T-Mobile Wing™ Smartphone Logo
Anonymous Posted on Sep 01, 2009
T-Mobile Wing rings normally when calls are received and calls can be dialed OK. HOWEVER, when connected on an incoming or outgoing call, I cannot hear the other party and they cannot hear me. I tried the MUTE button but the problem persists whether it says "Mute" or "Unmute". Volume is up to max. Also, Camera works OK BUT the "click" sound is not heard when taking a photo anymore. I pushed RESET and when phone came on again I heard the "coming alive" sound but still no sound when making or receiving calls.
Anonymous
Level 1:
  • Contributor 30 Answers
  • Posted on Sep 01, 2009
Anonymous
Contributor
Level 1:
Answers
30
Questions
0
Helped
5838
Points
66
I hate to say it but you might need to hard-reset the phone. If you choose to do so BACK UP YOUR DATA first. You can get a free program called "PIM Backup." This will let you back up all of your contacts, emails, etc. (all personal information). To hard reset, hold down both of the soft keys at the same time, then simultaneously use your stylus to hit the reset button. You should get a black screen with some text on it asking if you want to hard reset. Press the "send" key to confirm. If you don't get the screen right away keep trying as it doesn't work perfectly every time.
Testimonial: "I took my T-Mobile Wing back where we bought it. They did a Hard Reset as you suggest. Sadly, that did work. I now have a low tech Nokia 1680."
I-DECT Phone. It receives incoming calls but won't dial outgoing.
Question edited fir clarity
Ideas here. You can also Google
make model manual
See if it is a an outgoing call barring feature.
https://www.google.com/search?q=I-DECT+Phone.+It+receives+incoming+calls+but+won%27t+dial+outgoing
Incomming calls received no problem outgoing calls die after first ring cannot connect??
Did you try switching off and switching on your mobile or just try once with airplane mode and check once this should be issue with network
Oct 30, 2019 • Cell Phones
I get incoming calls but unable to make outgoing calls
Make sure that you have got sufficient credit to enable you to make outgoing calls. You can still normally receive incoming calls with no credit but make any except to emergency numbers.
7helpful
3answers
I have a mobile of spice model no m4330 .from todaymy incoming calls are barred .if anyone dial my number it answeres that the number is busy . my outgoing calls are running smoothely.pls help me to break...
To cancel bared incoming calls on your phone, enter one of the code given below.
##67#, ##21#,##62# or ##61# then okay/send/yes. the phone will be unbarred.
Regards
Jun 25, 2011 • Cell Phones
1helpful
I can make and receive calls, but I cannot hear anything.
Check Windows Sound mixer for application volume. Down in system tray at right side of taskbar double click sound icon for XP or click sound icon once and click Mixer for Vista. Look through volume settings for your phone application. Make sure it is not muted and volume is up.
2helpful
Nokia N72 mobile phone, am unable to hear dial tone when dialling and unable to hear incoming call answering a call and unable to from them when I make outgoing calls.
increase the volumes of ring tones ,unscrew the phone to check if the ringer is not faulty or damaged,repair or replace it ok
Philips VOIP8411B/37 IP Phone - Cannot make outgoing Skype calls
the internet connection's outgoing is too slow. ALl internet connections have an outgoing and an incoming speed. Make sure you are not uploading anything to the internet or get a faster internet service provider
2answers
Call barring
Use the network services menu for this...
Use this menu to access network services. Please
contact your service provider to check their availability and subscribe to them, if you wish.
This network service allows you to restrict your calls.
1. Select a call barring option:
All outgoing: prohibit outgoing calls.
International: prohibit international calls.
International except home: only allow calls
to numbers within the current country when
you are abroad, and to your home country.
All incoming: prohibit incoming calls.
Incoming while abroad: prohibit incoming
calls when you use your phone outside of your
home country.
Cancel all: cancel all call barring settings,
allowing to be sent and received normally.
Change barring password: change the call
barring password obtained from your service
provider.
2. Select the type of calls to be barred.
home country.
provider.
if you have any queries about your mobile..you can have a look at this user manual which can be downloaded from
http://safemanuals.com/user-guide-instructions-owner-manual/SAMSUNG/SGH-D600-_E
hope this helps :)
Top T-Mobile Computers & Internet Experts
Mohammad Abumuailek
Mohammad Abumuailek
Grand Canyon Tech
Grand Canyon Tech
john h
Are you a T-Mobile Computer and Internet Expert? Answer questions, earn points and help others
