Question about Hardware & Accessories
Talento timer 111 have it on from 1am to 6am off peak but company Charging for shoulder usage during day time how can this happen? Thermoset not showing its on during this time. Ruth
Posted by Ruth Farrar on
3 Related Answers
Anonymous
SOURCE: I have a Grasslin talento 371 easy timer (digital)...
Try this link http://www.graesslin.de/cms/pdf/instruction_manuals/80.10.080 6.7_talento_371+372_(V97_1_2digixx)_ls1_xx.pdf
Posted on Sep 23, 2010
Anonymous
SOURCE: The hot water recirc pump in my new house was
1) Open link below so we are talking about same type of household system
http://waterheatertimer.org/Water-heater-recirculation-system.html
2) 15 minute interval is misleading.
Pins located on timer dial divide 24-hour day into 15 minute intervals.
You set timer pins and decide which 15 minute intervals you want ON-or-OFF. Do this by moving pins inward or outward with your thumb or ink pen. To check settings, manually rotate timer dial clockwise and listen for pump turning on-off..
Set timer pins for 4 consecutive 15 minute intervals, then timer runs for 1 hour.
After pins are set, then manually rotate dial to set current time.
Dial rotates as time passes, and pins click a lever that turns pump on-off.
3) 5-year Life span. Like all things plumbing, if you have hard water or sand-n-dirt in water lines, then pipes clog. And pumps clog.
Once motor begins to slow down, it overheats and burns out.
Water softener can keep sediment out of lines, but shortens life of water heater.
http://waterheatertimer.org/Clean-sediment-out-of-water-heater.html
4) Real question: do you need a circulation pump? Do you need hot water at your faucet? Can you schedule hot water use, or does recirculation pump have to run several hours per day?
Recirculation pumps causes water heater to run more, the pump consumes 25+ watts depending on pump, and water savings claims of 15,000 gallons per year are fabrication.
Realistic water savings is 700-2000 gallons per year, assuming several folks in the home use water sporadically across a full day, and each time water is used people are waiting for hot water. It also assumes that you never want cold water at the tap and that refrigeration ice maker line prefers hot water to cold.
5) Add a comment for more free help.
Also take advantage of fixya phone service.
For a price, fixya expert speaks with you over phone while you work on pump/timer or any do-it-yourself project.
We are always less expensive than a service call.
Posted on Jan 15, 2011
Anonymous
SOURCE: need an operation manual for
Talento 371 is single channel din-rail timer.
Following manual might work
http://waterheatertimer.org/pdf/Grasslin-Talento-371-372.pdf
They also make the mini-371
Posted on Aug 19, 2011
Heavy duty astro model 457864 how do I set the event timer
[PDF]24-HOUR TIMER AND AQUASTAT CONTROL ...
armstrongfluidtechnology.com/.../11_871_astro2_timer_and_aquastat_i-...
Jun 3, 2015 - 9.0 Timer programming with manual override switch 3. 1.0 Timer ...eration of the circulating pump during high peak usage periods in order to ... pm timesetting. 2.0 aquastat ... 2 Astro 2 Series circulator and 24-Hour Timer wiring diagram.... In the event of power outage, the timer must be adjusted for.
Oct 28, 2015 | Astro Systems Armstrong Astro 20B050S-TA...
Off peak hot water not heating!!! :(
The Economy 7 can control different types heater. Some heaters do not have off-peak ... but you can solve problem..
Copy following link:
http://waterheatertimer.org/pdf/QE7-INSTRUCTION.pdf
If timer is wired to two different elements, then the night rate element or off-peak element might be burned out. Test element with multimeter.
http://waterheatertimer.org/How-to-test-water-heater-element.html
Also this timer is wired so either Off-peak is getting power or Boost is getting power, but not both at same time.
If heater has off-peak element, then there will be a wire connected to terminal 5, going to heating unit.
