Question about Aquabot Pool & Spa
Good morning, I have a Aquabot that flips over when it gets to the edge of the pool. What could be the problem?
Posted by Kirsten Ann Secord on
mehan
    Habit-Forming:
    Welcome Back:
    Visited the website for 2 consecutive days.
  • 19 Answers
Not using it enough,
Posted on Aug 14, 2019
2 Related Answers
Delita Foltz
  • 83 Answers
SOURCE: Aquabot is pushing out water but will not move to clean the pool
I am not sure if this is the manual that you are looking for, or not, but just in case. If you following the link below it will take to you the T2 User's Guide, with the trouble shooting.
http://www.i-love-my-aquabot-automatic-pool-cleaner.com/support-files/aquabot-turbo-t2-manual.pdf
According to the trouble shooting guide:
Pumps Water, but Does Not Move or Moves Slowly
1. Remove any foreign matter that may be obstructing Drive Tracks.
2. Check Drive Belts and Tracks. Make sure they have not slipped out of place and that they're not loose.
3. Observe Drive Pulley, if it is not moving contact Customer Service.
Posted on Jul 09, 2009
Geekman
Chris Hingee
  • 32281 Answers
SOURCE: aquabot is cleaning only one area of our pool and
The pool hose that is attached to the Aquabot gets set into a pattern so it moves to one part of the pool. Remove the pool hose and rotate it approx 100 degrees and re-attach it, then it will clean the pool. You may need to rotate the hose again to get the cleaner to clean the whole pool area.
Posted on Jun 03, 2011
My aquabot keeps trying to come out of the pool
Aquabots are interesting little robots! They're made to clean the entire surface of the bottom of the pool, and in regards to cleaning the sides, they are programed to climb walls, but once they reach the surface the programming recognizes the specific angle of the top and sends it back down the wall. Normally an Aquabot should never leave the pool. It should reach the surface and go back down the wall to continue cleaning. Good luck!
Pool Remodeling in Clearwater FL
Jul 17, 2014 | Aquabot In - Ground Robotic Pool Cleaner
How do you clean the filter on aquabot
I have a small stream nozzle on my hose that puts out a good but of pressure. I turn the filter bag inside out and spray it til it's white. I then turn it back in and spray water from the inside out. The bag is also machine washable if it still isn't clean.
Jun 18, 2014 | Aquabot Pool Rover Above Ground Robotic...
Will not clean shallow end of pool heads directly to deep end
Make sure that the Floating Handle is locked diagonally across the top of your Aquabot's body.
Clean the Filter Bag thoroughly so that the fine particles of dirt that get trapped within the fibers of the
Filter Bag are removed. To test if the Filter Bag is inhibiting the
Aquabot's performance simply remove the Filter Bag and operate the cleaner without it. If the Aquabot then pumps
water strongly, and climbs the walls properly, the Bag most likely requires a thorough cleaning
Sep 12, 2011 | Aquabot In - Ground Robotic Pool Cleaner
Keeps flipping over
Make sure that the treads are not worn on this pool cleaner. It could also be that you have air in the head. With these automatic pool cleaners, you can usually hold the cleaner upside down under water for a few mintues to free the trapped air. You might also have to add weight to the bottom of the cleaner.
May 19, 2010 | Aquabot Turbo In Ground Pool Cleaner
Online instruciton manual
Here is a page of articles from aquabot ,, lots of instructions you can view ..
http://www.123aquabot.com/Articles.htm
Please Vote !!
May 15, 2010 | Aquabot Pool Rover Above Ground Robotic...
I just bought replacement scrubbing brushes for my aquabot. The new ones are different. How do I install the new style cleaning brushes?
http://www.i-love-my-aquabot-automatic-pool-cleaner.com/Aquabot-Troubleshooting.html my give useful instrucyions, or, if you are near Phoenix Az I'll be glad to help! S. Christian [email protected]
Jul 12, 2009 | Aquabot Robotic Pool Cleaner
Jul 05, 2009 | Aquabot Turbo T2 In - Ground Pool Cleaner
My aquabot does not reverse
check with the website: http://www.i-love-my-aquabot-automatic-pool-cleaner.com/Aquabot-Troubleshooting.html which gives a wealth of information and ideas to try. S. Christian [email protected]
Jun 30, 2009 | Aquabot Robotic Pool Cleaner
Aquabot Turbo T won't climb
1.`. Replace your old, water logged floats. They will dry out when the unit is out of the pool, and the unit will work fine until they water log again, which may takes as few as 10 minutes in the pool. 2. Stop using all those words *********** didn't teach you and probably didn't even know...This is a common problem. http://www.i-love-my-aquabot-automatic-pool-cleaner.com/ gives some really good insight, too! S. Christian [email protected]
May 11, 2009 | Aquabot Turbo T
Pool & Spa Logo
136 people viewed this question
Top Aquabot Pool & Spa Experts
Anthony Ward
Anthony Ward
Kardoc
bulbist
bulbist
Are you an Aquabot Pool and Spa Expert? Answer questions, earn points and help others
