Question about Desa International White Wireless Plug In Door Chime
Wireless doorbell rings by itself
I have an SL-6151-RX-A wireless door chime using codes 5,6,7 and it sometimes rings by itself. How can I change the code?
James Colynuck
  • 40 Answers
Doorbell button is sticking or slightly pressed in. Check to see if cover is installed correctly. It may be on on one side.
Posted on Aug 31, 2009
Steven R
    Filmmaker:
    Uploaded 5 video answers.
  • 100 Answers
If its not that the button stck, it may be a neighbor has a similar unit. You can alter the code to be unique. Open up both the button and the main unit and switch the codes using the pins & connecotr covers. It done on a row of pin sets - Default is usually connectors on 5-6-7 (8 on the main bell unit causes the dingdong to change to a Westminster chime).
With a pair of needle nose pliers pull the connector and set them on different numbers than they were (but your units must match exactly). You must do this on both your main unit and button pieces, When you have a unique code its no longer an issue with the neighbors.
If you need further help, I’m available over the phone at https://www.6ya.com/expert/steven_7f54ab9063554f66
Posted on Jan 20, 2012
ricky singh
    New Friend:
I just opened both the button and the bell and changed the jumpers to different configuration on both. That fixed my issue.
Posted on Mar 28, 2012
  • ricky singh Mar 28, 2012
WIRELESS DOOR BELL BUTTON SL-1695-rx
Heath/Zenith SL-6166-C Wireless Plug-In Door Chime Kit ...
www.amazon.com > ... > Door Chimes & Bells > Kits
Amazon.com, Inc.Heath Zenith SL-6198-B Wireless Doorbell Replacement Battery. Total price: ... Plug-in doorbell chime, doorbell button/transmitter with battery, hardware pack ...
Oct 16, 2015 | Home Security
Phantom bell rings on Siemens wirreless door bell chime jsjs-204, I do not have instructions
You may need to change the frequency of the chime. In this model, you need to remove the batteries from the receiver unit and wait for a while. Then replace the batteries. The doorbell unit should automatically set itself to a different frequency once you press the button, which will(hopefully) solve the problem.
It seems impossible to find the instruction manual for the doorbell. But see http://oddsnsods.net/blog/?p=68 who had a similar problem with a different Siemens model, which works on the same principles. (I can't seem to be able to remove the battery from the door bell unit on the jsjs204, but it reset itself after changing the batteries in the receiver).
Nov 01, 2011 | Desa International White Wireless Plug In...
JUMPER SETTINGS FOR SL-6151-RX-A
I just solved a similar problem with mine. I found a PDF of the instructions for changing the frequency and the tone: http://heath-zenith.hcents.com/data/manuals/598-1034-02.pdf
May 14, 2010 | Desa International White Wireless Plug In...
Hello I have now got 2 (two) of these units over the past 8 months and neither work----changed batteries--interchanged push button---changed main unit--nothing works----but when my neigbour across road has...
The doorbell buttons and your receiver must be on the same channel. If you will get out the directions that came with your unit, they will describe the process to go through to reset the specific "codes" for your buttons and receiver.
Jan 04, 2010 | Desa International White Wireless Plug In...
I have a wireless SL-6151-RX-A door chime and it does not ring
Check that the dipswitches on the button and the reciever doorbell unit match. Also verify that your battery is not installed the wrong way.
Nov 15, 2009 | Desa International White Wireless Plug In...
SL-6195-RX seems three houses have the same
Open up both the button and the main unit and switch the codes with the pins. It done on a row of pin sets - Default is usually connectors on 5-6-7 (8 is on the main bell unit and causes the ding-**** to change to a Westminster chime).
With a pair of needle nose pliers pull the connector and set them on different numbers. You must do this on both pieces, When you have a unique code its no longer an issue with the neighbors.
Aug 02, 2009 | Desa International White Wireless Plug In...
Desa International White Wireless Plug In Door Chime Logo
5,225 people viewed this question
Top Desa International Home Security Experts
Eric Kalman
Eric Kalman
Level 1 Expert
Mike
Tom Chichester
Are you a Desa International Home Security Expert? Answer questions, earn points and help others
