Question about Konica Minolta Office Equipment & Supplies
Pls. help us,how can we used land cord to connect printer konica 7035 to computer. we already down load a driver from internet . we try many times to check sa IP address and test print but still we cannt connect .
Darek Goral
    New Friend:
  • 51 Answers
Using arp command (UNIX)
From UNIX you can use the arp command to assign the IP address to the network interface card.
Perform the following procedure:
1. Turn off the print controller and the main body printer.
2. Log in as superuser on a host on the same subnet as the network interface card. However, if
the server resides on another subnet, complete this procedure to store the IP address in the
3. Find the MAC address of the network interface card. The address is printed on the Status Page
each time you turn on the print controller and the main body printer.
4. Edit the hosts file (usually /etc/hosts) or use NIS or DIS to add IP address and node name of
the network interface card. See the network administrator for the IP address. For example, a
network interface card with a name of printfast and an IP address of 192.9.200.200 has the
entry:
192.9.200.200 printfast
5. Add an entry to the arp cache for IP address and Mac address of the network interface card,
as:
arp -s 192.9.200.200 0:40:c8:0:0:ff
RS6000 (AIX) requires the ether option after arp -s. For example:
arp -s ether 192.9.200.200 0:40:c8:0:0:ff
6. Check the print controller and the main body printer to see that the network interface card is connected
to the network. Turn on the print controller and the main body printer.
7. Send a ping command to the network interface card to verify it is running on the network, as
for example:
ping 192.9.200.200 or ping printfast
The network interface card will not respond to this ping command but it will read its IP address
from the packets.
8. Turn off the print controller and the main body printer and back on again and then send the
ping command again to verify that the network interface card obtained its IP address. A confirmation
message displays as:
192.9.200.200 is alive
9. Remove the entry from the arp cache using the following command. Specify the network
interface card either by its IP address or by its name, for example:
arp -d printfast
Konica Network Interface Card INSTRUCTION MANUAL 2-5
Chapter 2 Setting Up the Network Interface Card
Using MAP
By using MAP (Management Access Program) included the CD-ROM that comes with the network
interface card, you can automatically identify the network interface card on the network and set it up
for TCP/IP by using Web Utilities. To use this method to assign the IP address to the network interface
card, the following procedure should be performed on computers in advance:
• TCP/IP correctly configured
• IPX/SPX-compatible protocol installed
• MAP installed and MAP setup correctly executed
About how to set up TCP/IP and how to install IPX/SPX-compatible protocol, refer to Windows Help
menus for example. For MAP, refer to “Using MAP (Management Access Program)” in this chapter.
To change an IP address already assigned to a network interface card, you can not use the
arp command. Use Web Utilities instead. These methods also allow you to set up subnet
mask and default gateway, etc.
Using NIManage
Refer to “Chapter 7 AppleTalk Configuration”.
 Accessing Web Utilities
The network interface card is provided with an HTTP server having Web Utilities. By accessing this server,
you can change settings of the printing system. There are two ways to access Web Utilities, through a Web
Browser, either through Netscape Navigator, version 4.x or greater or through Internet Explorer, version 4.x
or greater.
• Use MAP to have the network interface card on the networks identified automatically, thereby accessing
Web Utilities.
• Use a Web Browser to type the IP address assigned to the network interface card, and thereby access
the Web Utilities. For example:
http://192.168.0.128/
If you designate the proxy setting in your Web Browser you cannot access the Web Utilities.
For more information see your network adminisrator.
2-6 Konica Network Interface Card INSTRUCTION MANUAL
A utility called MAP is provided on the CD-ROM that comes with the network interface card.
This program automatically identifies the network interface cards on the networks and lists them on Web
Browser screen. From this Web Browser list you can select a network interface card to change its settings
and control Web Utilities.
Posted on Aug 31, 2009
Testimonial: "sir, thanks alot its helpfull ..."
I have a konica 7020 machine, the first copy comes with horizontal black lines but not the others (when copying e.g more than one copy)
1 look to the drum surface for scratch if their is replaced it. 2 the write unit might already defective. Damage drum will cause sparks to charging unit and Horizontal lines produce.
Dec 02, 2014 | Konica Minolta Konica 7020 7022 7025 7030...
