Question about Texas Instruments TI-84 Plus Calculator
How to change from phasor/polar form to rectangular form?
Posted by evisubruce on
Anonymous
  • 3 Answers
Hit [Mode] then arrow down until you can choose Rect, then hit [Enter] then [2nd][Quit].
Posted on Sep 01, 2009
1 Related Answer
  • 102366 Answers
SOURCE: Converting between Forms When working with
You can switch the display mode for complex numbers by pressing SHIFT MODE down 3 and picking one. This will display the current result in the selected mode.
You can also override the current display mode and specify the format. Add these keystrokes at the end of a calculation: SHIFT 2 then 3 for polar or 4 for rectangular.
Posted on Nov 24, 2010
I need to find how to insert polar phasor to convert to rectangular complex...
See captured image below. These examples are computed for angles measurement in radians and degrees in two dimensions
Jan 29, 2016 | Texas Instruments TI-Nspire CX CAS...
How to add polar and rectangular form on calculator?
You cannot add rectangular coordinates to polar coordinates. You can only add rectangular coordinates to other rectangular coordinates. For polar coordinates you must use some specific trigonometric formulas.
Sep 23, 2014 | Casio Office Equipment & Supplies
How do I add or subtract numbers in polar form or rectengular form
If one or both numbers are in polar form, convert it/them to rectangular. Once both numbers are in rectangular form, simply add the two components separately: Add the two x components together, and add the two y components together.
If you're asking how to do this on a particular calculator, please specify the make and model.
Oct 15, 2013 | Office Equipment & Supplies
Polar to rectangular conversion working incorrectly
At first, Rect and Polar are a display-format instructions, not a conversion functions. Polar instruction displays complex value in rectangular form a + bi. The complex value can have any complex form. However, an r*exp(i*theta) causes an eror in Degree angle mode according to the TI avowal. See captured images below
Sep 06, 2012 | Texas Instruments TI-84 Plus Calculator
Conversion of polar to rectangular form and vice versa
Conversion of polar form to rectangular:
  • Switch to CMPLX mode: [MODE] [2]
  • Enter complex number in polar form, e.g. r = 3, θ = 42°: 3 [SHFT] [(-)] 42 [=]
  • Switch to rectangular view: [SHFT] [2] [4]
Conversion of rectangular to polar:
  • Enter complex number in rectangular form, e.g. real part = 2, imag part = 3: 2 [+] 5 [ENG] [=]
  • Switch to polar view: [SHFT] [2] [3]
Jan 12, 2011 | Casio FX991ES Scientific Calculator
How do I convert between the rectangular and polar form of a number with imaginary values? i.e. I want to take the number a+bi and convert it to polar D<(angle) and vice versa.
Use the >Rec and >Pol commands. They're in the Complex number menu, accessible through 2nd [CPLX] MORE.
[CPLX] is the shifted function of the 9 key.
Dec 10, 2010 | Texas Instruments TI-86 Calculator
Converting between Forms When working with phasors it is often necessary to convert between rectangular and polar form. To convert from rectangular form to polar form: M = sqrt{A^2 + B^2} f =...
Nov 24, 2010 | Casio FX-115ES Scientific Calculator
Hello - i have a casiofx250 calculator and i urgently need to convert from rectanular to polar - how do i do this ? raj
This is an example, plug in your problem.
Convert 12 - 42j to polar form (r ∠ q).
For CASIO calculator...
Keystrokes Display 12 12 rp.gif 12 42 42 plum.gif -42 eq.gif 43.68065934 (= r) xy.gif -74.0546041 (= θ) Therefore,
Complex number in rectangular form: 12 - 42j Same complex number in polar form: 43.7 ∠ -74°
Feb 29, 2008 | Computers & Internet
Texas Instruments TI-84 Plus Calculator Logo
4,143 people viewed this question
Top Texas Instruments Office Equipment & Supplies Experts
k24674
Paul Bade
Daniel Dollive
Daniel Dollive
Are you a Texas Instruments Office Equipment and Supply Expert? Answer questions, earn points and help others
