Question about Samsung SCX 4521F All-In-One Laser Printer
New cartridge saying low toner
Put in new cartridge in my Samsung SCX 4521F but it keeps saying low toner, doesn't want to print.
Posted by admin888 on
Anonymous
    Sniper:
  • 76 Answers
Try these steps:
1. Press MENU # 1 9 3 4 in sequence rapidly. The LCD panel should now display TECH.
2. Press MENU, and then press ENTER. The LCD panel will display Tech Mode.
3. Press the left arrow (<) button once. The operator panel will display NEW CARTRIDGE.
4. Press ENTER. The operator panel will display [YES].
5. Press ENTER. The toner warning message should be gone.
6. To exit TECH MODE, press MENU # 1 9 3 4 in rapid succession, as if you were dialing a phone number. The operator panel should no longer display TECH.
Let me know if it doesn't work as there is another possible solution.
Posted on Sep 01, 2009
Anonymous
  • 83 Answers
The problem is likely to be from your toner. Most off market toners and inks are made by third party vendors and their standard might not be up to the printer manufacturers'. Also check the expiry date on the toner's pack. It might have expired.
Also try printing with the toner on another printer and see if it works. If it does not, buy another toner- a very good one this time around.
  • Jitendra dhami
    Jitendra dhami Oct 27, 2013
    my printer Model is Samsung SCX-4521F , is comming Bigsound and com error "Tuner Low " what is Soulation ? pls help me
The printer samsung scx-452f cannot print out fax in,it shown on screen as memory receive
you have received faxes, but they can't be print until you replace toner because probably you have TONER EMPTY message also on the display.
You can buy only fuse for toner cartridge (25mm, 250V/ 0,063A or 0,1A and maximum 0,125A)
When you pull out toner cartridge you will see the glass fuse on the front left side of the cartridge.
The new fuse will reset toner empty condition
pifonski
Feb 28, 2011 | Samsung SCX 4521F All-In-One Laser Printer
CRU FUSE ERROR SAMSUNG
hello,
their is small fuse in your toner cartridge.you have to replace it . it is also damage.
Jan 13, 2011 | Samsung SCX 4521F All-In-One Laser Printer
NAME OF TONER AND HOW TO REFILL
Samsung Black Toner Cartridge for SCX-4521F Part #: SCX-4521D3 samsung_scx4521d3.jpg
Its price: $76.99 You just pull outward the old print unit and replace it with the new !
Good Luck!
Dec 07, 2010 | Samsung SCX 4521F All-In-One Laser Printer
Put in second toner and machine is still saying toner empty
If you are using refilled cartridges those errors are common, Samsung has an eeprom on the cartridge keeping track of usage and you need a new chip from the refillers. If you are using OEM cartridges you need to clean the contacts inside the machine that the cartridge connects to and wipe the contacts on the cartridge before installing, Otherwise a shop repair for the CRUM circuits.
Sep 11, 2009 | Samsung SCX 4521F All-In-One Laser Printer
Samung scx-4521f toner refil but still printing light on paper
Donot refill the toner. Use the genuine cartridge. If you use the refilled it may cause printer damage.
Jul 09, 2009 | Samsung SCX 4521F All-In-One Laser Printer
Problem with printing
CRU Fuse Error The toner cartridge is
not installed correctly.
Install the toner cartridge
correctly. See “Replacing the
Toner Cartridge” on page 8.4.
www.zinetic.o.uk
Sep 04, 2008 | Samsung SCX 4521F All-In-One Laser Printer
Samsung scx-4521f fax memory received but never print out.
In 3 second make combination on you Samsung 4521F 'Menu'-#-1-9-3-4. You will enter in tech menu. Select 'toner'-new toner-yes. You will receive faxes. It really works.
Oct 24, 2007 | Samsung SCX 4521F All-In-One Laser Printer
My printer is comming big sound .
No big deal. You need a new toner cartridge, part number SCX-4521D3. Thi toner yields up to 3,000 pages, except the one that comes with the machine that will last no more than 800 pages.
Sep 17, 2007 | Samsung SCX 4521F All-In-One Laser Printer
Samsung SCX 4521F All-In-One Laser Printer Logo
305 people viewed this question
Top Samsung Office Equipment & Supplies Experts
Muntejaya Ginting
Muntejaya Ginting
Are you a Samsung Office Equipment and Supply Expert? Answer questions, earn points and help others