If there is no wire on terminal 5, then there is no off-peak element, or wiring has not been connected. However you can change the timer function by moving wire on terminal 4 to terminal 5. Then only the off-peak timer function will operate, and not the boost.
You can also fool the timer, by setting time clock differently. Instead of setting timer for current time, rotate the dial and fudge current time by 10-12 hours so water heater thinks it's time for boost, but the actual time is during off-peak hours.
If terminals 4 and 5 both have wires, then either the element is burned out, or the timer has malfunctioned. Again, you can fool the timer by setting current time differently, and solve problem.
If you need further help, I’m available over the phone at https://www.6ya.com/expert/gene_9f0ef4df2f9897e7
Apr 26, 2013 | Water Heaters
Onesto timer switch pts20a programing details
PTS20a is 20 amp version of Onesto din-rail mount7-day digital timer:
http://www.onesto.cn/product_list.asp?id=386
If you're searching for product manual, then there is no product manual posted oct 2012.
If you own this timer, then describe the buttons, and I can locate same-similar timer based on that description.
Frankly the product looks very similar to Intermatic Talento 400, or Tork DIN rail series.
But usually, to avoid patent conflicts, the Chinese knock-off product will have one or more button that is different.
Even with small difference, the programming will follow similar pattern, since all these timers do the same basic job.
Copy following links to help identify possible manual.
http://waterheatertimer.org/Intermatic-timers-and-manuals.html#Talento-400
http://waterheatertimer.org/Tork-Digital-timers-and-manuals.html#DIN
Oct 04, 2012 | Hardware & Accessories
Timer that has a 20 minutes interval up to 1 hour
More information is needed.
For example, a) what voltage timer is needed, b) what Load are you controlling and c) how does timer mount?
Easiest solution is 60 minute repeat cycle timer.
Timer knobs are adjusted, or the timer dial rotates once per hour and 20 minute timing cycle repeats each hour. The cycle repeats 24-7-365.
If you want the cycle to operate certain hours of the day, another 24 hour timer can be installed in-line.
1) Tork 8600 cycle timer, or Tork ACT percent cycle timer
http://waterheatertimer.org/Tork-timers-and-manuals.html#8000
https://www.grainger.com/Grainger/cycle-timers/timers/electrical/ecatalog/N-8hbZ1z0q55s
-or-
2) Intermatic CT2000 percent cycle timer, C8800 cycle timer
http://waterheatertimer.org/pdf/025-Talento-121-cycle-timer.pdf
-or-
3) For din-rail mount, Intermatic Talento 121 cycle timer
http://waterheatertimer.org/Intermatic-timers-and-manuals.html#cycle
Add a comment
Oct 01, 2011 | Hardware & Accessories
Need an operation manual for Grasslin Talento 371 timer
Aug 18, 2011 | Hardware & Accessories
Verve Digital Water Timer as sold at B&Q have lost the operating instructions.
Verve water timers might be Melnor:
Open following link for manuals.
http://www.melnor.com/instructions.php
Links to other water timer manufactures and manuals are found on following link:
http://waterheatertimer.org/How-to-program-Gardena-C1060.html#manuals
Jun 14, 2011 | GARDENA Water Timer
The hot water recirc pump in my new house was equippped w/ this timer. There was no user manual, but it was set by the installer to run the pump during awake hours and shut it off during sleep hours. ...
Dec 18, 2010 | Taco 265-1 / 563-2 Combination Analog 24...
Usage Troubleshooting
A typical time schedule might be on at 5am (for showers starting a 6am), off a 7am (when everyone is off to work or school), on again a hour or so before the first people arrive home, and off before bedtime. There will be a reservoir of warm to hot water available all the time, even after the unit is off for hours, provided your tank is properly insulated.
Aug 27, 2008 | Intermatic FD60MH Energy Controls -...
Hardware & Accessories Logo
159 people viewed this question
Top Hardware & Accessories Experts
Tom Chichester
ray gallant
Are you a Hardware and Accessory Expert? Answer questions, earn points and help others
