SOURCE: candy cpca291ffk fridge freezer
This is due to the failure of the thermostat device..hence its not controlling the temperature..If you are good at electrical appliance repair i can tell u how to fix it...Otherwise i advice you give it for servicing...Let me know what you have choosen..
SOURCE: fridge freezer
Check your settings for the temperature controls. Freezer may be set to warm (IE #1) set it mid point. Also set the refrigerator at mid point and go from there to adjust each to maintain the temperature balances.
SOURCE: frosting & water dripping from freezer in Frost free freezer
Hi, You will find that your problem relates to the defrost heater in the freezer. You will need to take the drawers out and remove the back panel to access the evaporator. There is a foil heater that lays underneath the evaporator and it will need to be changed. Along with the klixon that controls it. This will ensure that both parts are good. Your problem will then be fixed no more water!
Good luck................
SOURCE: Siemens fridge freezer keeps sounding the alarm but freezing up
yeah and that is never a problem
