The mechanic should check the battery if it is full charge or not . the battery should be inspected if it is corroded , lock of battery water or distilled water. then check the battery plate the one that divide the water in the battery check it if dirty or corroded . If these parts of battery are worn out or destroyed , then replace them.After checking the battery or after inspecting the battery then charge it fully on electricity .After it you still have to check the car's ignition system . check for loose wires or worn out fuse.from ignition switch , ignition coil , spark plug , distributor assembly.You have to check these for to be sure that when your going to start the car it will start properly. those loose wires you have to re connect them ,those worn out fuses replace them. Then place the battery back to its place.
Car
not starting or turning over indicates towards multiple possibilities. It can
be issue with battery or weak battery. But if battery checks out ok, then it
can be starter issue or faulty alternator or problem with low fuel pressure or
no spark at spark plugs due to dirty spark plugs or faulty ignition
coil or injectors getting cracked or dirty and needs to be cleaned.
To
confirm the problem, the basic troubleshooting is required.
Click
this link below and follow the troubleshooting:------
http://technoanswers.blogspot.in/2012/02/car-starting-issues.html
This will help.
Thanks
alot more info needed
