Question about Goldstar DH5010B Dehumidifier
Same with me
My dehumidifier is icing up at the coils
Posted by catena on
D. Floyd Kolb
  • Goldstar Master
  • 43,501 Answers
DehumidifiersSame with me - 2_bing.gif freezing up can be causes by a few different problems.
Here is a tip that I wrote to help people with the freezing dehumidifier problem....
Dehumidifier is Freezing up and not working
http://www.fixya.com/support/r4662033-dehumidifier_freezing_up_not_working
heatman101
Posted on Jul 13, 2010
Why does Frigidaire dehumidifier LAD704DUL has ice on the coils?
Hello Friend, thank you for your question!
I see that you have frost accumulating on the coils of your Frigidaire dehumidifier, LAD704DUL. Typically frost appears on coils either because your dehumidifier has been turned on recently or the room temperature is too low. Sometimes this is normal due to refrigerant rushing through the coils and usually it disappears within 60 minutes. However, if your dehumidifier is not removing moisture, then at this point your dehumidifier may possibly been experiencing a sealed system issue. Is your appliance still in warranty? If so, you might want to reach out directly to the manufacturer to determine the coverage on your dehumidifier and the procedures to any potential remedy in that regard. Hope this helps! - Z
May 15, 2014 | Frigidaire Dehumidifiers
I have a danby ddr586r dehumidifier. the coils are icing up. the outside of the unit also has ice build-up on the left hand side.
Here is a tip that I wrote that will help you understand why and what you cando with a dehumidifier that ices up.
heatman101
May 30, 2011 | Danby DDR586R Dehumidifier
My dehumidifier ices up. It will not remove moisture when it ices up. What can I do and is it under warranty?
The coils you see on the back of your dehumidifier are the evaporator. When the unit runs, the coils get very cold. As the fan draws the room air over the coils, the humidity in the air condenses out of the air onto the cold coils. But, if the temperature of the air the fan draws over the coils is too cool, the humidity that condenses out of the air freezes on the coils. To remedy this problem, you can try any of these: Warm up the room the dehumidifier is in. Put the dehumidifier on a sturdy table (the room air is coolest near the ground). Turn the unit off until the room warms up.
Take care.
Aug 10, 2010 | Fedders A7DH45B2A Dehumidifier
Icing on Coil
Unit has a leak...
heatman101
Jul 08, 2010 | LG Goldstar 30-Pint Dehumidifier
Ice on dehumidifier coils
most likley low on freeon gets colder when it leaks out stat could be not working correctly
May 10, 2009 | Frigidaire FDL50R1 Dehumidifier
Icing on back of dehumidifier
heatman101
Mar 25, 2009 | Goldstar DH3010B Dehumidifier
Dehumidifier icecing up
Three possibilities for coils icing up.
1. Low ambient temperature in the area where dehumidifier is located. If so, shut down and de-ice it. Then move the unit to a different - (warmer) - location and start it up.
2. Heating element - (which cycles periodically to liquify frost on the coils and allow water to drain) - is malfunctioning.
3. Low refrigerant level in the unit.
Sep 25, 2008 | Eva-Dry EDV300 Dehumidifier
Goldstar DH5010B Dehumidifier Logo
183 people viewed this question
Top Goldstar Dehumidifiers Experts
Sheldon Dedek
Tim Venetis
Tom Chichester
Are you a Goldstar Dehumidifier Expert? Answer questions, earn points and help others
