Question about Microsoft LifeCam VX-3000 Web Camera
Video becomes blurry when object is moved using
Picture and video is clear for still shots but when the person moves in front of the camera, the video is blurry as if it's not tracking right
Posted by melque77 on
Angus Broadwell
  • 150 Answers
Most web cameras are that way. cams are rated on there refresh rate. Higher the rate the better the picture and higher the price.
Posted on Aug 30, 2009
Pictures come out blurry if any movement
The most likely culprit is a slow shutter speed. If the subject moves while the picture is being taken, you'll see it blur. If non-moving objects show up sharp while the moving objects are blurred, then this is definitely it.
Another possibility is camera movement. Try putting the camera on a tripod or a table or other steady support, then use the self-timer to take a picture. If everything in the picture is blurry, then this is probably the reason.
The third possibility is that the camera isn't focused on the subject. Try taking a picture of the subject when it isn't moving and see what happens.
Mar 16, 2013 | Olympus Sz-12 14mp Wide-angle With 24x...
Some of my pictures are blurry using a cannon rebel 3. how can i fix this problem?
There are several possible causes for blurry pictures.
1) Camera motion. If everything is blurry, it's most likely because the camera moved while the picture was being taken. Make sure your shutter speed is fast enough if you're handholding the camera (longer lenses require faster shutter speed). Alternatively, put your camera on a stable surface, such as a tripod or a tabletop.
2) Subject motion. If the subject is blurry but the background is sharper, then the subject may have moved while the picture was being taken. Use a faster shutter speed. Raise the ISO if needed. There are limits, of course. If you're trying to photograph a fast-moving object in the dark, you probably won't be able to.
3) Improper focus. If the subject is blurry but something else in the picture is sharp, then the camera probably focused on the wrong object. Move the focus selector to the subject you want in focus. Alternatively, center the viewfinder on the subject, press the shutter button halfway to lock focus, then reframe and shoot.
Without any more specific information as to what and how your pictures are blurry, I'm afraid the above is all I can give you.
Jan 13, 2012 | Canon Cameras
I like to get up close pics of objects especially plants and scenery. The problem is when I zoom in the picture is always blurry and cannot focus on objects that are not far away. Is there anyway setting...
most cameras come with an option called macro,this setting is for close up shots.on your camera it needs to set at wide angle.when choosing the shooting mode move left or right and choose the icon of a flower.if you adjust the zoom, a zoom bar will appear at the top of the lcd.if you try to use a zoom not intended for macro shots the flower icon will gray out and the bar will appear yellow,if you take a picture with the yellow bar it will be blurry.if you zoom out a little until it stops you should be ok. if you use a flash in macro mode the images edges usually will darken.hope this helps.
Jan 08, 2011 | Canon PowerShot SX100 IS Digital Camera
Sony Cyber-shot takes lots of blurry pictures in
first thing you can do is to try reverting cam back to factory settings.to do that initialize the camera.it's under menu>setup settings>main settings1>initialize. after initializing,set cam to auto adjustment mode (green camera icon in mode dial). what to avoid when taking pictures:
1.subject too close (use macro if needed)
2.insufficient light
3.subject movement
4.camera movement (that's caused by you)
5.incorrect camera setting
5.incorrect camera operation
btw, before you take a picture,press the shutter button halfway down first to give the cam ample time to focus.you'll see a flashing green indicator on the screen that means cam is focusing.when the indicator stops blinking cam is ready for the shot.press shutter button all the way.review your picture.if still blurry, you may try changing iso (for dark or fast moving subject, note:the greater value the noisier the picture gets), metering mode and focus settings by going to the shooting menu (press menu when your in P or program mode). hope this helps.tnx:)
Apr 16, 2010 | Sony Cyber-shot DSC-S980 Digital Camera
Sony cyber-shot dsc-w200 taking blurry pictures in auto mode...
Its due to slow shutter speed setting.
If you want to take moving object picture, set high speed shutter, there would an icon of golf stick that is for moving object pictures.
Mar 23, 2009 | Sony Cyber-shot DSC-W100 Digital Camera
SONYA CYBERSHOT DSC-S600
sounds like someone has changed the shutter speed. Look in owners manual on how to change back to default. might also look at the picture type settings but setting the camera for action shots u will get better images if there is movement in the image.
Dec 27, 2007 | Sony Cyber-shot DSC-S600 Digital Camera
WHEN TAKING PICTURES OF MOVING OBJECTS THE IMAGES ARE VERY BLURRY, ALSO SOMETIMES WHEN WE TAKE A PICTURE THE WHOLE PIC IS BLACK ANY HELP?
WHEN TAKING MOVING PICTURES YOU SHOULD BE ON THE RIGHT SCENE MODE. AS FOR BLANK PICTURES WE HAVE FOUND THAT GENERIC SD CARDS CAN CAUSE THIS.
Nov 23, 2007 | Panasonic Lumix DMC-FZ50K Digital Camera
Picture Blurry on the Sony DSC-T1
Put it on a tripod, and don't move it until the picture is captured. At the very least, hold it steady for several seconds after you press the shutter button. You are probably moving it while the shutter is still open recording the image. Digitals do this in low light situations. I frequently get caught by this because I think 'Click. I'm done. Move on.'
Sep 08, 2005 | Sony Cyber-Shot DSC-T1 Digital Camera
Microsoft LifeCam VX-3000 Web Camera Logo
80 people viewed this question
Top Microsoft Computers & Internet Experts
Lee Hodgson
Lee Hodgson
efs_perpends
efs_perpends
ThaMp3Doctor
ThaMp3Doctor
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
