Question about Health & Beauty
How to Service resmed s9 cpap - Health & Beauty
Posted by David Gordon on
1 Related Answer
jerardi
David Payne
  • 14162 Answers
SOURCE: My Resmed Elite S9 does not start properly the company that sold me my machine has moved away I live in Albion Park where can I go for assistance am not able to breathe
call sears home services at 1-888-266-6317 and get a quote for a service call and possible repair. the website is www.searshomeservices.com
Posted on Nov 09, 2014
How do I turn off the humidifier on my Resmed cpap machine?
Most Resmed models have a clear plastic reservoir to hold the water.
Just remove the reservoir.
Sep 03, 2018 | The Health & Beauty
I just got my resmed AirSense10.I got the set-up figured out,except for how to connect the air supply to the Resmed10. Can you help me?
The small tubing is for connecting to an oxygen concentrator or oxygen tank You might not have that requirement.
Oct 21, 2017 | Washing Machines
Displays a reset to default error. How do I reset the machine?
Remove the SD card and power off and on with the card still removed from the machine. It probably won't help, but it's worth a try.
May 26, 2015 | ResMed S9 AutoSet w/ H5i
Nov 09, 2014 | Washing Machines
How to adjust pressure on resmed s9
I think you are talking the the RESMED S9 CPAP Machine. If so,
1.Press the Setup button and the Push Dial (see first image below) for 3 seconds.
2. Turn the Push Dial until you see the Options Screen (see second image below).
3. Press the Push Dial once to select the Option Screen.
4. Turn the Push Dial until Set Pressure is highlighted in blue.
5. Press the Push Dial once. The highlight should now be orange.
6. Press the Push Dial once. The selection should change from orange to blue.
7. If finished, turn the Push Dial until <8. Done!
Jan 29, 2013 | Health & Beauty
My 3 yr old Respironics CPAP has stopped putting out the pressure it is supposed to. Still works and still show 12.5 Lb - but is 1/2 as strong - maybe less.
if have pressure gauge u can check that if your using a manual machine the pressure will be constant as the set pressure is 12.5 and there will be ramp which will start with lower pressure and reach to 12.5 as per the set timings and if you are using a automatic mcahine no need to worry.
Mar 17, 2011 | Respironics Health & Beauty
Health & Beauty Logo
44 people viewed this question
Top Health & Beauty Experts
ray gallant
Bill Boyd
ADMIN Canada
ADMIN Canada
Are you a Health and Beauty Expert? Answer questions, earn points and help others
