Question about Maytag 30" Built-In Single Electric Wall Oven - Black
Control panel buttons due not work
I have a Maytag oven, the control panel does not work!  Cannot control anything. How do I fix it? What is the problem? Does the whole thing need to be replaced?
Posted by yvettenueva on
Anonymous
It is the whole front face w/ the buttons. My whole neigborhood has these ovens (same builder, same ovens) and this part lasts about 2-4 years. The part is about $165. You can see it on Home Depot's appliance repair site. It looks like there is nothing electronic, but there is, and it's busted. It is really easy to replace:
1. Turn off the breaker at your house's breaker panel.
2. Verify there is no power to the oven.
3. Open the oven door. Look on the right and left side of the oven. There should be 4-6 screws going from vertical trim pieces of the oven into your cabinets. Your builder may have also put screws from the bottom trim of the oven into your cabinets. Mine did not. Remove these screws.
4. After that, your oven should slide forward out of the cabinet. Pull it about 6 inches out.
5. There are two screws (1/4 inch hex headed screws) holding the front panel to the oven. Remove those.
6.Slide the front panel off.
7. Remove the computer ribbon looking wire from the back of the control panel. It's a strange connection - it should come out effortlessly when done right. The little grey connection that surrounds the wire's entry point stays on the panel, but a wedge is jammed between the grey surround and the wire. You pull the wedge out and the wire comes out...easier than my credit card out of my wallet.
8. Remove the four screws (again, 1/4 inch hex headed screws) connecting the thick, double layered circuit board and clock display from the metal face.
9. The metal face is what you need to replace. Pasted onto the front of the metal face is a super thin button panel, and that's the part that died, and will die again, and again, and again...
email me for pics [email protected]
Posted on Sep 30, 2009
Brand new oven, maytag, the oven won't heat up and
IF IT IS STILL UNDER WARRENTY DON"T TOUCH IT CALL THEM BACK , MAYTAG HAS MANY PROBLEMS BUT THEY ARE GOOD AT REPLACING UNITSTHATHAVE PROBLEMS , PLEASE LET ME KNOE WHAT HAPPENS IF YOU NEED ME TO CALL THEM GIVE ME THE INFO AND I WILL DO THIS BUT SHOULD BE OK
Dec 01, 2011 | Maytag Ovens
Only some of the keys on the keypad of my oven work. I have replaced the control board (computer board), but they keys still don't work. What specific part do I need to replace?
Hello, Thank You for using FixYa. I will be helping you today.You didnt have to change the computer you need to replace the control panel. The control panel is the whole front piece which has the touch membrane on it. This is common on these units.
Thank You and please rate my answer if it was helpful..
Jun 10, 2011 | Maytag MEW6530DDS Stainless Steel Electric...
I have a GE JTP70, The Plastic over control panel bubbled up.
Mine did the same thing...and believe me it even looks worse over time....look online it happened to a lot of people....GE won't do anything about it....it is a defect but they won't own up to it......They just want you to keep replacing the part, which cost a fortune. Mine oven cost over $1000 and I am stuck with a nasty looking piece of garbage in my brand new kitchen......can't afford to buy a new one.........I Will NEVER BUY ANOTHER GE PRODUCT AGAIN!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
Feb 19, 2010 | GE JTP70 Electric Single Oven
Built-In Oven Buttons Stop Working
Email me for some pictures:
[email protected]
Aug 02, 2009 | Maytag 30" Built-In Single Electric Wall...
Error code E6 F2
We repair these control boards frequently. The E6 F2 error is very common for whirlpool ovens and almost always is caused by the control board. It can be repaired quickly and reliably. www.fixyourboard.com
Jul 07, 2009 | Ovens
Maytag wall oven Model # MEW6530DDS control panel failing
HI, unfortunately, it is not just dirt, this is a faulty touch pad that is combined with the control board. most touch pads are separate parts that are clipped in front of the circuit board but, in this case, the touch pad and control board are one piece. You will need to replace the entire control board in this case. the touch pad is faulty.
Jun 03, 2009 | Maytag 30" Built-In Single Electric Wall...
Dacor ECS136 Control panel just beeps but does not work
i am having that problem with my maytag one. the only thing i can do is unplug it and quickly press bake and set the temp and time length. mine says its locked though. i am trying to figure out how to unlock mine.
Oct 30, 2008 | Dacor ECS136 Epicure Stainless Steel...
Front Panel Buttons not responding
The touch control panel is a piece of ****! Call MAYTAG, and get a new one, you should still be under warranty. Make them send you the part direct ( its the WHOLE front top panel ), then call a tech to put it in for $50 bucks. Takes about 10 minutes to do. The panel plugs into the electrical Board behind the panel.
FYI...the Top panel includes the Stainless Panel + the Touch controls! Its all one integrated part. The part that goes bad is the "cable contacts" that latch to electrical panel.
FYI....the Cable is made of "thin clear film " similar to Film you put in a Camera.
Jun 19, 2008 | Maytag MEW6530DDS Stainless Steel Electric...
Maytag oven calibration
Maytag single built in oven model cwe9000bcb beeps intermittenly. Reset stops for about 1 minute. Two control panel boards replaced since 2002 with same problem. Can it be fixed?
Dec 18, 2007 | Maytag CWE4800A Electric Single Oven
Maytag 30" Built-In Single Electric Wall Oven - Black Logo
399 people viewed this question
Top Maytag Ovens Experts
Michael Thomas
Michael Thomas
Marvin
Marvin
Paul Carew
Are you a Maytag Oven Expert? Answer questions, earn points and help others
