Question about RCA RCR815 Remote Control
How reprogram my universal rca remote control
I am trying to reprogram my rca remote back to my tv how do i do this
Posted by lanthorn21 on
Anonymous
Hold the tv button down and keep it down and then press and hold the power button down and hold them both until the power button stays red then let go of both buttons then keep pressing the power button until the tv turns off and as soon as it turns off press the stop button and it should work.
Posted on Sep 30, 2009
1 Related Answer
SOURCE: need code to reprogram to
You already try with 000
Posted on Apr 24, 2008
Universal remote for RCA tv channel 1
Something missing here. There is no channel 1 on a TV set. None of the universal remote instructions I have or have seen specify that as a first step. From your post, I believe you want to use some kind of universal remote to control an RCA flat panel TV, Can you tell me the brand of universal remote you are trying to use? The answer to the last line of your post is you don't need the original remote to "reprogram". That's what universal remotes do
Jan 04, 2013 | RCA Televison & Video
I have an RCA tv model # f27159wn, we had a universal remote to turn it on because the power button is missing. Our son lost the remote, when we found the remote it doesnt turn the tv on now. How do I...
RCA tv codes from the original RCA 3-in-1 universal remote.000,181,100,233,203,212,098,005,003 004,006.One of these codes program for the RCA universal remote will work.Sorry but to find the tv wright codes for the tv to work.The tv must be power on and working to find the tv wright codes to program in to turn the tv off to get the tv wright codes.Try website like Rmotes.com to buy the tv original remote,will not require tv on to used the tv original remote.
May 03, 2011 | RCA 4-in-1 Universal Remote Control
Antenna button not functioning on RCA300x universal remote
U have glitches in the reprograming back and forth.Take the battery out,about an hour.Reprograms the codes again,should work again.Don't reprograms the codes back and forth to many times or one times to many will kill the remote for good.U have 2 tvs,U should have 2 tvs remotes.
Jun 22, 2010 | RCA RCU300 Remote Control
RCA 3 device universal remote.
you'll need the manual
you can try http://www.wikiremotes.com for troubleshooting. They have codes manuals and support for all universal remote controls
Sep 20, 2008 | RCA 3-Device Universal Remote with...
Try it without a code. Turn your tv off. Press tv then press the on.off button and tv button at the same time. When it lights up, press play every five seconds until the tv powers off. Next press the reverse button every few seconds (sometimes takes a while), until it powers back on. When it powers back on hit the stop button to save the code.
Sep 08, 2008 | RCA Universal Remote Control
Need code to reprogram to an RCA tv
What is the name, model # of the universal r/c, and the model of RCA t.v.?
Please, do not be offended when I correct you.You cannot "reprogram the RCA t.v." because only the r/c[remote control] can be reprogramed.
Apr 12, 2008 | RCA Universal Remote Control
VCR stuck on menu screen
Thank you. I did fix the problem. Reviewed the instruction manual for the Samsung VCR and removed the SAFE reading on the VCR by just holding down the TV-VCR button on the RCA universal remote for several seconds which then released the frozen menu screen. From there I was able to reprogram the TV using the instructions and codes for the RCA universal remote. I still have to reprogram the VCR.
Mar 09, 2008 | RCA Universal Remote Control
RCA RCR815 Remote Control Logo
2,267 people viewed this question
Top RCA Televison & Video Experts
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
