Is just flashing and the carriage is not moving at all
Try Code "L" this will take you out of the Language Mode.
DickyO
SOURCE: IBM Wheelwriter 5 nonresponsive, line spacing lights flashing
A lot of possibilities Which lights, beeps, how many? Check for debris in and around the printwheel, look for any obstructions under the carrier, put a few drops of oil on the silver shaft the carrier ride on.
Good Luck
DickyO
SOURCE: IBM Wheelwriter 5. Beeps once when turned on,
Try reinserting the printwheel, check for debris in the printwheel area.
DickyO
SOURCE: IBM Selectric Typing carriage doesn't stop moving. Stuck key?
Check your margins to see if they are set right against each other
SOURCE: IBM Lexmark typewriter carriage return won't return to left position
Hi:
Open the top cover and locate the shiny rod that the carrier moves back and forth across. Use some WD-40 on a rag to clean it well the apply a light coating of it to the entire shaft.
Hi abubakar sadiq adamu, I want to help you with your question, but I need more information from you. Please call Customer Service For Help & Support Call 1 8O5*465*751O Toll Free 24x7
