Question about Hitachi Televison & Video
Got several Hitachi DVDCAM mini-DVD discs that were not finalized. No longer have the DVDCAM. Can they be finalized on a Funai ZV4227FX4 (VHS-C to DVD recorder) which I have? What else might work?
Posted by Stephen M Quennoz on
5 Related Answers
Gazza10
  • 6 Answers
SOURCE: remote no longer controlls recorder
Remote can be used to control more than 1 recorder, on the remote press enter and 1 simultaneously, this should switch the remote to control dvd 1.
Posted on Oct 27, 2007
Anonymous
SOURCE: recording from vhs to dvd
Direct copy VCR to DVD:
- Insert VHS tape you want to copy
- Insert a recordable DVD disc
- Press DVD copy button on front panel or remote control (to DVD).
- To stop recording press the stop button.
IMPORTANT: If attempting to copy copyrighted material the Samsung DVD-VR320 will detect the encoding and will not allow the copy to be made.
Posted on Apr 05, 2008
Anonymous
SOURCE: "FInalize" menu option greyed out on my Canon HR10
works!  Cannon FAQ stinks and never mentioned it.  Thanks for posting the solution!
Posted on Oct 09, 2008
Anonymous
  • 75 Answers
SOURCE: Funai DRV-B2737 Error message
I'd had this problem with my 2737 for quite some time but haven't had the time to fix this until now.
Just for the record it has one laser unit inside which fires off two frequencies one for read the other for write. Anyway, I've been repairing Playstation 1 and 2 and Xbox for years and the most common problem seem to be disc read errors caused by seemingly failing lasers or scratched/damaged discs.
The manufacturer sets these lasers at safe usable limits but after some use they start malfunctioning.
I wanted to copy a VHS recorded disc to my PC tonight only to find I hadn't finalised it in my Funai.
Realising I couldn't because of the silly E4 54037380 error I finally took the plunge and dismantled the unit.
NOTE: the following is not for the faint hearted and please use an antistatic wrist strap to earth yourself.
The Disc tray mechanism has to be removed and a small circuit board directly to the right has too be released. There are a plethora of ribbon cables but only one needs disconnection. Carefully turn the disc drive mechanism on it's back and un clip the thick ribbon cable that attaches to the laser. Tuck the cable out of the way being careful not to damage it. Move the lens unit to the top of the tray mechanism and note there are two potetiometers Using a pot tool or fine flat bladed screwdriver adjust the lower pot by an eigth of a turn (this increases the frequency of the recording laser enough to eliminate the E4 54037380 error completely or it did in my case).Problem solved fully working recorder.
Dismantling procedure
Disconnect Funai from mains and remove the top casing (5 screws)
There are 4 screws holding disc drive mechanism in front right most tricky (use grabber tool to retrieve screw)
Top right has an earth cable connected to it
The other end of the earth cable is held in by another screw on the circuit board next to the drive mechanism this also needs removing
The screw directly below this with the metal earth case strip remove.
The board is held on by two small plastic lugs which need compressing so the board can pop up.
Remove drive mechanism carefully along with the circuit board and flip the whole lot over. Be mindful of the ribbon cables as they are fragile
Posted on Jun 23, 2009
Anonymous
SOURCE: Funai VCR/DVD recorder DVR 2737. My -R discs
I was advised to try another make of blank discs. I bought Sony discs & they worked ok. I had been using supermarket own brand.
Posted on Oct 18, 2009
EWR20V4 How do I finalize a disc after it's recorded ?
For the EWR20V4, press Setup on the remote then select the Disc menu (with the left/right arrows) and press enter. Select Finalize (using the up/down arrows) and press enter. A confirmation window will pop up, select Yes (left/right arrows) and press enter. Note: finalization takes some space on the DVD so leave room after recording to the disc. The step will take a few minutes. Finalization is permanent except for -RW discs (rewritable) and can only be undone with same unit that finalized the dvd-rw.
The DVD recorder was made by Funai Corp for Emerson. The manual for the unit can be found here: http://www.funai-corp.com/support/manuals.aspx . I found searching for products starting EWR gave several similar models. The direct link is http://www.funai-corp.com/6pdf/om/EWR20V4.pdf .
I hope this helps.
Jan 06, 2011 | Emerson EWR20V4 DVD Recorder/VCR
How can i get mini dvd to play on dvd player
Make sure that MiniDVD has been finalized in camcorder then it can be playback in any other DVD Player.
Finalize option would be available in camcorder dvd setup menu, select it to finalize recorded mini dvd disc, please note UnFinalized mini dvd disc will only playback in camcorder because of its raw data and Finalization will validate this raw data so other dvd players will recognize this mini dvd disc for playback.
Hope these info will help you.
Thanks.
Dec 17, 2010 | Hitachi Video Cameras
I transferred some pictures from my computer on a Maxell RW disc. When I played the disc on my Funai DVD/VHS Dual recorder model DRV-2737 no picture appeared on TV screen. What could be the problem? On the...
sorry...it seem like your dvd/vhs player is outdated...(do the rw disc plays in pc?) are you using Nero software? this will curve the problem...or try another DVD RW brand that funai is compatible with...dvd players, dvd recorder and pc dvd burners do roll back...all must be a year or less apart to work with each other....
May 26, 2010 | Funai PY90VG DVD Player/VCR
Am unable to transfer the disc to my pc
Finalize mini DVD in camera, option is in camcorder menu.
Take out finalized DVD and put it into computer drive and copy files there.
Jul 08, 2009 | Hitachi DZ-BX31E DVD Camcorder
DVD
the best discs to get are dvd ram discs as they can be edited in the camera ..hope this helps you my friend.......
Aug 08, 2008 | Hitachi DZ-MV550E DVD Camcorder
Magnavox ZV420MW8 VHS/DVD/RECORDER
This is the link to the ZV420MW8: http://www.funai-corp.com/6pdf/om/ZV420MW8.pdf
Jun 27, 2008 | Funai Televison & Video
NEED FINALIZING DVD
I had the same problem. What I did on my Hitachi DVDCam was to click the "Stop" button to clear all keystrokes. Then, click "Menu". The camera might say "Creating Thumbnails" for a minute but then it will stop and display a mock menu for your mini dvd. Then click "Menu" and the toolbar should pop up. With the arrow keys, scroll down. You should see a menu that says "Finalize DVD" click this. For a small dvd, it will take around 13 min. to finalize.
Dwmcc
Apr 24, 2008 | Hitachi DZ-GX3100A DVD Camcorder
Transfer VHS to DVD
The illustrations within the PDF is very help!
To play disc in other DVD players…
The disc needs to be finalized.
Page 37 of the manual has “Finalizing a disc”.
Recording from DVD to VCR…
Page 39 “Dubbing Mode”
Type in the box: MWR20V6
Nov 09, 2007 | Philips Magnavox MWR20V6 DVD Recorder/VCR
Finalizing discs
IT USUALLY NEEDS TO BE PLUGGED INTO THE MAINS ADAPTOR TO FINALISE DISCS TRY THAT.
Nov 08, 2007 | Hitachi DZ-GX3100A DVD Camcorder
My dvd recorder no longer records
take your DVD player to a tech and your problem will be all over.good luck
May 17, 2007 | Funai FDRV90E DVD Recorder/VCR
Televison & Video Logo
41 people viewed this question
Top Hitachi Televison & Video Experts
matt martin
matt martin
Todd Hill
Todd Hill
Are you a Hitachi Televison and Video Expert? Answer questions, earn points and help others
