Question about Sony Televison & Video
Sony xbr-49x900f tv has sound but no picture after a min or shorter
Hi, When I turned on my Sony XBR-49X900F TV, sound and picture were on but screen turned black after a min or so, I could still hear the sound. I powered the TV off and on again, same thing that no picture after a min (some times less than a min) sound still on. Any suggest on how to fix it?
Nasir Muhammad
    Champion:
  • Sony Expert
  • 229 Answers
Hello
in this case ld board is defective please replace ld board .
thanks
M Nasir
Posted on May 14, 2020
5 Related Answers
Anonymous
  • 6 Answers
SOURCE: SONY 36 XBR SOUND BUT NO PICTURE
posible solution is adjust the screen to low.also check the trimer if it is working.check the resistor in the heater line...weng
Posted on Dec 29, 2007
Anonymous
SOURCE: SONY XBR 60" STANDBY
Check the door for the lamp...over time mine distorted from the heat, and this was an error code for the door now being closed. Temporarilty I wegeded something in there to hold the switch closed, but ended up replacing the door.
Posted on Mar 14, 2008
Cybertech
Jose Zetino
  • 149 Answers
SOURCE: Sony Videoscope XBR TV
just need to balance the three colors red,green and blue that may help remove the front covers and look for black module that have sccree and focus controls just move a little bet left or right be carefull because you can loos the picture e-mail me for more info
Posted on Apr 08, 2008
Anonymous
SOURCE: my sony xbr 60 picture turns off and on
No solution for you...but I have the same problem. I also had the green blob problem which sony fixed earlier this year. It happens on an intermittent basis. Screen goes off, standby light blinks green, then comes back on. Its off for maybe 1-2 min.
Posted on Nov 27, 2009
Lee
  • 393 Answers
SOURCE: sony 32" xbr trinitron trusurround T V picture is black
Most likely on a trinitron tube if it is dark is the high voltage capacitor has blown. This is the device that feed the 30,000 or so volts to charge the tube, it attaches at the back with a clip and ****** and a single cable coming from it.
You can check easily if it is definately that as you will notice if you power the tv on and off once or twice if you get that static charge feel from the screen, if there is none there then almost certainly that is the problem.
Posted on Mar 10, 2010
My sony trinitron xbr won't come on when the remote iis pressed it only clicks.. no picture or sound
Your problem could be any one of the boards in the set. When a flat screen attemps to turn on, but finds an internal problem, it defaults by clicking off to keep the remaining circuits and boards from buring up. You'le have to take the tv to a shop. Sorry that I can't be of more assistance.
"Original Radio Man"
Ed
Feb 13, 2013 | Televison & Video
Sony XBR 40" tube tv.
Failure of the vertical deflection module/circuit. The tv will have to be opened, the vertical deflection circuit found and replaced.
Definitely a job for a pro - the circuit is going to be extremely difficult to extract. The repair will cost you about $200: $20 for a new circuit and $90 per hour for the 2 hour job.
Sep 03, 2011 | Sony BRAVIA KDL-40S2000 40 in. LCD HDTV
MY sony trinitron XBR TV does not stay on.
what's wrong with my Sony trinitron XBR tv's timer
Apr 27, 2010 | Sony FD Trinitron WEGA KV-32FS120 32" TV
Sony Trinitron XBR TV, picture-in-picture got
A solution I found for our KV-32XBR200 was to press Setup on top of the set, then select the "Demo" item with TV/Video. The text overlay apparently banished PIP. Verified this twice, as I'm at this page because our remote can only turn PIP on :-).
Dec 24, 2009 | Sony Televison & Video
Sony xbr 27"
you do have a deffective crt
Jul 30, 2009 | Sony FD Trinitron WEGA KV-36XBR800 36" TV
TV has sound no picture, Sony Videoscope xbr
Please post both the exact model number (on the back) and the blink count. The standby light should be blinking a repeated pattern. That info will indicate the problem circuit and allow us to provide you with the proper parts/steps to resolve this.
Thanks,
Dan
Feb 10, 2009 | Sony KP-53XBR45 53" Rear Projection...
Sony Qualia and Sony XBR 4 TV
wow. mostly all new set from the last few years have a dual tuners
NTSC and ATSC and that would depend if or which set will get the better signal. Also remember that off air is analog and the sets are now design for digital.
Feb 09, 2008 | Sony QUALIA 005 46 in. LCD Television
Sony 57 Inch XBR 2001
I don't have the XBR, but on my sony, using the cable box remote, I had to go into menu/display/etc. and mark the 1080i, 720p, and 480i settings. you usually get a "if you can see this" comment if your tv accepts the settings. for standard tv i set the screen to normal, and when the upper channels go to HD, they auto go to full screen. Sounds like you are using the component cable, and also make sure you are on the video port of remote, and the the TV input. The above worked for mine. Hope it helps.
Dec 04, 2007 | Sony KP-57XBR10 57" Rear Projection...
Oct 30, 2007 | Sony FD Trinitron WEGA KV-20FS120 20" TV
Televison & Video Logo
71 people viewed this question
Top Sony Televison & Video Experts
Muntejaya Ginting
Muntejaya Ginting
Nasir Muhammad
Nasir Muhammad
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
