Question about Plantronics Explorer 220 Bluetooth Headset Wireless Headset
I need help connecting my CODi Bluetooth keyboard case for iPad
It won't connect and I can't find the manual for it
Posted by Lauren Bernstein on
5 Related Answers
barbaracarth
SOURCE: Cannot connect my Bluetooth keyboard
Try this
http://www.tuaw.com/2010/04/05/found-footage-how-to-connect-an-ipad-to-your-existing-wireless/
Posted on Jan 10, 2011
HDI Headsets
Headsets Direct
  • 537 Answers
SOURCE: connecting bluetooth plantronics 330 headset to nokia cell phone
Here is a link to an Explorer 320 User's Guide, that will help you with your connecting to the phone. The instructions for pairing would be the same for the 320.
Plantronics Explorer 320 User's Guide
Good luck from Headsets Direct!
Posted on Oct 21, 2011
Lance
  • 118 Answers
SOURCE: can't connect my Belkin F5D7234-4 v4 to my ipad
This link is for Iphone repair, It solved some of my Ipad problems. Hope it works out for you
Posted on Jan 01, 2012
William Alequin
  • 931 Answers
SOURCE: I forgot how to connect my DG Bluetooth Keyboard Case to my iPad. Can you help please?
It should be just like pairing an audio Bluetooth device. Turn the iPad's Bluetooth on and the keyboard as well, the iPad will look for an available device, it should pop up in the iPad, tap it to pair, if its ask for a pairing number, it should be noted in the box that came with the keyboard or in the instructions, that should be it.
Posted on Mar 10, 2015
ray gallant
  • 68282 Answers
SOURCE: Keyboard will not connect to iPad Bluetooth, first time using?
reread the instructions . then return it to place of purchase , should have warranty .
Posted on Nov 03, 2015
Ds won't connect to wifi nintendo24 won't for the wii won't connect to the wifi
you need to get wifi at your house before you can use the wifi on the ds
Mar 24, 2013 | Video Game Consoles & Games
1983 vt500 shadow. I connected the battery backwards and now the dash lights wont light up
Hi, Hikinbender for this scenario you will need your service, parts fiche, and owners manual if you can't find the best tool you ever bought for your Honda, despair not, for a mere zero $0 you can download another one. For more information about your issue and valuable "FREE" downloads that you will need please click on the blue links below. Good luck and have a wonderful day.
Installed battery the WRONG way now bike won start
Connected the Battery Up Backwards and Now It Won Start
http://www.cycleterminal.com/Service-Manuals/Honda-VT500C-Shadow-Service-Manual-English.pdf
http://www.partsfish.com/page/oem-parts-for-honda
http://mybikemanuals.com/honda/honda-vt-owners-manuals
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/gregg_c0ec1df182c7330e
Sep 08, 2012 | 1984 Honda VT 500 C Shadow
1978 bmw r80/7 won't start, can remove spark plugs and hit with gas, fires up but won't stay running unless at 3000rmp
Hi, Anonymous and the usual suspects are:
1. Fuel tank empty.
2. Fuel supply valve/petcock turned off.
3. Fouled spark plugs.
4. Engine flooded as a result of overuse of the enricher.
5. Vacuum hose to the fuel supply valve/petcock disconnected, broken, cracked, or pinched.
6. Fuel valve/petcock or filter clogged.
7. Discharged battery, check battery terminals for damage or corrosion, check the battery cables at "BOTH" ends for loose, corroded, or broken connectors, "INSIDE" and outside the cable harness, perform connector wiggle test and check cables with an ohmmeter if necessary.
8. Loose or corroded wire connection at the coil, battery or plug between ignition sensor and module.
9. Spark plug cables in bad condition and shorting, cable connections loose, or connected to the wrong cylinders.
10. Ignition timing incorrect due to a faulty ignition coil, ignition module or sensors (MAP, CMP, CKP, O2 and/or BAS).
11. Security alarm needs a reset.
For more information about your issue, please visit the websites below. Good luck and have a nice day.
http://forums.bmwmoa.org/showthread.php?21018-R80-Won-t-start-Help-me-budda
BMW Airhead motorcycle starting and running problems starter motor bendix...
http://www.lamaneta.org/manuales/manuales/BMW%20R80GS-R100R%20Manual%20de%20Taller%20ingles%205555.pdf BMW Motorcycle Parts Fiche OEM BMW Motorcycle Parts online 1970 present BMW
http://www.bmw-motorrad.com/us/en/index.html?content=http://www.bmw-motorrad.com/us/en/services/manuals/manuals_main.html¬rack=1
Jul 11, 2012 | BMW R 80 Motorcycles
Why won't my galaxy Rugby GT-S5690 automatically connect to my bluetooth
Usualy, it should, But vith bluetoooth, there are so many mysteries. Try with another phone.
Dec 01, 2017 | Cell Phones
Plantronics Explorer 220 Bluetooth Headset Wireless Headset Logo
637 people viewed this question
Top Plantronics Radio Communications Experts
Anthony Ward
Anthony Ward
Ekse
 Grubhead
Grubhead
Are you a Plantronics Radio Communication Expert? Answer questions, earn points and help others
