Question about Cyclops Camping, Backpacking & Hiking
How to open the battery section of cyclops 7 to test and calibrate
Posted by McArd Mlotha on
Compass not working on 2006 Mercury Grand Marquis
Electronic Compass The compass display and module are contained in the overhead console and are replaced as an assembly. For additional information, refer to Section 501-12 . The compass display can be turned off and on by pressing the MODE button in the overhead console. The vehicle heading is displayed as one of N, NE, E, SE, S, SW, W, or NW.
Inspection and Verification
NOTE: Press the MODE button to turn on the display.
  1. Verify the customer concern by operating the vehicle along roads of known direction to duplicate the customer concern with the compass.
  1. Visually inspect for obvious signs of mechanical or electrical damage.
Visual Inspection Chart Mechanical Electrical
  • Compass module
  • Central junction box (CJB) fuse 15 (7.5A)
  • Circuitry
  1. If an obvious cause for an observed or reported concern is found, correct the cause (if possible) before proceeding to the next step.
  1. If the fault is not visually evident, determine the symptom and GO to Symptom Chart .
Pinpoint Test A: The Compass Is Inaccurate/Inoperative
Normal Operation The compass receives battery voltage from the central junction box (CJB) through circuit 964 (DB/LG). Ground for the compass is supplied through circuit 676 (PK/OG).
    Possible Causes
  • fuse
  • circuit 676 (PK/OG) open
  • circuit 964 (DB/LG) open or short to ground
  • compass zone setting
  • compass calibration
  • compass module
PINPOINT TEST A: THE COMPASS IS INACCURATE/INOPERATIVE NOTE: Always set the zone and calibrate the compass before replacing an inaccurate compass.
NOTE: After installing a new compass, always set the zone and calibrate.
Test Step Result / Action to Take A1 CHECK THE OVERHEAD COMPASS DISPLAY
  • Key in ON position.
  • Check the overhead display.
  • Does the overhead compass display remain on after prove out?
Yes
GO to A3 .
No
GO to A2 . A2 CHECK THE COMPASS MODE
  • Press and release the SELECT switch on the overhead console.
  • Does the overhead compass display turn on?
Yes
If the compass display turns on correctly, GO to A3 . If the compass display turns on, but the heading is inoperative/inaccurate or the display indicates VAR, GO to A4 . If the compass display turns on, but it does not display all directions, or indicates CAL, GO to A5 .
No
GO to A7 . A3 CHECK THE COMPASS DIMMING
  • Turn the headlamp switch to the parking lamps ON position.
  • Does the compass display dim?
Yes
TURN the headlamp switch to the OFF position. GO to A4 .
No
TURN the headlamp switch to the OFF position. GO to A8 . A4 CHECK THE COMPASS ZONE SETTING
  • Set the compass to the correct zone for your location. Refer to Compass Zone Adjustment in this section.
  • Does the zone adjustment set correctly?
Yes
GO to A5 .
No
INSTALL a new overhead console. REFER to Section 501-12 . TEST the system for normal operation. A5 CALIBRATE THE COMPASS
  • Calibrate the compass. Refer to Compass Calibration in this section.
  • Is the compass calibrated correctly?
Yes
GO to A6 .
No
INSTALL a new overhead console. REFER to Section 501-12 . TEST the system for normal operation. A6 CHECK THE COMPASS ACCURACY
  • Position the vehicle at each of the 8 directions (N, NE, E, SE, S, SW, W, NW) and verify that the displayed heading is accurate. The vehicle must be stationary for at least 10 seconds at each direction.
  • Is the compass display accurate in each direction?
Yes
The compass is OK. REVIEW the operation of the compass with the customer.
No
INSTALL a new overhead console. REFER to Section 501-12 . TEST the system for normal operation. A7 CHECK THE VOLTAGE SUPPLY TO THE OVERHEAD CONSOLE
  • Key in OFF position.
  • Disconnect: Overhead Console C930.
