Nikon D5000 Digital Camera Logo
Question about Nikon D5000 Digital Camera
Nikon 18-55mm AF-S/ VR lense shudder?
I am using a Nikon (D5000) with a 18-55mm AF-S and VR lense. When I press the shutter button down to see the focus and release the shutter back..I hear and feel a ticking/buzzing sound and also see a slight shudder (movement)in the lense optics (view finder). When I fully press the shutter button down to take a picture it is fine. This only happens when I press the shutter and release it without taking a picture. Do I have a problem with my lense/camera. I also found the same thing happen on another demo D5000 camera with the 55-200mm AF-S /VR nikon lense. Thanks
Posted by nbugli on
  • 1 more comment
  • nbugli Sep 01, 2009
    The auto focusing seems to work fine. It is when I autofocus to see my subject and release the shutter button...I can see a slight shudder (movement) in the image I am seeing (through the view finder)and hear a snall buzzing/ticking noise. Its like the optics are moving/adjusting after I release the shutter button.
    Thanks. It does not see mt do that when I am using manual focus.
  • Anonymous May 11, 2010
    Is this more than just the focusing motor in the lens? Maybe you could switch to manual focus and see if it still ticks/buzzes.
  • Anonymous Mar 13, 2014
    Won't release. Camera card Nikon D5000
Jeff Marcus
    Scholar:
  • Nikon Expert
  • 115 Answers
I believe you're hearing the VR in the lens adjusting. Try turning the VR off and see if you hear the sound. If not, then you have a normal operating lens.
Posted on Sep 18, 2009
Anonymous
    New Friend:
I do have the same problem. i also have D5000. i think the VR mechanism is the reason.
Posted on Jan 06, 2010
  • Anonymous Jan 09, 2010
    is the problem with your D5000 already solved? Please help me, I also have the same problem.
1helpful
2answers
Hi, I have a Nikon d5000. Love it. Lately, when I put on the zoom lens--Nikon DX AF-S Nikkor 55-200mm 1:4-5 6G ED, and try to take a picture it will not let me. I have it on auto-focus, zoom out
Hi Anna,
In order for your Nikon to auto focus correctly, you need to have several things:
First - focus indicator. In your viewfinder, locate it on the bottom row of the status information bar; you should see a small, green circle in the left-most position. This will BLINK when you partially depress the shutter release (or back button focus - depending how you focus your D5000) whenever the subject is OUT of focus. It will switch to "STEADY ON" when the subject is IN focus. Please note that you will not be able to release the shutter any time it is blinking unless you make a change to the setting that will allow you to release the shutter when the camera is out of focus (not recommended).
Second - light. You must have enough light entering the camera for it to detect areas of different contrast on the selected focus point. If there is not enough light there is too little contrast for the camera to autofocus and no matter how close or how far (and everywhere between) the focus is set resulting in the camera "hunting" near and far to find it. The green circle will not stop blinking. Have you tried in a well lit room or outdoors in daylight?
Third - minimum focus distance. All lenses have a minimum focus distance. Acording to Nikon, yours is rated at 3.6' (1.1m) (see: http://www.nikonusa.com/en/Nikon-Products/Product/Camera-Lenses/AF-S-DX-VR-Zoom-Nikkor-55-200mm-f%252F4-5.6G-IF-ED.html for full specs on this lens). This means your subject needs to be at least 3.6' away to be able to focus on it - manually or aut0matically - it makes no difference. There are lenses that do "very close" focussing that are called "Macro" (but curiously Nikon branded versions of these lenses are called "Micro"), that are also telephoto lenses. Your lens is not a macro/micro type.
Lastly - operational equipment. It is possible that there is an issue with the D5000 camera body or lens (or even both). Try another lens to see it it works as expected. No other lens? Go to camera store with your camera and lens and "shop" for a new lens. Ask to try it out in the store and see if it it works. Maybe the counterperson will identify another issue with your set up.
I hope this helps & good luck!
Why when i press my shutter halfway it does not focus ?
Make sure the A-M switch on the lens is set to A for autofocus.
Also make sure the AE-L button is set to on (pg 144 of your manual) in your menu's otherwise the half-press of the shutter won't allow it to focus.
Nikon d5000 really dark
go into settings an change the lighting
Why wont my Nikon af nikkor 70-300mm G lens autofocus its self with my D5000 camera
The D5000 does not have a focus motor in the body, relying on the lens to have one. The old 70-300mm G lens does not have a focus motor, relying on the camera to have one. Thus, this combination will not autofocus.
The newer 70-300mm AF-S G lens, as well as the even newer 70-300mm VR AF-S lens, do have the autofocus motor and thus will autofocus on the D5000.
1helpful
I had my D5000 for a month now, recently i noticed something with my camera. looking though the viewfinder only, whenever i focus (half pressing the shutter button), the view from the viewfinder moves up,...
Welcome to the real world of photography, using the viewfinder is a whole new experience in the crating of fine photographs. Aside from this what you are actually seeing is the VR turning on and locking onto the target, you should actually feel this happening as well (if you are holding the camera correctly) What you are experiencing is normal. Thank you for the excellent description
I can't tell the diff between VR and VR OFF with my Nikon 18-200 lens. Is there a foolproof way to tell if VR is functional?
Charles, I can save you the effort. The D200 lacks the menu item I suggested and will not show any symbols in the viewfinder or LCD to indicate which VR setting you have the lens set to.
But Ken Rockwell's guide to the lens has a big clue: VR takes a moment to stabilise, so you ideally need to half press the shutter release and wait a second or so before firing the shutter.
I don't want to plagiarise his excellent article, so instead suggest that you click here to read what the man has to say himself. He discusses the benefits of your lenses VR early in the article, but you may want to skip right down the page to the heading, "How to use the VR".
Ken has also created an excellent alternative D200 users' guide, click here.
Good luck, and please take a moment to rate my reply.
P.S. If the hotlinks don't work then the 18-200 lens review is at:-
http://www.kenrockwell.com/nikon/18200/18200-vr.htm
and the D200 guide is at:-
http://www.kenrockwell.com/nikon/d200/users-guide/d200-users-guide.pdf
Manual focusing on d5000
Most professional photographers use spot focussing...just the center dot. You focus on the subject...hold the shutter button half-way and recompose..press the rest of the way.
Lens works fine in manual focus on Nikon D5000 but won't autofocus.
The D5000 needs an AF-S lens to autofocus.
Nikon have not fitted the mechanical focus drive to the D5000.
55-200mm VR focus noise
The lenses have a focus motor built into them.when the camera is set to auto focus, once you press the shutter button, the motor activates to set the correct focus. VR is for motion stabilization. Turn off AF on lenses and camera and see if noise stops.
Top Nikon Cameras Experts
Steve
David Shaub
Are you a Nikon Camera Expert? Answer questions, earn points and help others
