Try this, it's gonna work! The insulation in the ribbon cable is poor. The conductors in the cable are crossed. The ribbon cable is actually two ribbons pressed together, and the conductors between the two cables are shorting or becomming crossed. Lift the two cables apart, place a piece of paper between them, fold the edges of the paper over the cable so that it does not slip out, and make sure to shove it all the way down to where it will meet the plastic display panel housing. There, problem solved.
Sometimes you can fix this by removing the ribbon connector where the key panel plugs into the control and cleaning the ends with a soft eraser on the end of a pencil, but most of the time, you will have to replace the key panel.
SOURCE: Double GE wall oven - F7 code
from repairclinic.com:
F7
A = Function
pad button stuck or
B = Bad clock
Unstick button
or
Replace Electronic Range Control (ERC)
It looks like you have a function button pad stuck or a bad clock.
Unstick button or replace electronic range control.
