Question about Hitachi Televison & Video
55 inch hitachi plazma won't come on blue light keeps blinking
Possible bad transformer board
Posted by Darlene Murray on
5 Related Answers
premtech
William Rayburn
  • 934 Answers
SOURCE: hitachi lcd about 2004
Power supply.
Posted on Mar 29, 2008
Anonymous
SOURCE: My Mitsubishi tv power light keeps blinking
have a 55 inch Mitsubishi TV.. the green power light keeps blinking.. is there anything I can do myself?.. or I have to have someone to get it fix?
Posted on Nov 29, 2009
ladywinn
ladywinn
  • 5138 Answers
SOURCE: the temp and lamp light start blinking when i turn
CK the Lamp Fan to see if it is running ,If you are still running the orignal Lamp then replace it . Mats has them for $99.00
1-800-628-1118
Posted on Jul 10, 2010
Norman Worley
  • 1273 Answers
SOURCE: have a 55 inch hitachi plasma tv. The picture
Seems as if your high voltage power supply went kaput. This happens sometimes see the complaint
at: http://hitachi-home-electronics.pissedconsumer.com/hitachi-55hds69-plasma-tv-20100417178696.html
See: http://www.partstore.com/Model/Hitachi+Ltd/Hitachi/55HDS69.aspx for a list of parts and you can see if it is worth fixing
Posted on Dec 01, 2010
romeo_5_5_0
SOURCE: My 50 inch Hitachi plasma 1080 tv has a blinking
my hatachi hd/1080 tv has a solid blue light on and it wont turn on i push the reset button on the bottom right and it still wont turn on
Posted on Feb 08, 2011
Hitachi 55" plasma: No picture, no sound
Perhaps the seller forgot to mention the basic power supply problems and who knows what else
Jun 12, 2013 | Hitachi 55HDS69 55 in. Plasma Television
My hitachi p50s601 turns on for 1 second and then goes completely blank and the blue light flashes 3 times repeatedly.what do i do?
3 Blinks means one of the buffer boards is bad. The way to test it is to unhooking one SDR board at a time, and see if half of your screen comes on properly. If the SDR-D board is bad the bottom half of the screen won't come on when you remove the board. Send it out for repair (less expensive then buying a replacement board) or search for a refurbished board. If your non technical provide this info to a service tech and ask for an estimate. Cost will be moderate. Hope this helps you. Jon
Oct 25, 2011 | Hitachi Ultravision P50S601 50 in. Plasma...
MY 50 inch Hitachi TV wont turn on and the on/off blue light at the bottom of the TV blinks 3 times then pauses and blinks another 3 times. This is non stop. The TV model # is P505601
Unfortunately, this indicates a technical fault with the TV which can only be fixed by a service engineer.
If the light is blue and blinks 3 times, it is indicating a fault with one (or both) of 2 circuit boards inside. They are the XSUS or YSUS boards and will possibly need replacing.
At least knowing this might help you ascertain a quote as too how much the repair will cost.
Jun 09, 2011 | Hitachi P50S602 50 in. Plasma TV
Tv wont turn on but acts like it is
either a relay or power supply or high voltage transformer is bad. You can test any of these with an ohmmeter and a voltmeter or better yet a multi-meter. Then if low or no resistance, it is bad.
Oct 14, 2009 | Hitachi 55VS69 55" Projection HDTV
I have the same problem blue power light blinks 3 times
Ur power board inverter is dead.
U need a new board.
Jul 17, 2009 | Hitachi P50H401 50 in. Plasma HDTV
55HT79 HITACHI BLUE POWER LIGHT BLINKS ON AND OFF.
I can't help you because after 26 months of ownership mine is doing the same thing (started on 7-12-09). Judging by the number of people with the same complaint I believe Hitachi knows that they have bad boards but refuses to replace them for customers unless they are within warranty. It also explains why the merchant that sold it to me in 2007 stopped offering Hitachi in 2008.
I'm disgusted because I'm anticipating a $300-$500 repair bill simply because Hitachi's design did not provide an external way of resetting it. Impossible to get to the menu to do a reset within 12 seconds before it starts the powering on booting cycle again.
Adding salt to the injury, mine is wall mounted and repair people will only work on it if it is readily accessilble when they walk in the door or if it is brought to the shop. Know what a 55" plasma TV weighs? Too much.
Jul 09, 2009 | Hitachi 55HDT79 55 in. Plasma HDTV
Powers up but picture doesn't appear.
Most likely the TV has a power supply related problem. It's possible that it maybe a bad capacitor or transformer on the power supply board. The most common thing to go out is the circuit board that supply power to the screen. Commonly called a Backlight Inverter Board.
But, I can't say it's 100% the problem because I can't actually look at the tv over the internet.
If by chance the TV is still under warranty, go that route.
If not under warranty and If you have some electronic experience, if you can find and purchase a Service Manual over the internet; It will help you diagnose the source of the problem and fix it by soldering in the new part. The Service Manual will give you circuit diagrams, test points, and part# lists. Usually, cost under $20. And most cases the new part cost less than $15.
I hope I shed some light on the subject for you.
Jul 08, 2009 | Hitachi Televison & Video
Vertical red line on 55 hitachi plazma
The vertical line, in my case, was due to a bad contact on the flexible printed circuit. I fixed the problem by using a piece of a rubber eraser to apply downward pressure on the flexible circuit as shown in the picture. To locate the faulty section lightly push on the flexible circuit from lef to right untill the line dissapears.
Nov 28, 2007 | Hitachi 55HDM71 55 in. HD-Ready Plasma...
Televison & Video Logo
50 people viewed this question
Top Hitachi Televison & Video Experts
matt martin
matt martin
Todd Hill
Todd Hill
Are you a Hitachi Televison and Video Expert? Answer questions, earn points and help others
