Question about GE Refrigerators
GE bottom freezer PFS22SISDSS experience power outage and now Temp controls read 999 999 at low temp and 000 000 at high temp. Both frig and freezer are functioning. Is there a reset for controler?
Posted by Neil Beaverson on
5 Related Answers
Anonymous
  • 33 Answers
SOURCE: Freezer temp is rising to 12 degrees and doesn't reset
Most likely your computer board got zapped. It's usually located on the back of the unit. Have you tried to reset the unit by leaving it unplugged for about 20 minutes?
Posted on Nov 29, 2008
Anonymous
SOURCE: Freezer not working
I have a Kenmore Freezer model # 253.9251310 serial # s510347256
10\95 Makes all kinds of noises and now is defrosting. Sounds like fan is working but no noises besides fan. any ideas
Posted on Dec 12, 2008
Anonymous
  • 700 Answers
SOURCE: control pad is flashing and can't seem to reset tempeature
try unplugging the unit and waiting 9 minutes then plugging it back in.
Posted on Dec 26, 2008
SOURCE: frig mdl#pbb1951grq freezer works fine frig will not cool.
The damper is not opened and closed just by control movement alone. Your control connects to the damper by a notched plastic band. The damper also has a temperature sensor on it. To check damper operation set control to 4. Hold an ice cube to the temp sensor (a coil of small aluminum tubing) and the damper sholud close. As long as the fresh food comprtment is calling for cold air, the damper will remain open reguardless of control setting.
Posted on Jun 05, 2009
2coolrick
Cool Blue Services
  • 560 Answers
SOURCE: GE side-by-side PS123SGMD BS won't cool
Check the door seals to be sure they are in good working order. Close both doors on a dollar bill at several locations all around the door and pull on the dollar bill. You should have resistance as you pull it out in every area you check. If you have any gapped areas and it slides easily, adjust the door or replace the seals. Also, is the circulation fan in the freezer working correctly? Lastly, unplug the unit for 5 minutes to allow the control module to reset itsef. Then plug it in again and reset your temps, clock etc.
Posted on Jul 31, 2009
Ge profile 2004 open door and temp controls off shut door open they come back on light was staying on sometimes to bottom half of coils in freezor froze freezer working but temp in frig 50s on off fri
It is possible the refrigerator is low on Freon. You will need to remove the back panel inside the rear of freezer to examine the evaporator coils. If only a few rows have frost it will be time to replace the refrigerator. If the control panel in the freezer dispenser are coming on and off there may be a bad connection in the plug under the top left door hinge cover. Check that the plug is tight. Let me know what you see first behind the freezer wall, Thanks Sea Breeze
Dec 12, 2012 | GE Profile 25.6 Cu. Ft. Side-by-Side...
My GE Profile side by side fridge freeze the food in the bottom draw. I have set the temp to 43F but keep the fridge at 34 or colder. It frooze the water lines and tank in the fridge several times. What am...
You probably have a sensor issues there are two one for the freezer one for the frig. Check your freezer temp it should be at 0 degress at manufactor setting. If the temp is below -10 you freezer sensor is bad. Otherwise your frig sensor is bad. CHECK FREEZER FIRST!!!
May 27, 2011 | GE Profile 25.5 Cu. Ft. Side-by-Side...
I have a GE Profile refrig with bottom freezer.Today, the power company turned off the power to the streey and when power came back on, my display in the left refrig door is brinking 88 on one side and the...
I had this issue after a power outage with our GE Profile Model GFSF6KKY Dispenser Model. No solution that I could find online helped me so I started trying different button combinations. Pressing Adjust Freezer and Adjust Refrigerator buttons at the same time and holding it for at least 10 seconds worked for me.
Nov 19, 2010 | Refrigerators
SIDE-BY-SIDE WARMING UP
do a full manual defrost then turn unit on and let it settle for 24 hours then check temp guage.....(try to keep doors shut when settling down)
Apr 08, 2010 | GE (PSS26MSRSS) Side by Side Refrigerator
Freezing problem in maytag frig
the probe from the temp panel is not sensing correct temp or the panel itself is bad...call a tech to check it out
Feb 04, 2010 | Refrigerators
GE refrigerator not cooling after power outage
It sounds like the main control board is bad . After looking up the board , it is on a recall lisr by GE . You should call GE and have them come and check it .
http://www.scribd.com/doc/13371507/Ge-Motherboard-Concession-Letter
Nov 02, 2009 | GE Refrigerators
Bottom freezer temperature rises as high as 35 degrees and drops only to a low of 15 degrees continually. ongoing for a month now. french doors fridge now has temp. fluxes within this past week. temp. goes...
check the defrost thermostat , and any temp sensor that can determine the freezer temperature.
If this fridge temperature is electronically controlled, the freezer control board must also be tested.
Click here to get all parts and diagrams for this fridge.
Regards.
Jul 09, 2009 | GE Profile PFS22MBW French Door...
Freezer not maintaining temp
sounds like the evap thermistor took a ****. in the back of your freezer you have cover that sits over the refrigerator coil. under this coil sits a heater element that is turned on and off to defrost the refrigerator coil based on how long you've had the door open. the evap thermistor reads the temp inside the freezer.. close to the refrigerator coil.. and tells the heater element to turn off after it reaches a set temp where it can be sure that the ice has melted off the refrigeration coil which is about 60 deg. if your thermistor has taken a ****.. your heater element will only shut off based on the "fail safe" time (which is based on how long you've had your fridge door open) leading to a hot freezer.
i suspect your at home more on the weekend.. inside the fridge.. getting cold beers.. and that is why it ends up hotter on the weekend.
Cheers!
Jun 14, 2009 | GE Energy Star PDS22SIS Stainless Steel...
Freezer/ fridge not cooling, compressor not running
this refig has 2 independent temp controls one that operates the freezer side (this one also operates compressor, condenser fan and evporator fan) and one that controls the temp for the fresh food side this one operates a damper and evaporator motor.
I looked up you model number and you need to check the control that is located to the left side of the control panel or the freezer control. if it is 60f in the unit then if this control is good it should read infinity on a ohms meter. if its bad you will get no reading at all. alternatley you may try hitting the control solidly with the **** of a screwdriver sometimes the contact will hange open. message me back if you need further assistance. peyton...
Jan 28, 2009 | Frigidaire FRS26R4A Side by Side...
LG LRBN20514ST Bottom Freezer Frig cooling problems
Set the temp to low not high and wait 24 hours to see if the temp has drop.Also make sure the freezer is not icing up anywhere.If it is please repost.
Jan 13, 2009 | LG LRBN20510WW Bottom Freezer Refrigerator
Refrigerators Logo
114 people viewed this question
Top Refrigerators Experts
Ron Rak
Ron Rak
gbob59
