SOURCE: Craftman weedacker
HI,
You need a long narrow 20T tork wrench to remove the clutch bell.Most stores that sell tools should have them. You stick the wrench down
the opening of the clutch bell (where the shaft normally goes), hold
the flywheel so it doesn't turn (a screwdriver will work) and then
unscrew the screw that holds the clutch bell on.
SOURCE: Whirlpool Duet GHW9400PWO: Replacement of the rear counter weight
This is a simple repair. All that should be required is to remove the back panel to access the counterweight. I've performed this repair on several occasions. Loosen the bolts that sandwich the weight between the mounting plates and the whole weight should slide out of its mounted position on the back of the tub. Insert the new weight by sliding it in place and then re-installing the mounting plates and bolts. Tighten until snug. Do NOT overtighten as you may crack the weight. I hope this helps you.
SOURCE: change counter weight
Generally its best if you wish to try yourself to use very heavy fireproof bricks as they are extremely heavy and dense.to do this you must remove the bottom plate which should expose the whole of the balancing section.
SOURCE: broke the pull cord. need to know how to take the
bad engineering - the guard is riveted so you need to pull the whole right side of the casing which means removing three brass bolts. BUt then you will find that the steel housing is in the way so you need to remove the engine from the unit - another four tight bolts and a bit of dismantling a few other connections - a lot of work! Then you need to mess with the spring mechanism!!
This could be an easy fix if the counter weight came loose from the top of the tub shell which is a common problem. Pull the unit out from the wall and removed the back panel to inspect the counter weight, spider pulley and belt. If the counter weight is not broke you can reattach it to tub shell and retighten the bolts. If it is broke it is about $30.00 plus shipping. Inspect the spider pulley which is attached to the tub with the belt around it. If it is not broken, you can turn the pulley by hand to check the tub bearings for free movement. Make sure the belt is in good shape and attached to the motor spindle and spider pulley. If the spider pulley is broken you may have to order a new pulley. If you have to remove the spider pulley you may want to use a gear puller from an auto parts store to remove the pulley. The belt is easily replaced once you know the below procedure:
1. Place the belt around the center of the motor pulley stretching the belt to the spider pulley leaving no slack in the belt.
2. Keeping the slack out of the belt, place the belt on the outside rim of the spider pulley as much as the belt tension will allow you to do so.
3. Keep the tension on the belt and slowly rotate the spider pulley counter clockwise until the belt is completely on the spider pulley.
Rotate the spider pulley several times to make sure the belt stays in the center of the spider pulley. If the belt is not centered after several revolutions you need to remove the belt and reinstall it after moving the ribs of the belt on the motor pulley in the direction which centers the belt. If it was my unit I would fix it unless you have to replace the outer tub shell (approximately $300.00 for parts only).
Pull the unit out from the wall and unplug it. Remove the back panel and check the counter weight (looks like a cement quarter round cement block), spider pulley and belt. The counter weight is attached to the top of the drum and can loosen and fall to the bottom damaging the spider pulley. If the counter weight is firmly attached to the top of the washer drum and the belt is attached to the spider pulley and motor, remove the top cover and lower front panel. Check to make sure the drum springs and shocks are attached to the drum. I hope you only need to bolt the counter weight back on and no other damage to the machine is found, you should get bake to business in about 40 minutes.
