Computers & Internet Logo
Posted on Aug 31, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
I need to open a coreldraw 14 document for editing using coreldraw 12.
pankaj rautela
Level 3:
Genius:
  • Master 1,252 Answers
  • Posted on Aug 31, 2009
pankaj rautela
Master
Level 3:
Genius:
Answers
1252
Questions
0
Helped
333417
Points
3358
Save your file in corel 12 format using corel 14 then open it on corel 12
1helpful
2answers
How do i fix CorelDraw?
Hi, these steps work for me.
1. rename the file to ".zip "
2. open the zip-file with Winzip or WinRar (these programs has a repair-function for zip)
3. try to repair the file
4. then extract the riffdata.cdr from content-folder of zip-file and open this file in CorelDRAW
Maybe that utility might be what you're looking for - CorelDraw Fix Toolbox http://www.coreldraw.fixtoolbox.com/
Or see more http://www.filerepairforum.com/forum/cad-tools/cad-tools-aa/coreldraw/707-%E2%80%8Bcoreldraw-corrupt-file-repair
1helpful
Corel DRAW X6 problems
I presume you mean CorelDRAW Graphics Suite X6 and NOT technical Suite?
If nothing seems to work I would then do as follows.
1.Uninstall CorelDRAW X6 via Control Panel
2.After uninstalling X6 in the Control Panel - Go BACK to the Control Panel and uninstall "Corel Graphics - Windows Shell Extension".
3.Then go to Documents > Corel folder > Uninstall/Delete anything that says CorelDRAW X6
4.You can also go to C: > Program > Corel and delete anythign that says CorelDRAW X6
5.Repeat step 4, but choose folder called Programx86, and delete anything that says CorelDRAW X6
6.You should now have uninstalled everything that useally could disturb when you re-install from scratch.
7.NOW put in your DVD again with CorelDRAW Graphics Suite X6 - and INSTALL from Scratch.
8.You SHOULD now be able to run your CorelDRAW X6.
9.And NOW you should go online to www.corel.com and download and install Update/service pack and Hotfix for CorelADRAW Graphics Suite X6
10.It should in all normal situations work just fine on your PC with any Windows 7 version as well as any Windows 8 and 8.1 version.
11.Try to use a program to recover and view CDR files. For example, you can try this CDR Open File Tool http://www.cdr.openfiletool.com/
12.Also recommend to come to this forum. Many have useful information on the topic. http://www.filerepairforum.com/forum/cad-tools/cad-tools-aa/coreldraw/479-problems-with-cdr-files
Good luck and hope this helps!
I can't open corel draw file ver:12, please help me.
Probably the file is corrupted. Try to use program method for resolving trouble http://www.coreldraw.fixtoolbox.com - it must help you
2helpful
4answers
I have used CorelDraw 8 for years, and the clipart worked fine, even with Windows XP, but I installed CorelDraw X4 and installed it. But after Installing CorelDraw X4, I could no longer is CorelDraw 8...
I had a similar problem with Coreldraw 8. I used it successfully for years and loved it on varoius version of Windows, currently XP. I installed Coreldraw 12 and still had Corel 8 on the computer.
Now the problem: Corel 8 and Corel 12 could not open the Corel 8 clipart disk #2, only just down to the folder level. When I right clicked on the Corel 8 disk #2 clipart folder and checked the Path Properties it gave me a path other than the correct clipart disk location (in my case it should have read E:) BUT it was some weird location like
MNfisherman referenced above and read: C:\Documents and Settings\All Users\Documents\Corel.! What the?! I knew the path should have read E: to access the clipart since the clipart was on the disk and in my CD tray, so I uninstalled Corel 12 thinking that was the problem since 8 had worked fine, then checked the clipart CD again but still no luck.
I then uinstalled Corel 8, so now I had no Corel program on hard drive. I put the Corel 8 clipart disk #2 in the computer knowing it would not open the clips but just to see if I could get beyond the folder level to see if the clipart files were there and yes I could. (I could only read the names of the files at this point because no Corel on computer) So I only reinstalled Coreldraw 12 figuring the later version would open the older version clipart and Success! It worked. I think my problem had something to do with the Corel 8 MF indexer, but I'm not sure. I had a red semi circle (like the Corel Set Up Semi circle) on all of the clipart folders instead of the regular yellowish fold so thats why I think it had something to do with indexer or other type of setup conflict). Now all of my clipart folders appear normal being the regular yellowish color folder.
I suggest using a clean slate by unistalling all versions (Make sure you shut down the computer after each uninstall to get rid of all of the components of the program and then restart the computer) and then only reinstall the newest version. Hope this helps. Good Luck
Coreldraw 12 does not launch even on new installation of xp and coreldraw 12
Are you receiving any errors?
Is this the shortcut on your desktop?
I would try navigating to the actual coreldraw.exe file
windows logo + r
type
coreldraw.exe
If it's anything like microsoft word you can use this
window logo + r
type
coreldraw.exe /s or /a for safe mode options.
2answers
I can't open my corel draw file. When I open closed corel Draw Application
Set CORAL as a default program for your coral draw files because many specific files can only be opened by the application that created them.
1helpful
3answers
Corel draw is not open plz help me
coreldraw x5 (Portable Vertion) not opend.
Error :
The application was unable to load a required component :
CrlUtl.dll. Please contact the publisher of this application for more information.
2answers
Corel draw files do not open
Try launching CorelDraw FIRST then open the file from the CTRL+O command in Corel. Let me know if this works!!!
2answers
Can't open Coreldraw 12 file
convert bitmap object in lo-resolution by convert to bitmap option & than try to save the document
2answers
Opening CorelDraw 12 documents -text shifting and changing size
try running scandisk on the server's drive with "fix errors" checkbox clicked and then defragment it.
Top Corel Computers & Internet Experts
k24674
Kolbrun...
Are you a Corel Computer and Internet Expert? Answer questions, earn points and help others
