Question about Video Cameras
Hi, my Dz-Mv2000E disc eject is not opening and noise coming from it as it is trying to open, any ideas
Posted by William Sharp on
3 Related Answers
Anonymous
  • 154 Answers
SOURCE: When we press the disc
it could well be that the tape or the metal / plastic part that prevents the tape door from being opened accidentaly is bent or broken.
if the memory's on the tape are worthwile the effort bring it i to a specialist repairshop, do not try to open it in any other way than described in the manual of your camcorder
Posted on May 17, 2008
Anonymous
SOURCE: hitachi DZ-MV380A NTSC won't eject Disc
I have the same problem, I unfortunately cannot fix it.
Posted on Jul 17, 2008
Anonymous
SOURCE: disc eject on Hitachi DZ-GX5060E will not work
I've just received mine today from Argos Clearance Bargains (http://myworld.ebay.co.uk/argos-clearancebargains/) and had the same problem. I was already compoisng a strong complaint in my mind. Anyway I tried the reset method. Remove battery; open LCD screen;hold in reset buttona few seconds; reconnect battery; set to "off" and eject .... out popped a very dirty DVD-RW.
When I reinsterted it the problem recurred and I solved it the same way. I have now permenently removed the offending DVD and the cover opens and closes fine. I will buy some fresh DVDs this weekend and see if the problem returns.
Watch this space and also let me know how you get on,
Posted on Aug 21, 2009
Testimonial: "Worked perfect, Thanks"
1helpful
Eject the tape on Hitachi VT-FX695. It stays on for about 45 seconds and will not eject and then powers off.
hi,
the door mechanism is may be gripped because of a small kick...
did you try to open the door with a full charged battery and with the wall plug connected too ? help it with a toothpick or the corner of a credit card...
if this doesn't work, it may be the motor that is dead, do you ear any little noise when asking the ejection ? if yes, it is the mechanic, if not, it is the motor or the motor driver that is dead.
cheers,
mich
I cannot open or eject the digital disc? what can be the wrong?.
The eject button, the spring, or the piece of plastic that pushes it out.
1helpful
I have the DZ-GX5020A DVD Cam....the disc eject door will not open.....I can hear it clicking trying to open, but no luck... everthing else works fine.......can you help me?
None of those options worked for me. I had to remove the single screw on top of the camera. Then slide the silver top panel forward to remove it. Then remove the dark panel where the screw was removed. Then you should see a small metal piece very close to the DVD door opening that is holding it closed. Slowly nudge it forward to unlatch the door. This allowed me to open the door to remove the DVD. Unfortunately I still have to do this every time to get the door open. I may try some lubricant on the metal to prevent sticking.
7helpful
2answers
Disc eject on Hitachi DZ-GX5060E will not work
1helpful
2answers
Probelm ejecting the dvd from my Hitachi GX3100A
If you go to the Hitachi website, you can download the product manual for your camcorder there.
These are the instructions for opening the dvd door.
1 Press down the DISC EJECT button once and
release it.
A few moments after the ACCESS/PC
indicator blinks, the cover of disc insertion
block will open.
2 Gently open the cover by hand fully until it
stops.
This is the link for the owners manual search: http://www.hitachionlinestore.com/survey/manualsearch.aspx
Hope this helps.
Hitachi DZ-MV380A NTSC won't eject Disc
When we press the disc eject button the door does not open on the Hitachi DZ-GX5080A camcorder.
3helpful
2answers
Help ejecting dvd
I had the same problem and tried for ages (even tried forcing the door open thinking I could just tape it shut) without luck.
Then my very clever wonderful husband had a go (I know i'm crawling and yes my knees hurt).
Any way to the relevant bit. If you hold the eject button down and at the same time slide a knife or similar object round the edge of the door where the screw is near where it says photo/select you'll find that the door opens as this is an override mechanism.
Cant open up cassette
There are positions on the rotary switch that determine whether you're on the hard-drive or the mini-DVD functions. There's even a small switch (to the lower left of the rotary dial) that keeps you from accidentally switching to the DVD functions.
Make sure you're dial is all the way to the left and reads "DVD". Once you're set on that, the disc eject button should work.
Disc Eject won't work after improperly inserting disc and since removing it.
I have an DZ-MV780 with the same problem. I found that the cover plate around the flash hot shoe only has a single screw. If you remove it and pull up the cover you gain access to the gear and lock mechanism. Hit eject and if necessary press on the white gears you see in front of the zoom switch. It should then cause the door mechanism to unlock and open.
Video Cameras Logo
Top Video Cameras Experts
Ekse
Harrie
Are you a Video Camera Expert? Answer questions, earn points and help others
