Question about Pentax Optio 50 Digital Camera
My pentax optio 50 lens got stuck half-way and now the camera turns on briefly and then goes off automatically. I've replaced batteries and pushed the lens in manually, but it's still not working. Mary
Posted by marychap on
Anonymous
    Scholar:
  • 42 Answers
This is tricky .. if you have no warranty, and have already managed to push the lens in.. I suggest pulling the lens outwards gently AS you simulataneously turn the camera on. You may be able to use a small suction-cup affixed to the lens to do this :)
you could hold the lens-cover open with tape so the cover is less likely to be damaged.. good luck, this problem is common, annoying, and usually not worth repairing (*although with some cameras it can be done again and again!)
Posted on Aug 31, 2009
Optio 555
Is the lens totally stuck? Does it even move a little? Did you try to power cycle the camera?
Feb 27, 2008 | Pentax Optio 555 Digital Camera
IF MY PENTAX OPTIO A30 is turned on a blank screen
It sounds like you need a new main board. Pentax in Arizona will replace the main board for about $135, or I will replace it for $65. If you just want to get rid of this camera, I also buy all Pentax Option a10, a20, a30, a40 cameras.
Contact me at: mrfixitmark at comcast dot net
Dec 23, 2009 | Pentax Optio A30 Digital Camera
Goes off after lens come out.
Get it repaired under warranty. Sounds like a logic circuit problem.
Dec 10, 2008 | Pentax Optio S50 Digital Camera
Pentax Optio M20
Maybe.
But it does seem to be a lens problem. Possibly the lens is out of sync as mentioned in another post here.If there is a grinding, the lens is probably damaged by dirt or sand.
Make sure the batteries or battery is fully charged.
May 31, 2008 | Pentax Optio M20 Digital Camera
Pentax Optio 50 Digital Camera Lens Error
Not really, it sounds like the lens has been bumped while it was extended. Unfortunately, the "buzz" you hear is the gears stripping one another. The only fix is to have the lens assembly replaced, which usually costs upwards of $200. I see this problem at least 3 times a week in my shop.
Oct 27, 2007 | Pentax Optio S50 Digital Camera
Pentax Optio 555 - Fozen with the lens stuck-out
happened to me a couple times & after recharging battery, still stuck, so manually pushed it in when motor was running trying to close it.
Sep 23, 2007 | Pentax Optio 555 Digital Camera
Pentax Optio T10 turning off immediately
My optio t10 did basically the same thing...turned on, lens goes out, then automatically shut off. I took the advice of a solution listed here for another problem...hit the camera. For whatever reason it worked.
Apr 08, 2007 | Pentax Optio T10 Digital Camera
Pentax Optio 50 Digital Camera Logo
Top Pentax Cameras Experts
Muntejaya Ginting
Muntejaya Ginting
halotheracer
halotheracer
Lee Hodgson
Lee Hodgson
Are you a Pentax Camera Expert? Answer questions, earn points and help others
