Question about Johnson Boating
I have a 1991 40 horse Johnson outboard motor for some reason that only wants to run on choke what can I do to remedy this
Posted by Anthony Sadecki on
rlev_7
    New Friend:
  • 47 Answers
You need to take off the carborator clean take apart clean with carb cleaner and put it back together good to go make sure the fuel line has no hole
Posted on Jul 18, 2019
5 Related Answers
Gene Pitts
  • 159 Answers
SOURCE: relay switch for power tilt for Johnson outboard motor 40HP
Hello jalbin0308, I may can help but "NEED MORE INPUT" said ET. Model, year, HP, ect.
Posted on Oct 30, 2008
Anonymous
SOURCE: Johnson Outboard Motor 175HP
Not knowing what year it is...Light and alarm? Reason: overheat low oil etc. check water flow..water pump. The motor is most likily going into S.L.O.W mode. its a fail safe system. Last possibile reason ..CDI box and or stator.. pull plugs check compression...should be 120-150 lbs.
Posted on Feb 21, 2009
Anonymous
  • 52 Answers
SOURCE: 1974 60hp johnson outboard won't run on full throttle.
Carbs probably need to be cleaned and re-built. Common problem in outboards that havent been run in a while
Posted on Apr 13, 2009
Anonymous
SOURCE: Boat engine 1995 Johnson Outboard 70 HP
Ihave a 1991 70 hp Johnson outboard thats hard to start the first time but starts good after that. Seems to be flooded. Starting rpm seems to be low.
Posted on Jul 25, 2009
Hal Hallman
  • 770 Answers
SOURCE: 1974 Johnson 70 hp outboard, quits on acceleration.
It sounds like your motor is starving for fuel. At an idle, you have adequate flow to keep the engine running. When you call for more fuel...you sputter and quit. Could be a clogged filter or trash in the line or in a jet. Yes you will have some air in the bulb, but not a great deal. You could be sucking air at a hose connection (loosing some prime)...try this, start the engine and slowly accererate, have someone pump the bulb as you accelerate, see if the engine works properly while doing this test.
Posted on Sep 20, 2009
What year and other information can you tell me about a Johnson Outboard motor model 50ESL73R Serial # E3817581
Model # shows it's a 1973 year, 50 horse power. 2 stroke engine with 50 to 1 fuel mix.
Apr 27, 2017 | Johnson Boating
What year model is a mercury outboard 4 horse with serial number 3303712?
call a mercury dealeris all I can tell you .we handled johnson /evinrude.
Jun 17, 2014 | Light Outboard Motor Boat Bass Fishing...
What year is my Johnson "seahorse" serial# J252 668, model# CD-22M
the SEA HORSE models were made late 50's thru early 60's
Apr 02, 2014 | Boating
70HP JOHNSON OUTBOARD doesn't want to run with cowl on.
There is an air inlet at the upper back side of te cowl. Check if that is open...
Mar 07, 2014 | Seloc Marine Johnson Evinrude Outboards,...
Starter dragging on 2001 Johnson 90 horse outboard
Check batt wires good contact,check brushes in starter have good earth check batt cables have no black death
Jul 31, 2013 | Light Outboard Motor Boat Bass Fishing...
115 hp johnson great difficulty to cold start,sometimes it even run the baterry flat but once it started there is no problem in starting again what could the reason for this be or do i just start the...
Hello vcd9,
When You Turn The Key On ,Press It In To Activate The Choke Solenoid And Then Crank At The Same Time,This Should Solve Your Problem, If All Is Fine With The Engine.
Cheers
Gordon
Feb 11, 2013 | Light Outboard Motor Boat Bass Fishing...
What type and weight of oil for johnson 28 horse outboard boat moter
Hi, mix the gas and oil at 50 to 1 and use two cycle outboard oil. Regards Phil.
Jun 29, 2012 | Seloc Johnson Outboards 2002-2007 Repair...
Merc outboard 115HP 1996 fuel primer/Choke
Hello there
here is a good place to start ok Outboard (wiring A Tachometer To An Outboard, Mercury Outboard Float) safe.gif
merc outboard motors mercury outboard ... diagram of mariner outboard motors johnson outboard fuel problems ... johnson outboard motors ebay 1996 115 hp mariner outboard
  • tipsterdatabase.com/mods.php?id=outboard
  • · Cached page
Aug 27, 2009 | Boating
Boating Logo
129 people viewed this question
Top Johnson Boating Experts
Marvin
Marvin
Lawrence Oravetz
Are you a Johnson Boating Expert? Answer questions, earn points and help others
