock I can't get it unlocked what do I do
How to lock or unlock channelsTo lock or unlock channels:
  1. Press the Menu button on your remote control.
  2. Select Settings.
  3. Highlight System and press OK/Select.
  4. Select Parental/Purchase.
  5. Enter your Parental Controls PIN.
  6. Select Parental Preferences.
To lock or unlock all channels:
Select Lock All or Unlock All and press OK.
To lock or unlock specific channels:
Select Block by Channel > Add or Remove Channels.
From there you can select to Lock All, Unlock All, or
select specific channel(s) that you'd like to lock or unlock.
Jul 21, 2015 | Philips Televison & Video
How do I unlock my scanner?
Channel Lockout You can lock out a channel so it is not scanned. Channel Lockout does not erase the frequency from the channel. You can lock out up to 50 channels, including the Priority channel.
Lockout information is retained in the memory when the scanner is turned off.To Lock out a Channel
Example: Suppose you want to lock out Channel 2 because it stops on transmissions you don't want to hear.Press LOCKOUT when the scanner stops on Channel 2.The scanner locks out Channel 2, Then it immediately advances to the next channel that is not locked out, and resumes scanning.In the Manual mode, press LOCKOUT to lock out the displayed channel. Pressing LOCKOUT does not advance to the next channel in Manual mode.L/O appears in the display to indicate the displayed channel is locked out.Whenever you want to search for channels that are locked out, press MANUAL repeatedly to go through all 50 channels. If a channel is locked out, L/O
appears in the display.Restore a Locked Out Channel To unlock a channel so that it can be monitored during scanning:1. Press MANUAL repeatedly to find the locked out channel.2. Press LOCKOUT again to unlock the displayed channel. L/O no longer appears in the display.Restore All Locked Out Channel To unlock all channels, you must be in the Manual Mode.1. Press MANUAL.
2. Press and hold LOCKOUT to unlock all channels. The L/O indicator goes out on any channel previously locked out.
Sep 18, 2011 | Uniden BC248CLT Base Scanner
All channels are locked out how do i un lock them
To remove the lockout from a channel, manually select the
channel and press L/OUT so LO changes to lo.
reviewing locked-out channels
To review all locked out channels, press MAN. Then repeatedly
alternate between pressing FUNC and then L/OUT to view each
locked-out channel. When you fi nish reviewing locked-out
locking out frequencies
To lock out a frequency during a search, press L/OUT when the
scanner stops on that frequency. The scanner locks out the
frequency, then continues searching.
From the manual:
http://www.scancat.com/OnLineHelp/OEM_Radio_Owners_Manuals/PRO-97_OwnersManual_ome20-527.pdf
Please remember to rate my solution.
Jul 03, 2011 | Radio Shack Pro-97 Handheld Scanner
Pro-96 ,channels 1 thru 9 are locked out ,only 0 is
You are referring to banks, not channels. When bank 0 is active, then you push 0 to de-activate it, you have now removed all your banks from the scan list. To re-activate any bank, just press any number. This is confusing because locking out a channel and removing a bank from the scan list are two very different operations but use the same terminology.
For more information and some tutorials to help with various functions, visit this site: http://support.radioshack.com/support_tutorials/communications/20-526.htm
Feb 11, 2010 | Radio Shack Pro-96 Scanner
I was given a mitsubishi tv but the previous owner had a password lock on it. Is there any way to access the tv by rebooting or something in order to use the tv?
1. Press the Mode button until the LOCK CODE display appears.
2. Enter the 4-digit code using the CHANNEL SELECTOR buttons.
3. Press the CANCEL button to cancel the previously locked channel. The LOCK CODE number display flashes.
4. To exit the CHANNEL LOCK mode, press the MODE button until only the Time and Channel display appear.
Secret text if the code is forgotten!
2. Press Channel Number "9" and "QV" simultaneously. Knowledge of this procedure defeats the channel lock system.
Nov 12, 2009 | Televison & Video
Locked Channel
try settings and the set all data to factory default or restore to factory settings, then you my start new installation. Jkahangwa
Jun 05, 2008 | JVC AV-27230 27" TV
Uniden BC72XLT compact scanner
Hi, this is from the manual,
Locking Out Channels
You can increase the scanning speed by locking out channels that have a continuous transmission, such as a weather channel. To lock out a channel,
manually select the channel, then press Func +L/O.
L/O appears.
Note: You can still manually select locked-out channels.
select the channel, then press Func + L/O.
L/O disappears.
I hope this helps you out,,, Mechanic
If you need a manual, go here.
http://www.uniden.com/pdf/BC72XLTom.pdf
Jan 22, 2008 | Uniden BC72XLT Handheld Scanner
Mitsubishi tv
Without the code, you must get an original remote and press the "QV" and the "9" buttons together to unlock the TV.
Oct 16, 2007 | Televison & Video
Televison & Video Logo
47 people viewed this question
Top Philips Televison & Video Experts
ThaMp3Doctor
ThaMp3Doctor
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