  • Measure the voltage between the overhead console C930-1, circuit 964 (DB/LG), harness side and ground.
  • Is the voltage greater than 10 volts?
Yes
TURN the key to the OFF position. GO to A9 .
No
VERIFY the CJB fuse 15 (7.5A) is OK. If OK, REPAIR the circuit. TEST the system for normal operation. A8 CHECK THE DIMMING CIRCUIT
  • Measure the voltage between the overhead console C930-4, circuit 484 (OG/BK), harness side and ground while rotating the instrument panel dimmer switch.
  • Does the voltage vary between 0 and 10 volts?
Yes
GO to A9 .
No
REFER to Section 413-00 for further diagnosis of the instrument cluster and panel illumination. A9 CHECK CIRCUIT 676 (PK/OG) FOR OPEN
  • Measure the resistance between the overhead console C930-2, circuit 676 (PK/OG), harness side and ground.
  • Is the resistance less than 5 ohms?
Yes
No
Nov 30, 2017 | Mercury Grand Marquis Cars & Trucks
I have a 97 ford expedition. the brake lights don't come on and it won't shift out of park unless i disconnect the battery cable and turn the key to on. i can then connect the battery cable and start the...
Smart Junction Box (SJB)
ItemPart NumberDescription1-Electrical connectors (part of 14A005)2W706287 - S901SJB bolts (2 required)314B207SJBRemoval
CAUTION: Electronic modules are sensitive to static electrical charges. If exposed to these charges, damage may result.
NOTE: Prior to the removal of the module, it is necessary to upload the module configuration information to a scan tool. This information must be downloaded into the new SJB after installation. For additional information, refer to Section 418-01.
NOTE: The tire pressure monitoring system (TPMS) functionality is integral to the SJB.NOTE: A new SJB is delivered in "manufacturing mode" with 7 pre-set DTCs. These 7 manufacturing mode DTCs require that a successful configuration of the SJB occurs, then a successful TPMS sensor training occurs, then a successful self-test occurs, including the clearing of all DTCs. All of this is required in order to clear the 7 manufacturing mode DTCs. The 7 manufacturing mode DTCs are as follows:
B2477 (Module Configuration Failure)B106D (Tire Pressure Monitor System Initiators Not Configured) This DTC is present when the SJB is not configured, even on applications that are not equipped with initiators.B2868 (Left Front Tire Pressure Sensor Fault)B2869 (Right Front Tire Pressure Sensor Fault)B2870 (Right Rear Tire Pressure Sensor Fault)B2871 (Left Rear Tire Pressure Sensor Fault)C2780 (ECU in Manufacturer Sub-state)Upload the module configuration information from the SJB into the scan tool. For additional information, refer to Section 418-01.Disconnect the battery. For additional information, refer to Section 414-01.Remove the pin-type retainer and the RH A-pillar lower trim panel.Remove the glove compartment. For additional information, refer to Section 501-12.Disconnect the 7 electrical connectors.Remove the 2 bolts and the SJB.Installation
Position the SJB and install the 2 bolts.Tighten the screws to 2 Nm (18 lb-in).Connect the 7 electrical connectors.Position the RH A-pillar lower trim panel and install the pin-type retainer.Install the glove compartment. For additional information, refer to Section 501-12.Connect the battery. For additional information, refer to Section 414-01.NOTE: When successful, this step provides the calibration necessary for the SJB operation and clears DTCs B2477 and B106D. The clearing of these DTCs indicate the calibration data has been successfully downloaded to the SJB.Download the SJB configuration information from the scan tool to the SJB. For additional information, refer to Section 418-01.NOTE: When successful, this step clears DTCs B2868, B2869, B2870 and B2871. The clearing of these DTCs indicates the SJB has recognized the tire pressure sensors during the training procedure.Train the tire pressure sensors. For additional information, refer to Section 204-04.NOTE: DTC C2780 will not clear if any other DTCs are present in the SJB.Carry out the SJB on-demand self-test by clearing DTCs and then retrieving DTCs to confirm all DTCs have been cleared.