How i can adjust the position of the Touch Panel display konica 7020
Go to Touch Panel adjustment you will see "+" to the 4 corner of the touch panel use pointed object point it MILD on the center of the 4 "+" . Off / On
Oct 06, 2014 | Konica Minolta Konica 7020 7022 7025 7030...
Printer offline
You did not specify if printer was formerly working, the model # of the printer, or what version of Windows you are using. All this information is needed for successful troubleshooting. However, the below is general resolution for your problem:
"Offline" means your computer cannot "see" the printer as connected and powered on.
In order of things to try:
1. Turn printer OFF. Unplug USB cord from printer (or other end from computer). Wait at least 30 seconds. Plug USB cord back in. Turn printer back on. Does it still show as "offline" under Start --> Devices & Printers?
2. Try replacing the USB cord (yes, they can and do go bad).
3. Turn printer off. Unplug USB cord.
Under Windows Start --> Printers and Devices:
RIGHT click the Konica printer icon. Select "uninstall" (or "remove device") and follow through until printer is successfully UNinstalled. If there is other Konica software installed, remove it also (via Start --> Control Panel --> Add/Remove Programs -or- Programs & Features).
4. Reboot your computer. Follow manufacturer printer installation procedure, step-by-step (consult mfr website if you do not have a printed installation manual). Do not plug in USB cord or turn on printer until instructed to do so.
If all else fails:
Ignore any manufacturer installation instructions.
Do # 3 only above.
Reboot computer.
Plug in printer and connect it to computer.
Let Windows try to automatically install it (in most cases, Windows can install the "basic" print drivers, which are smaller and sometimes more stable than the fancy drivers and excess software the manufacturer wants you to install).
If still no go, you probably have a dying or dead printer. Consult manufacturer website for help.
Mar 07, 2014 | Konica Minolta Office Equipment & Supplies
Konica 223 spooler error
what model machine
tried different files and programs down loaded latest drivers from konica minolta
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/normanj_7893313f0751935f
Jan 23, 2014 | Konica Minolta Office Equipment & Supplies
How to clear f-326-3 code on a Konica 7035
Turn off then on wait 10 seconds between
Mar 12, 2010 | Konica Minolta DiALTA Di200 Copier
USE KONICA 7025 AS A PRINTER...
have you loaded the print driver on your computer? Does the machine have a print controller (IP 011/421) and networkcard (KN303) Can down load print driver software at Konicaminolta.us
Mar 10, 2010 | Konica Minolta Office Equipment & Supplies
Konica coppier 7035 (F-26-1 error)
Replace the developer and the drum and clean the sensor that monitors the drum. and after developer is replaced ensure you run the required procedure in 36 mode.
Jan 17, 2010 | Konica 7075 All-In-One Laser Printer
I have a Konica 7035 that has code F-35-6 show up. We found a major paper jam, removed it after taking apart part of the copier but the code remains. Any advise? Also, where can I find a manual for this...
Hello sir; Here is the way to reset this error code; press and hold down 25 while you turn on the machine, chose 1 for software switch, use up/down key to select dipswitch 3, and bit 1, then change 1 to 0 by pressing ''off".
Jan 10, 2010 | Konica Minolta DiALTA Di200 Copier
I want to install network adapter
hi! there,internet connection using your lan card or built lan adapter on *********** board if your network to public server e,g In your town telephone w/internet using usb port or broadband wire less no matter where,as long you subcribed there service ready for internet connection,i thing this kind of service once you purchsed and subcribed they are responsible to connect to your computer,but somehow this is your request,external land card when you buy it is already provided w/ cd driver installer and built land adapter on mother board driver was on mother board cd installer.if in the absence of installer you can down load to web site there free and there is you have to purchase take name of mother board you can see on inside pc and on *********** type this website just put .com at end.and select what ever you want.same with external lancard,insert your externai landcard on mother board on white slot.but you have to remove cover for land card back of cpu.check the driver of land card in device maneger.
to open device maneger ,control panel,system properties.connect your usb cable both on land card and modem,wait a minute until installation appear in your screen follow what wiazad
Apr 02, 2009 | Dell OptiPlex GX260 PC Desktop
715 people viewed this question
Top Konica Minolta Office Equipment & Supplies Experts
Norman  J Weimar Jr
Norman J Weimar Jr
carpediemweb
Level 1 Expert
George Mclaughlin
Are you a Konica Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
