Computers & Internet Logo
Candice Morris Posted on Jul 18, 2019
My note 8 won't turn on unless plugged then gets stuck in the logo screen at start of turn on process
  • Patrik Parker Jul 18, 2019
    Hi Candice Morris, I want to help you with your question, but I need more information from you.
    Please Call Customer Service For Help and & Support Call 1 8O5*465*751O Toll Free 24x7
5 Related Answers
ginko
Ginko
  • 19396 Answers
  • Posted on Mar 20, 2008
SOURCE: Stuck on CREATIVE Screen
Take out battery and put it back in, see if it reset
A
Anonymous
  • Posted on May 04, 2008
send it in and they will give u a new one!!! (free)
Anonymous
  • 272 Answers
  • Posted on Nov 28, 2008
SOURCE: ford courier van x reg td
Have you checked the heater plug relay?
Anonymous
  • 366 Answers
  • Posted on Dec 26, 2008
SOURCE: NEW ACER ONE NETBOOK WILL NOT BOOT UP
Try Safe Mode.Disconnect every device (Mouse also)
Hit F8 at very beginning until you get a list of options select Safe mode and check if Windows starts.
then try step by step confirmation option.
say yes to every request until freeze: last driver you accepted to load is the culprit.
Remove it in Safe mode using Start/Run/Msconfig
Anonymous
  • 12 Answers
  • Posted on May 18, 2009
SOURCE: window xp is starting in logo screen but it does not appear other programs
you might have loose connection on your hard disk.
How do I create disc for Acer aspire 5560 notebook they recovery disc
hi
How to reinstall the Operating system on your computer
Select models, with Microsoft Windows, have the ability to have the Operating System reinstalled from a hidden partition built into the computer.
Note: During the process, all data stored on your computer will be overwritten. This means all your files, such as email and photos, will be erased. Therefore, we recommend making a backup of all personal data before starting the recovery process.
To start the system recovery:
1.Restart the computer.
2.When the Acer logo appears on the screen, press the Alt and F10 keys repeatedly.
3.If you are prompted with a Microsoft Windows boot screen, press the Enter key.
4.After the system recovery application has loaded, follow the prompts to reinstall the Operating System.
If the ability to reinstall from the previous method is not available or fails, recovery of the Operating System will need to be from Recovery Media. If you do not have a set of Acer Recovery Media, you may purchase the set online from the Acer Recovery Media Order Form..
Note: If your computer does not have an internal optical disc drive, an external optical disc drive will be required in order to recover the Operating System using Acer Recovery Media.
2.When the Acer logo appears on the screen, press the F12 key repeatedly to enter the computer's Boot Menu.
3.Press the CD-ROM drive eject button and insert the disc labeled System CD.
4.Close the CD-ROM tray.
5.Refer to on screen instructions to select either CDROM or USB CDROM.
6.The computer will boot from the Acer Recovery Media
7.When prompted for the Recovery CD, remove the System CD and insert the Recovery CD.
Note: If there are multiple Recovery CDs, please insert the first of the Recovery CDs.
8.After the system recovery application has loaded, follow the prompts to reinstall the Operating System.
Note: if your computer is unable to run the Acer Recovery process, or errors occur during recovery, please contact Acer support.
Please take time to rate me
Reboot samsungsamsung galaxy indulge stuck on samsung logo at boot up
1. Turn the power off first
2. Slide out the keyboard
3. Power on and press ad hold the 'R' Key
4. In Android system recovery use Vol keys to scroll up and down
5. Use the power key to make a selection.
If you cannot get to a recovery you will need to use ODIN to flash phone to factory state. this "should" fix anything unless phone itself is bad. Here is a ODIN guide for your phone. ODIN is official samsung flashing tools available for free from samsung. Good Luck.
http://theunlockr.com/2012/05/18/how-to-get-the-samsung-galaxy-indulge-r910-and-r915-back-to-stock/
Won't finish booting
Sounds like a corrupt operating system you can try the master reset steps below WARNING ALL PERSONAL DATA WILL BE LOST UNLESS STORE ON THE SD CARD
Other wise contact your provider via website or phone for the closest repair center
http://locator.t-mobile.com/Locator.aspx
  1. Back up all necessary data.
  2. Turn off the phone.
  3. Press and hold the Volume Down and Power keys.
  4. Wait 3 seconds and press the Back and Menu keys.
  5. Note: If you see the LG logo before pressing the Back and Menu keys, the reset hasnt been completed and you will need to restart.
  6. Release the Power/Lock key after you see the LG logo.
  7. Release the remaining keys after the LG logo flashes (blinks once).
  8. The Android Unpacking screen appears.
  9. The phone will restart and complete the factory reset.
9helpful
3answers
Android vimicro logo stuck on screen
ANDROID Tablet Freezes at Android startup screen
For Superpad VI - 10.1" Android Version 4.03, this worked for me!
1. Press & hold START button
2. When "VIMICRO" appears, Then Press & Hold the MENU button
3. The Android System Recovery <3e> Menu should appear
4. Scroll down using the Volume Key to "wipe data/factory reset"
5. Press HOME Button
6. Scroll down to "Yes - delete all user data"
7. Press the HOME Button
At this point the system will do a recovery and hard start, and will be on "reboot system now
8.Press the HOME Button
Your system should reboot normally, but you will need to enter all new data, as it has been wiped clean.
Top The Computers & Internet Experts
Alexander
vince
Steve Sweetleaf
Steve Sweetleaf
Are you a The Computer and Internet Expert? Answer questions, earn points and help others
