Question about Lexmark X2350 All-In-One InkJet Printer
Only printing 1/4 of page
When i try to photocopy an a4 page it only prints the top left hand 1/4.
Posted by jackie_field on
Anonymous
    Scholar:
  • 110 Answers
Follow steps below
Load photo paper or plain paper with the print side facing you.
Open the All-In-One Center.
Click the Saved images tab.
From the Creative Tasks section, select Print an album page with various photo sizes.
Click Change the category of layouts listed above.
From the Selected Layouts box, select for example Only Borderless.
Click OK.
Select a paper size for the photos <- use DIN/4 to print on whole page
From the Page Layout area, select a page layout.
Drag the photos onto the page.
Click Printer Settings.
Select the paper size and paper type. <- use DIN/4 to print on whole page
From the Quality menu, select Photo, and click OK.
Click Print Now.
Hope this is helpfull and answers your question.
Posted on Aug 31, 2009
I cannot print a whole A4 page although the printer is set to A4 - ie labels only print one column
You can do several tests to understand where the problem is.1. Try to print a test page - Go to Printer Devices - Right click your printer and select Properties - Click Print Test Page button like on the picture below
11_29_2011_9_40_40_pm.jpgIf the result is still like your description, you are facing hardware problem like defective toner cassette or drum.2. Try printing from different sources - print a page from your browser like Internet Explorer - print a page from your Office Application like MS Office or OpenOffice - print from notepad - print from Image viewer application
If your printer prints only the left half of the page - this is definitely hardware problem. If you receive different results from different sources, find out wich one of them does the described printout and try to discover the setting that causes the problem and restore it.Sometimes when we talk about MS Office this problem is caused by Print Area setting. You can just Clear this Print Area from Page Layout like on the picture below.
Nov 28, 2011 | Epson Stylus Office Equipment & Supplies
On my Laserjet 3015, in Microsoft Word, if I set top, bottom, left, and right margins to 1", on the printed page, the margins print as Top 1", Left 15/16", Right 1-1/8", and Bottom...
The default paper selection/ size in MS Word is 'letter'. you may have designed the document on letter size and while printing you have A4 size paper in the printer.
So, Make sure that you design the document on the same paper size (such as A4, which is commonly used). Secondly, while printing don't print the document directly. From the Print dialogue option choose the exact paper size and un-check (de-select) any option of paper resizing (if available). You will have the documents printed exactly as designed.
Let me know if any further clarification/ assistance is required.
Hope it helps! Good Luck! Thanks for using Fixya!
CreativeTECH
Jul 12, 2011 | HP LaserJet 3015 All-In-One Printer
The page prints to a small version in top left hand corner. everything is set to A4. Have tried all settings Have tried paper feed from back and front. Unable to get it to print a full size A4 page even...
Make sure on the Page Setup tab that the Page Layout says 'Normal-size' and not 'Poster' (poster tries to place four documents on a single printed sheet). If this is not the problem, try uninstalling and reinstalling the printer driver.
Feb 10, 2010 | Canon PIXMA iP4200 InkJet Photo Printer
Print page settings revert to 6x4 when using as a photocopier, rather than A4
1-In copy mode, display the Settings screen by pressing "Settings" on the MP500.
2-Select the Setting Tab using the left and right arrows.
3-Select the page size by using the up and down arrow.
4-Select "A4" by using the left and right arrows.
5-Complete the setting by pressing Settings
Aug 04, 2009 | Canon Pixma MP500 All-In-One InkJet...
Sheet feeder wheel marks on both sides of A4 photo prints
Open the kodak all in one home center on your desktop and click on [?] on top most right hand side. choose maintenance under general links and choose printhead cleaning. if this does not solve the issue, call kodak @ 1800 421 6699 and they will replace the printhead for you free of cost. no need to switch over to any other brand.trust me Kodak is really good.
Jun 22, 2009 | Kodak ESP 5 Printer
COUNTER CHECK "CANON IMAGERUNNER 2200" BLACK AND WHITE
On the left side of the on/off switch is there a small button mark with 123 press that button and the meter reading will display.
101 TOTAL ***** -that will be the total of copies,printing,and fax receiving on A4
103 TOTAL LARGE ******-this is the total of the A3 copies,printing and fax receiving made
201 COPY(TOTAL) -this is the total A4 copies
203 COPY(TOTAL LARGE)-this is the total for A3 copies.
Apr 02, 2009 | Canon imageRUNNER 2200
OKIpage 10i does not accept A4, and wants 'Letter'
Maybe you won't be able to use A4 paper, which I think is 3/4 inch longer than letter-size 8 1/2 x 11, according to the sizing inside the paper tray of my OKIPAGE 10e. My computer, using Windows 98, doesn't list OKIPAGE 10e among the printers I can use with my computer. Yet, Windows 98 has incorrectly identified my printer as Okidata OL-600e for some reason. I'm surprised my printer works at all with Windows 98. Thanks for detailing your question as "when I print a test page (from the printer controls), because I was unaware I could print a test page using printer controls, so I started pressing anything that looked like an electronic button on the top of my printer. I believe this trial and error eventually helped me to get rid of an unwanted 1 inch wide bar, from top to bottom of 8 1/2 x 11 pages about 2 inches from the right-hand-side of my pages. This was progressively getting worse. I thought I was going to have to buy a new printer. I bought this printer used, and without instruction booklet, so I used your info. about printer controls and started pressing electronic buttons. It's amazing, because after I made about 35 copies, now the annoying 1 inch wide black bar is gone!
Feb 12, 2007 | OKIPAGE 10i Led Printer
Lexmark X2350 All-In-One InkJet Printer Logo
243 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
Muntejaya Ginting
Muntejaya Ginting
CheckitRight
CheckitRight
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
