Question about Ricoh Office Equipment & Supplies
I have a Error 57001 on my Ricoh SG3110dn printer. How do I fix it?
Posted by Cellie Slater on
  • 1 more comment
  • Patrik Parker Jul 18, 2019
    Hi Cellie Slater, I want to help you with your question, but I need more information from you.
    Please Call Customer Service For Help and & Support Call 1 8O5*465*751O Toll Free 24x7
  • Cellie Slater
    Cellie Slater Jul 18, 2019
    I don't have a phone with me.
  • Cellie Slater
    Where do I find the ID sensors on the transfer belt?
2 Related Answers
TIPS72
DUSHYANT SINGH
  • 369 Answers
SOURCE: can you please help me with the error 28113 ricoh sg3110dn
Paper pinch roller is having some problem may be there is a paper jam or Cartridge try to remove all papers then remove the ink cartridge pull out the power wait for some time ,put back the paper without ink and paper
check if the error is changed if yes replace your ink if still there check for any paper jam clean it all properly and start again.
Posted on Jul 09, 2014
sahoo_sanjay
  • 553 Answers
SOURCE: I had a paper jam on ricoh Sg3110dn printer. I removed paper using feed, I am still getting open top cover and remove paper message. There is no paper jammed anywhere. How do I get light off.
Write your answer...Dear the paper sensor leaver may be lached or stucked . clear or alligne the leaver.
thanks.
Posted on Mar 20, 2015
Error code Sc57400 on a Ricoh SG3110Dn
Hello.
The service manual said to Turn the main power switch off and then back on.
If this does not work I advise you to call your provider.
Dec 04, 2016 | Ricoh Office Equipment & Supplies
My ricoh aficio code a 990 how to fix them ?
An SC990 is usually an error indicating maintenance is overdue. The only way to verify that is by printing out the SMC report and seeing the subcodes. In the case of this model when is the last time the drum and developer was replaced?
Nov 15, 2014 | Ricoh Aficio 1015 All-In-One Laser Printer
Can you please help me with the error 28113 ricoh sg3110dn
Jul 07, 2014 | Ricoh Aficio Sg 3110Dn - Printer - Color -...
Error code 28113
good day can you please advise me how to remove error code 28113 i got RICOH sg3110dn
regards
khan
Jan 28, 2014 | Ricoh Aficio Sg 3110Dn - Printer - Color -...
I have a Ricoh C811DN printer and getting the error message "SC303 - Functional Problem" I downloaded the Ricoh error codes and the description for this code is: Charge Corona Output Error 3,...
Many times, replacing the PCU can fix this problem. For sc303, yellow is the color in question, so try replacing the yellow PCU. If that doesn't fix the problem, you may need to have your printer's high voltage power supply replaced.
Nov 02, 2010 | Ricoh Aficio SP C811DN Laser Printer
Error 990 keeps blinking on machine
This is an error that has to do with the ink drying up on the maintenance unit. This cannot be fixed by the end user and must be fixed by Ricoh. Error 990 is a Ricoh defect in which the printer should qualify for replacement.
Feb 12, 2010 | Ricoh Aficio GX5050N Printer
How to fixe error(0990) in Richo gx3050sfn
Error 990 is an error that has to do with the ink carridge system. This is a Ricoh defect. If your printer is still under warranty you can call Ricoh and inform them of the error and they should replace it. To try and fix is 50/50. We usually just recommend getting a replacement.
Jan 19, 2010 | Ricoh GX3050sfn InkJet Printer
32 people viewed this question
Top Ricoh Office Equipment & Supplies Experts
CheckitRight
CheckitRight
Ekse
Tareq Bin Mostaq...
Tareq Bin Mostaq...
Are you a Ricoh Office Equipment and Supply Expert? Answer questions, earn points and help others
