Question about Homelite 'Yard Broom' Leaf Blower
How do I replace the fuel filter and the two fuel hoses on my Homelite leaf blower? The fuel filter is inside the fuel tank.
Anonymous
    Novelist:
  • 133 Answers
Take your Model number of your machine and the model, type, and code of your motor to your local small engine repair shop and have them get you your replacement filter and also pick up new gas line. When you replace your fuel lines do one at a time. All you have to do is pull a fuel line off, cut new line to length and re install. As to the filter in the tank, I usually take a coat hanger and fish it up to the top and then use needle nose pliers to grip it. Then just pull off the old filter and install new one.
good luck
Posted on Sep 01, 2009
Testimonial: "Thanks for your help with the solution on replacing the fuel filter on my Homelite leaf blower. You guys are "ACES"! KB2MKP"
eldee
  • 279 Answers
Is the filter loose or is one that goes through the tank? If it is loose, just empty the tank and reach in and get it. Take the filter and both the lines to Lowes, Home Depot or a hardware store and get exact replacements. Reinstall in the reverse order that you took them out. Good luck...Lee
Posted on Sep 03, 2009
On a homelite model 26 bv blower Does the gas tank filter connect to anything
The filter fits on the end of the fuel pickup line inside the gas tank. If you see the filter just rolling around in the tank it probably has hardened or damaged fuel lines. Size them up and get replacement lines online or at your local outdoor equipment retailer.
Oct 06, 2014 | Homelite Garden
Homelite leaf blower fuel tank pickup fell off
There should be something going into the tank, a plastic elbow or connector, that will connect the fuel line from the carb to the pick up in the tank. Generally what I do is remove what ever goes into the tank and get a piece of fuel line slightly bigger than the hole and insert the fuel line directly from the carb into the tank. You have to be sure the hose is really tight so to create an air tight seal. Pull the new hose out of the tank through the fuel fill and insert the new fuel filter, push the hose back in making sure it is on the bottom of the tank but has room to move around
If you need further help, I’m available over the phone at https://www.6ya.com/expert/kelly_69a0cf1b13789df1
Jan 22, 2013 | Homelite 308675004 Fuel Tank With Cap...
My homelite 26b is not getting gas into the primer bulb. It's only been used a few times...help
There are a few things to look for with this problem. First, open the fuel cap and look inside the gas tank. If the tank is more than half full, dump some out to assist you in seeing inside the tank. Look at the fuel line and filter. Make sure that hose is long enough to reach the bottom of the tank when tilted on its side. Make sure that there is a filter on the end of the hose also. Then follow the hose to the carburetor and the other hose from the carburetor to the primer. If they are all intact and no cracks, then the primer may be bad or there is a leak in the carburetor. It will have to be rebuilt.
Feb 15, 2011 | Homelite Garden
I have a Homelite "Vac Attack" leaf blower model
The fuel line is replaceable by itself, you don't need a new tank. Just make sure you get the same size line or it will leak where it goes into the tank. Any local small engine repair shop should have the line. There are two lines that go into the tank, the pickup line has the filter on it. It not only filters the gas but keeps the end of the line down in the fuel.
Nov 02, 2010 | Homelite Garden
I have a Homelite leaf blower that will start and run for a half tank og gas. However when the tank is half empty it stalls out and will not start. If I stop it fill the tank let it sit it will start
Sounds to me as though the fuel line that supplies the carburetor has been pulled out so that it is above the fuel when tank is 1/2 empty, or there is a crack/break in the fuel line inside the tank. Not a hard job to replace the fuel line, but takes patience. If your machine has 2 lines, only take 1 off at a time to avoid confusion as to which one goes where on the carburetor.
Dec 29, 2009 | Homelite 'Yard Broom' Leaf Blower
I need the fuel line size on Homelite gas blower. Is the fuel filter a washable/cleanable filter?
i think they are 1/8 in hoses on them and if it is a foam filter they are washable,mild soap and then a light coating of oil
Dec 24, 2009 | Homelite 'Yard Broom' Leaf Blower
Model bp250 leaf blower, cuts off on full throttle
Sounds like its starving for fuel.
Try fishing the filter out of the fuel tank with a piece of bent wire,
remove of hose and back flush with carby cleaner a few times reinstill and see if it works.
Dec 06, 2009 | Homelite 'Yard Broom' Leaf Blower
My Homelite backpack leaf blower runs until tank is 1/2 full
thats what it is try opening the gas lid look inside to see where the fuel line lies if its up high them try pushing it down to the bottom
Nov 13, 2009 | Homelite Consumer Products Backpack...
How to position the two little plastic hoses going from carburetor to fuel tank.for my homelite leaf blower and Vac, i need a caburator view
This is much easier than you think; the carburetor has two ports, one supply one return, the return port is the top port which allows excess fuel to be returned to the fuel tank when pressing the primer bulb. The bottom port is the intake that supplies fuel to the carburetor to be mixed with air and pushed into the cylinder for the combustion cycle. Both lines connect to the tank, the line with a cylindrical looking object is the supply line, that object is the fuel filter, so it would be connected to the bottom port of the carburetor. I hope that helps.
Oct 06, 2009 | Homelite 'Yard Broom' Leaf Blower
My homelite yardbroom 2 won't start. Maybe wrong gas/oil mix
Hi
If you remove the fuel you believe to be the mixture out of the fuel tank and refuel with the correct mixture then remove the air filter. Put a few drops of the correct mixture in to the intake it should start. it may take a few times of repetting putting the fuel in to the intake, but eventually it will clean out the bad fuel and run good.Remember to replace the air filter!
Apr 24, 2009 | Homelite 'Yard Broom' Leaf Blower
Homelite 'Yard Broom' Leaf Blower Logo
836 people viewed this question
Top Homelite Garden Experts
bryan st
Randy Schumann
Randy Schumann
colesmowers
Are you a Homelite Garden Expert? Answer questions, earn points and help others
