Question about Pro Office Equipment & Supplies
How can do i Stylus Pro 4900 Printer to wifi?
Epson Stylus Pro 4900 with error code 1433. What does this mean?
Error 1433 means "IS Unit position sensor error".
unfortunately this issue is a major one and will need to be repaired by an Epson technician.
Sep 06, 2014 | Epson Stylus Pro UltraChrome HDR 4900 Ink...
EPSON STYLUS PRO 7600 Leaking ink One of my
sir the printer head of your printer is already thin... try to change the printer head...
Oct 21, 2013 | Epson Stylus Pro 7600 InkJet Printer
Maintenance request error code 4000 for Epson stylist pro 4900
HI,
MAINTENANCE REQ - 4000 - It detects twice in a row that all the nozzles are clogging.
Check the video to know how to clean the nozzle to get ride of error 4000
How to clear nozzle clog on your Epson wide format printer from PRO...
www.electro-medical.blogspot.com
Mar 04, 2013 | Epson Office Equipment & Supplies
Mac 0SX snow leopard 10.6.6 will not print also my local wifi system will not print, OS can not find /library/printers/lexmark/drivers/.resources/4900 series color 2.lut have reloaded driver from...
go to applications, utilities, and open terminal in the window, paste this: open /Library/Printers/Lexmark/Drivers/.Resources/ It will open the folder where the missing component should be. You will find the "4900 Series Color 1.lut" file. Duplicate it and change the name to 4900 Series Color 2.lut close the folder, and shoot a print, it should work.
Feb 07, 2011 | Lexmark X1290 All-in-one Inkjet Print...
Can't print to a Epson STYLUS SX510W from MacBook Pro OS 10.5 via wifi
First make sure the Wifi light on the printer is lit which will show if the printer is connected wirelessly to the router or not. If not then enter the Network settings on the printer and carry out a Wireless Lan set up using the wizard.If there is now a light Go to Apple Menu > system Preferences > print and fax, Delete the printer that is in the list and then select Add. Select Bonjour and wait for the printer to appear, highlight it and then add it.
Jan 13, 2010 | Epson Office Equipment & Supplies
29 people viewed this question
Top Pro Office Equipment & Supplies Experts
ray gallant
 Russ Hill
Russ Hill
Terry
Terry
Are you a Pro Office Equipment and Supply Expert? Answer questions, earn points and help others
