Question about Lands Phones
How do i adjust volume on my it5625 phone? - Lands Phones
Posted by ellis ikenda on
Low volume on headset
Press the volume up button.
When the phone is idle, the volume with set teh ringing volume.
When the phone is in speaker phone mode, the volume adjusts the speaker level.
When in headset mode, the volume adjusts the headset volume....
Dec 06, 2012 | Avaya 9608
What is the code to increase the volume of Samsung C3010
Hi
By volume do you mean Ring tone volume or Handset volume?
Ring tone volume adjustments.
Press menu >settings >phone profiles
Scroll the phone profile you ares using.
Press on options >edit and select call alert volume.
Scroll right or left to adjust the volume levels.
press on select and then save.
The handset volume adjust is done by pressing on the 1st side key in idle mode.
Feb 27, 2012 | Samsung Cell Phones
How do i adjust the volume on my phone, not ringer, but voice volume?
While you're in the middle of a call use the same button to adjust the ringer volume. It should only adjust the in call volume.
May 03, 2011 | Motorola Mobility W755 (4 GB) Cell Phone
LHow do I increase the volume as the phone is very quiet
Hello there,
Adjusting the volume on an HP Officejet All-in-One
Follow these steps to adjust the volume of the various fax sounds.
Adjust the rings and beep volume
1.Press the Setup button P(wrench).
2.Press the arrow buttons (Left and right) to select Basic Fax Setup , and then press OK .
3.Press the arrow buttons (Left and right) to select Rings and Beep Volume , and then press OK .
4.Press the arrow buttons (Left and right) to adjust the volume, and then press OK .
Adjust the phone line and monitor volume
1.Press the Setup button (wrench).
2.Press the arrow buttons (Left and right ) to select Basic Fax Setup , and then press OK .
3.Press the arrow buttons (Left and right ) to select Phone Line, Monitor Volume , and then press OK .
4.Press the arrow buttons (Left and right ) to adjust the volume, and then press OK .
Adjust the handset volume
When you receive a call, pick up the handset of the product, and then press the arrow buttons (Left and right ) to adjust the handset volume.
Please feel free to leave a testimonial if this works and please do not forget to click 4 thumbs.
Cheers!
Mar 22, 2011 | HP J3680 Officejet All In One Printer
How do i turn up volume on hp officejet all in one
Adjust the volume
The HP All-in-One provides three levels for adjusting the Ring and Beep Volume and
the Phone Line Monitor Volume.
The ring volume is the volume of the phone rings. The beep volume is the level of
button press and error beeps. The default Ring and Beep Volume setting is Soft.
The Phone Line Monitor Volume is the volume of dial tones and fax tones. The
default Phone Line Monitor Volume is Medium.
To adjust the Ring and Beep Volume from the control panel
1. Press Setup.
2. Press 4, and then press 4 again. This selects Basic Fax Setup and then selects Ring and Beep Volume.
3. Press to select one of the options: Soft, Loud, or Off.
4. Press OK.
To adjust the Phone Line Monitor Volume from the control panel
1. Press Setup.
2. Press 4, and then press 5. This selects Basic Fax Setup and then selects Phone Line Monitor Volume.
3. Press to select one of the options: Medium, High, or Low.
4. Press OK.
Trust this is helpful. Please vote. :)
Dec 14, 2010 | HP Officejet 4355 All-In-One InkJet...
How do i adjust the volume on my panosonic kx tga 131az cordless phone.
With Panasonic phones the volume of whatever function is active can be adjusted with the arrows button. While it is ringing use the arrow up or down to adjust ringing volume. When off hook (you can hear dial tone or you are on a call) use arrows to adjust handset volume.
Dec 08, 2010 | Panasonic KX-TG5632 Phone
How to adjust hearing volumn on samsun cell phone
Adjusting the volume during a call Use [up navigation /down navigation ] to adjust the earpiece volume during a call. Press [up navigation ] to increase the volume level and [ down navigation] to decrease the volume level.
Nov 27, 2010 | Samsung SGH-D900 Cellular Phone
How do i adjust voice volume on my jitterbug
The rubber volume button on the outside of the phone adjusts both the ringer volume and the call volume, which is how loud a caller sounds when on a call. If you are not on a call, the volume button will adjust the ringer volume. To adjust the volume of a caller, you must adjust the volume while on that call.
To do this, while looking at the inside screen, adjust the volume by using the rubber volume button, which can be found on the outside of the phone. Press the top of the button to increase the volume and the bottom of the button to decrease the volume. The inside screen will display the call volume level. You may also set the call on Speakerphone mode. If you have the Jitterbug J model, there should be a button labelled "SPKR" on the upper left corner of the keypad.
If you need additional help, you can call a customer service expert available 24 hours a day 7 days a week at 1-800-733-6632 who will walk you step-by-step through the process.
Nov 19, 2010 | One Touch Jitterbug One-Touch Cellular...
Does not ring
The Volume key allows you to adjust the volume level for the currently active audio device (handset, headset, or speaker). When no audio devices are active, pressing the Volume key adjusts the ringer volume.
Adjusting the Volume of the Ringer, Handset, Headset or Speaker
Note: By performing this function, default volume level will be replaced.
  1. Press the up or down arrow at either end of the Volume key to reach the desired volume level.
  2. When you are satisfied with the setting, press the Save softkey.
Note: When adjusting only the ringer volume, there is no need to press Save. The settings are automatically saved upon adjustment.
See the below link for user manual
http://noc.unet.maine.edu/IPT/7961_7941_User_Guide.pdf
Jun 20, 2009 | Cisco 7941G IP Phone
Ringer Volume
I am assuming this is on a DTU 16D nec phone. On the right side of the phone is a volume up and down button. If someone calls you, you adjust this while the phone is ringing. If you adjust it after you answer it controls the voice volume (what you hear through the ear piece) if you adjust it while the handset is down but there is no one calling you it adjusts the display contrast on the phone.
May 04, 2007 | NEC Electra Elite DTU 16D-2 Corded Phone
Lands Phones Logo
136 people viewed this question
Top Lands Phones Experts
Marvin
Marvin
k24674
Are you a Lands Phone Expert? Answer questions, earn points and help others
