Question about Freezers
I have a Beverage Air 2 door reach in freezer serial # 8005466. Can you help me pin down it's age?
Posted by Beth Vos on
Andrew Taylor
    Top Expert:
  • Freezers Master
  • 31,545 Answers
We are FIXYA dot com, you would have to contact the maker. The date should be on the specs label inside the unit or on the back near the power cable.
https://www.google.com/search?q=Beverage+Air+2+door+reach+in+freezer
Posted on Jul 21, 2019
4 Related Answers
Anonymous
  • 149 Answers
SOURCE: Beverage-Air Freezer Model KF-24
verify that condensers ain't clogged with dirt, condenser fan is running all the time and set the thermostat to the coldest setting. if temperature keeps rising suspect dirty condenser of deficient condenser fan. if compressor runs and no cooling after condenser cleaning. suspect a refrigerant charge problem. hope to be of assisit
Posted on Apr 26, 2008
Anonymous
  • 750 Answers
SOURCE: commercial reach in freezer
Hi scondon15,
I just read this article about the subject you ask about!
How old is the freezer?
Repair or replace?
When to pull the plug on your old refrigerator and or freezer
It nearly always makes sense to undertake simple do-it-yourself repairs,
such as replacing a gasket on a refrigerator or a freezer.
Typically, you'll also find a troubleshooting section for more-serious problems
in the owner's manual.
Should you pay for a repair or buy a new model?
The answer depends mostly on the age of your refrigerator,
how much you bought it for,and the cost of the repair.
Follow these guidelines:
When a repair makes sense.
If your refrigerator is under warranty or less than four years old (three years for top-freezers),
paying for a repair makes sense.
Note that refrigerators under warranty might require service from a factory-authorized technician;
readers have found them on a par with independent repairers.
When a repair might be a wise choice.
If your refrigerator is out of warranty and is four to seven years old,
it might make sense to pay for a repair. Customers generally pay $100 to $200 for a repair.
But you might want to buy a new model even at this stage,
given that today's models are quieter and have added features.
Higher energy efficiency is another plus: Energy Star-qualified models made after April 28, 2008,
are 43 percent more efficient than conventional models built before 2001 and 56 percent
more efficient than those built before 1993.
When it pays to replace.
The repair costs more than half the price of a comparable new refrigerator.
Data also shows that it doesn't pay to fix a less-expensive top-freezer refrigerator
six or more years old or a bottom-freezer or side-by-side eight or more years old.
Thanks to better recycling programs, less than 10 percent
of a refrigerator you replace is likely to end up in a landfill.
Thanks for giving me the opportunity to help!
Please do not for get to give a rating before you sign off!
Thank You, HUUUM
Posted on Sep 22, 2008
Anonymous
  • 185 Answers
SOURCE: WHAT ARE THE COMMON PROBLEMS WITH BLUE AIR 2-DOOR
Toll Free # 001-866-677-8500 FAX 001-310-808-0242 / 1-310-808-0262 E-mail 00Admin : [email protected] / Sales Team : [email protected]
sorry couldn't delete it. why not call blueair and ask them product info on that model and see what they say if there is any particular problems with that model. ask about warranty and recalls
1-310-808-0102
1-886-677-8500
[email protected]
hope this helps
Posted on Apr 02, 2010
Dennis Boxerman
  • 1300 Answers
SOURCE: I have a commercial reach in Turbo Air 2 door
I've never heard of "Points going out" and I've been doing commercial refrigeration since '85. I can only guess that he is referring to either the potential relay or the current relay. In either case, the part costs about 30 bucks and takes about 30 minutes to install. I'd look for a second opinion for sure.
Posted on Sep 02, 2010
What does DA mean on the digital display on a Beverage air Freezer HS series
What does ( da ) mean on a beverage two fan single door reach in frezzer disply
Sep 08, 2014 | Beverage-Air Freezers
How do i replace a wheel on a beverage air freezer
For Service Call (877) 866-1223 Beverage-Air Corporation Offices: 3779 Champion Blvd., Winston-Salem, PA 15825
_________ Manufacturing/Shipping/Receiving: Brookville, PA 15825
Contact with Model Number and Serial number for assistance
Beverage Air
Sea Breeze
Feb 26, 2013 | Freezers
Beverage-air freezer model EF-48-1AS one of two fan motor stop working but it's hot to the touch and the freezer is alway on, what's wrong and where can purchase one to replace?
2 ways for a motor to "Lock Up." Mechanically and electrically. If it spins free with the power off, it is electrically locked. Restaurant Parts and More in Ohio can help. Need Model and serial. Ask for Rick. 1-888-814-1110.
Aug 28, 2011 | Beverage-Air 46.6 cu. ft. / 1320 liter...
Beverage Air. Model: CFG24-1. The evaporator fan motor does not turn while unit is operating. The entire condensing unit is working, except the evaporator fan motor. When I removed the evaporator fan motor...
http://beverage-air.com/pdf/manualsbycategory/K%20Series%20-%20Bottom%20Mount%20Reach-Ins/CFG_CRG_KF_Series809-046A.pdf
The fan has a limit control wired in series that shuts the fan down until the coil temperature reaches 25*F. this prevents the fan from blowing warm around after defrost.
There is also a switch which is placed for the door to close. Either one may be defective.
Worst case is the freezer is not pulling down temperature wise.
Jan 19, 2011 | Beverage-Air CFG24 Freezer
Where can I order extra shelves and support clips for GST 40GF
Call Rick at Restaurant Parts and More in Ohio. Give him the model and serial numbers and he can match what you need. FYI, most Turbo Air freezers are also Masterbilt. Turbo Air does the private lable thing for Master bilt.
Hope this helps.
Mar 11, 2010 | Turbo Air Freezer Green World by Bottom...
Beeping freezer??
Also check that there is plenty of room around the air vent to stop the freezer overheating.
Thanks J
Feb 08, 2008 | Beverage-Air Freezer K Series Reach in...
Freezers Logo
154 people viewed this question
Top Freezers Experts
Dennis Boxerman
John Tripp
John Tripp
Marvin
Marvin
Are you a Freezer Expert? Answer questions, earn points and help others
