Question about Sony Handycam DCR-HC42E Mini DV Digital Camcorder
Where can get the sony handycam DCR-HC42 device drivers support Windows vista
Mitesh Kr Anand
  • Sony Master
  • 497 Answers
If you want to use the USB cable to connect the Camera to the Computer to transfer the video to the Computer then:
This Camcorder does not support USB streaming with the VISTA Operating System. Use an i.LINK cable to transfer the video to the Computer. The i.LINK port is also called IEEE 1394 or Firewire port. (An i.LINK is a black D shaped connector with 4 or 6 pins. The type of cable to be used will depend on the i.LINK port of your Computer. The Sony Camcorder will have the 4 pin i.LINK cable and if the computer has the 6 pin i.LINK port, then you may have to use the 4 pin to 6 pin i.LINK Cable).
You can use any video capturing software like Windows Movie Maker to transfer the video from the Computer.
Refer this link for the instruction to transfer the video to the Computer using i.LINK cable.
http://www.kb.sony.com/selfservice/documentLink.do?externalId=C111893
NOTE: As the Camcorder does not support USB streaming with Vista, it is not required to use any Sony Device Driver to transfer the video to the Computer. You do not require any Drivers or Software from Sony to transfer the video from the Camcorder to the Computer using the i.LINK/Firewire interface.
Posted on Sep 01, 2009
Testimonial: "Thanks for your responce. I will check with using i.link cable. "
Need driver for Sony dvr hc42- using windows 7 on a dell 32bit
Greetings - you can get the needed drivers, manuals, etc at the Sony support website.
Click on HERE to get the files you need.
Good Luck and have fun.
Mikeywaf
May 19, 2011 | Sony Handycam DCR-HC42 Mini DV Digital...
Need driver for dcr-hc42
You can get the drivers on the link below. Select your operating system.
http://esupport.sony.com/US/perl/swu-list.pl?mdl=DCRHC42
Jan 24, 2011 | Sony Handycam DCR-HC42 Mini DV Digital...
Windows 7 64 bit and sony dcr-hc42
Maybe, It doesn't work because the driver you installed. It is for other versions of operating system. I am also using windows 7 like you.Dont worry, You can still use your installer/driver from other versions of operating systems. Before you installing any program/driver in a windows 7 Operating System Computer, Use "troubleshoot compatibility". Right Click the Icon of your program installer first, then choose "troubleshoot compatiblity". This will allow you to choose on what type operating system your program will run. Just reply back if it still doesn't work.:Djulyallan01_6.jpg
Nov 05, 2010 | Sony Handycam DCR-HC42 Mini DV Digital...
My software does not work in windows xp for my sony handycam dcr-trv19 is there any free software for editing
+Hello there, well if you got windows XP/Vista etc you can see good editing software at www.bargainshopping.org.uk and I use myself Videowave, get that from PC World shops around £39.99
Jun 25, 2010 | Sony Handycam DCR-HC42 Mini DV Digital...
I'm looking for driver for sony dcra-121 free download
Hi, what Windows have you got on PC? no drivers made for Win Vista or Win 7.
Jun 15, 2010 | Sony Handycam DCR-HC42 Mini DV Digital...
Sony Handycam DCR-HC42 Mini DV not recognized by Windows 7
win vista and win 7doesn't support usb streaming. the usb driver for this model would not be compatible with your computer's OS. although, you were able to download PMB still this wouldn't work, it's basically an alternative software that you can use with the newer OS. still the device driver would not be installed. and you would get a message that "ilink connection is not detected". the reason you get that is bec the camcorder and the software is intended for use with the dv (ilink or ieee1394) connection. so if your computer has an ieee1394 card and you have a compatible ilink cable,then your good to go,it should be a plug-and-play connection (no drivers required). all you need then would be a video capturing software (like win moviemaker) to transfer videos from tape to PC. hope this helps. thanks :)
Mar 28, 2010 | Sony Handycam DCR-HC42 Mini DV Digital...
Sony digital handycam dcr-trv33: how to transfer video to computer
first you need a driver for your camcorder to recognize the device what you plug. use USB for pluging it. upload your videos to any movie maker application such as ulead movie maker, nero movie maker, windows movie maker, etc.. save it with any various types of videos like avi, divx, vcd, dvd, etc.. and now its on your computer. heres the link and other instructions of installations. hope that helps!
http://www.sony-asia.com/support/download/1656/product/dcr-hc42/modelfirst?site=hp_en_AP_i&subpage=detail
just click the download bar
CHARCOIS
Aug 26, 2008 | Sony Handycam DCR-HC30 Mini DV Digital...
Open Questions:
Sony Handycam DCR-HC42E Mini DV Digital Camcorder Logo
849 people viewed this question
Top Sony Video Cameras Experts
Muntejaya Ginting
Muntejaya Ginting
Larry Stiles
Larry Stiles
Al Rush
Are you a Sony Video Camera Expert? Answer questions, earn points and help others