The fuses you want to check are in the smart junction box. Hopefully you can find it from instructions. I was just trying to give you location for those fuses. Don't worry about tire pressure sensors info.https://s9.postimg.org/kqyabqqlb/smart_junction_box.jpg
I hope you can click on the link for fuses, if not, type into address bar. The two fuses at top left, are hot all the time, not only check the fuse, use a test light and check voltage on fuse circuits. With shift interlock the brakes lites needs to work. I can't rule out smart junction box or a wiring circuit somewhere? Any applicable trouble codes?
Jun 29, 2017 | 1997 Ford Expedition
Replacement battery availaibility
Same battery as VARIOUS UB623 MODELS.
http://www.interstatebatteries.com/cs_eStore/Products/RT/PID-SLA0184%28Other+Products%29.aspx?dsNavigation=Ns~product+Type'101'1'%2CNrc~id-3%2CN~4294509717-4279143893&Title=Battery+replacement++for+various+UB623+models
Jan 28, 2013 | Cyclops Thor X 9-watt Hand-held Spotlight,...
CAN I FIND MANUAL FOR CYCLOP-1 AP-7 (PARTS)
The Cyclop-1 is Russian manufactured. Go to Night Vision Optics web page and see if they have manual on this one eyer to down load. As far as parts go, They will not sell you parts. I really doubt if they have parts. What parts are you seeking for this Cyclop? GB...stewbison
Aug 28, 2011 | Optics
® XRF Xenon Rechargeable Flashlight: Where can we find the batteries for Xenon Cyclops ...
I am not familiar with that particular model flashlight. Most of the Cuclops flashlights use the 3.0 Volt CR123 Battery. However, here is the URL for Cyclops Solutions website. www.cyclopssolutions.com/index.html
May 15, 2010 | Cyclops ® XRF Xenon Rechargeable...
Ok well i bought the wheel and i have this game called dirtfactor and i was trying to drive a latemodel and it doesnt turn at all it turns a little but barly......also when i do sprint cars it turns but...
I wouldn't say it's a lack of the wheel being cheap I'd be more inclined to say it's "because" the wheel is cheap. Seriously, Have you tried to calibrate the wheel using the windows calibration routine found in your control panel under Game Controllers.
Obviously the wheel is operating but barly sorry, barely. That means it is working and giving input to your computer so if that input isn't enough you either need to calibrate in windows or maybe there's even a calibration routine in the game you're playing, maybe under options. Calibration by the way is found under properties on the Game Controller section. Try it.
The test section of the windows section will tell you just how far your wheel is turning or directing your cars by means of a box with a cross in it. The more you turn the wheel the further that cross will move. Test it first, then do the calibration and then test it again. I'm sure you'll see a big difference.
Apr 21, 2010 | Genius Twin Wheel F1
I have a cyclops 2 cell witch uses the cr123a batteries.the bulb burned out . where can i get an replacement at
The bulb may be purchased at most electronic stores such as Fry's or Radio Shack for under $2.
Feb 02, 2010 | Cyclops ® XRF Xenon Rechargeable...
CYCLOPS 15MILLION FLASHLIGHT--DOES NOT RECHARGE-RED LIGHT CONTINUES TO BLINK.  CHECKED BULB, APPEARS TO BE IN GOOD CONDITION.  NOW WONDERING IF BATTERY IS NO LONGER FUNCTIONAL AND WHERE CAN...
You will probably not be able to find a battery, those are usually very economically priced and replacement parts are rarerly every available. You may be able to find similar rechargable battery that would work, try a dept. store or hardware store and look in the flashlight section.
Jul 30, 2009 | Camping, Backpacking & Hiking
Camping, Backpacking & Hiking Logo
144 people viewed this question
Top Cyclops Camping, Backpacking & Hiking Experts
john h
Tom Chichester
Don A
Don A
Are you a Cyclops Camping, Backpacking and Hiking Expert? Answer questions, earn points and help others
