Question about Blaupunkt Televison & Video
I connected Facebook on my 32" Blaupunkt HD Smart TV. I got interface going and inserted code then something went wrong, now I get blank screen with box with abcd enter. I cannot do anything but exit
Posted by Nila DERIASHNYJ on
5 Related Answers
Anonymous
SOURCE: LG LCD Flat screen 32 screen blank red light blinking cable on
The Lg lcd was srtruck by a remote and now looks like a small crak on the inside towards the bottom right hand corner and there is no picture but audio does work
Posted on Nov 09, 2008
Anonymous
SOURCE: screen flicker when watching 1080i
Component video has a max resolution of 720p. in order to use 1080i or p you have to use hdmi or dvi connections. That is why you get the flicker.
Posted on Jan 11, 2009
Anonymous
SOURCE: hookup wrong? I can't get the menu to come up for the VR375
New HD tv. Have digital cable box connected to tv., cable box connected to DVD recorder, but can't get setup menu to come up on tv screen. I had a similar problem. I have a HD tv connected to a digital cable box. I hooked up the DVD recorder with the wires it came with, but it would not play or give me the menu. However it was correctly hooked up. So the next day I connected a HDMI wire from the DVD recorder to the tv and everything works now.
Posted on May 26, 2009
pappapumpdaf
Bob Sloan
  • 635 Answers
SOURCE: For Atheros PCIE Ethernet Controller... check
You didn't list your PC model or make, but it appears that you have enabled the network card to boot from it's rom chip. Turn that option off in your software or pcie Bios control.
Posted on Mar 15, 2010
Anonymous
SOURCE: westinghouse 32 inch screen goes blank
Westinghouse LTV-32w1
replace capacitor c162 on power supply
power supply was a delta electric dps210ep-2c rev01
reheat any solder joints that don't look 100% as well .
such as c310 .
this is a known working fix . try before you buy a supply .
Posted on Apr 15, 2010
Trying to record on finlux smart TVs but it says no removable disk and initialisation failed . What do I need to do !
Finlux USB Recording Functionality - YouTube
? 1:40
https://www.youtube.com/watch?v=GKH-p6u0O8Y
Mar 26, 2014 - Uploaded by MyFinlux
Stay in control of your TV viewing thanks to our PVR functionality. You can pause live TV, or even record shows up to seven days in advance via USB. ... SEG 46" 46125 FullHD Smart TV Uydu Al?c?l? Kanal Ge?i?i ve Media Player ve ... Terms · Privacy · Policy & Safety · Send feedback · Try something new!
Finlux 32H6020-D 32 Inch LED HD Ready TV - Full Video ...
? 13:54
https://www.youtube.com/watch?v=pqfAs2kBKHM
May 10, 2013 - Uploaded by TheSuperUberGOLDFISH
Finlux 32H6020-D 32 Inch LED Widescreen HD Ready TV with Freeview & USB PVR Recording Black (New For ... Gadget Show Live 2013: Finlux 47inch LED Smart TV with 3D, £799 - Duration: 2:17. by ShinyShiny 12,627 views ... Terms · Privacy · Policy & Safety · Send feedback · Try something new!
Finlux Smart TV System 2013 Review ' AVForums
Jan 05, 2016 | Finlux Televison & Video
We have just got a finlux 32hme249s-t smart TV. We are trying to record but it keeps coming up with no remove disk is connected initialisation fail . Recording and playback functions are disabled .
PDF]32HME249S-T Instruction Manual - finlux finlux
https://finlux.co.uk/media/wysiwyg/Product.../32HME249S-T.pdf
Recording a Programme . .... We exclude ... Don't operate your TV in extreme ambient..... Access Module (CAM) and the viewing card by subscribing to Digiturk or D-Smart...... screen while starting a recording, try restarting the recording.
Finlux 32 Inch Smart LED TV HD Ready Freeview ... - eBay
www.ebay.co.uk/.../Finlux...Smart...TV...32HME249S-T-/4010197...
eBay
£199.99 - ‎In stock
Finlux 32 Inch Smart LED TV HD Ready Freeview HD (32HME249S-T) in Sound ... Download our Finlux Smart Centre App and take control of this Finlux TV via your ....Our Freeview HD PVR has a capacity of 500GB which will allow you record .... Weoperate a seven day no-quibble cancellation and returns policy for goods ...
Jan 05, 2016 | Video Cameras
I am not getting facebook on my smart tv blank screen in corner it says peer did not perform tls handshake?
Make sure you are connected to your wifi, if you have been connected in the past and are no longer or you changed your roughter you will need to re-setup your wifi on the TV
Oct 20, 2014 | Facebook Social Network
When I connect my hp laptop to my spectroniq hd tv the screen goes black on both devices and nothjing plays how can i get it to connect properly
I a feeling that your computers screen is blank because it is displaying to the TV and the TV is blank because it is on the wrong input. Your TV/remote should have an input or source button which you can use to select the appropriate input.
Mar 02, 2012 | LG 32LG30 32 in. LCD HDTV
While watching the TV the screen went blank and there wasn't any sound. I've checked all the cables. I tried turning it off and back on but when I did this the power light flashes 27 times before...
The tv power supply board it is shorted and dead.That the board where the tv power a/c cord plug into it.Tries websites like Shojimmy.com,Ebay.com to buy a whole new refurbish tv power supply board for the replacement.
Aug 28, 2011 | LG 32LC2R 32 in. HD-Ready LCD Television
The screen on my Vizio television went blank. The
if you was trying to wipe your tv off with glass cleaner are something that can make your tv go to a black pic
Sep 22, 2009 | Vizio L32 32 in. LCD HDTV
Picture goes blank but audio on
If you are using component cables to connect your HD box to TV. Make sure your connections are tight. You should make the colors match up. Green, Red, Blue. Check on both TV and HD box. Make sure HD pox is powered on. Make sure to select TV input to Component 1 or whichever you are using. If this doesn't work you may need to call and have COX refresh the HD box. This can be done over the phone. This will make sure you are receiving and sending the proper signal level. Good luck
Oct 05, 2008 | Vizio L30WGU 30 in. HD-Ready LCD...
Televison & Video Logo
32 people viewed this question
Top Blaupunkt Televison & Video Experts
Marvin
Marvin
Vernon Taylor
Andrew Taylor
Andrew Taylor
Are you a Blaupunkt Televison and Video Expert? Answer questions, earn points and help others
