Question about 10 10 Computer Primax CompactSwitch
Make I-cons smaller and erase previous sites - 10 10 Computer Primax CompactSwitch
Posted by edward_suche on
Anonymous
  • 53 Answers
For making icons small
Right click on desktop>>properties>>setting>
now here set your screen resulation
for eraseing previous sites
open EnternetExplorer>>tool>>history or Delete Browser history>>from here you can delete sites history
Posted on Sep 07, 2009
Samsung LE40D550K showing horizontal glitches
If you wish to get more details visit the site linked here. Display d
faults of many popular brand tv sets are given in detail with illustrations. http://electronicshelponline.blogspot.com/
Jan 26, 2017 | Samsung Televison & Video
I have vertical lines showing up , I opened up the tv and I wiggled the connection ribben between the t-con and main board and the lines seems to be better but not 100% fixed what you suggest me to do?
Try one more thing, remove all the connections to t-con board the and clean the terminal of the wire. you can use an eraser for that. with the eraser rub the contacts on the end of the wires. do not use eraser on the sockets which is on the boards.you have clean only the wire. after cleaning connect it back and check. if then also the is lines there is line then you need a new t con board. There is also a chance of panel fault but it can only confirmed by replacing the t con board.
If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience
http://electro-medical.blogspot.com/
Nov 17, 2015 | Sharp Aquos LC-42D62U 42 in. LCD HDTV
Codigo 2401 bizhub 600
The erase lamp (EL) is unconnected. Did some one recently replace something in the image unit. There are two small connectors that need to be connected. when the Charge Corona Assy.is installed above the drum that assy houses the Erase lamp.
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/normanj_7893313f0751935f
Mar 19, 2014 | Konica Minolta Bizhub 600 750 Image...
Air con dead
Larger split system air con gets power from the external unit while smaller air con gets power from the internal unit. Can you find any power switch or power socket/plug around the external or internal units?
Nov 19, 2013 | Cell Phones
I have a problem with Samsung LN40B530P7NXZA. Powers on nice but 10-15 min later image starts turning white until it turns all white. You can still listen but no image. Help!
This sounds like a defective T-Con board. There is a company that is testing the T-Con board and eventually fix it. They also may offer you a replacement T-Con board if yours can't be fixed. It is a good idea to contact them directly. You can find more details at http://www.coppelltvrepair.com/p/539/repair-service-for-auo-t400hw01-v4-40to2-c02-40t02-c02-lcd-timing-controller-t-con-causing-bad-tv-picture
Sep 17, 2013 | Televison & Video
Sound o,k but no picture only back light on (52pfl5704d/f7)
Hey Your TV's T-Con board is bad. To replace the T-Con Board, watch the video provided
Sep 10, 2013 | Televison & Video
Compatible con que radios
If you wish to get more details, check this site. Pull up previous posts there. Setup code list and setup proceedings to many popular brand remote controls are given. Three digit, four digit, five digits and two-digit code list are there. Check the site with patience. Surely you'll get a solution to your problem. Search the site by 'Timeslide' option. It will make search easy. Or, type in the brand name to your device into its search box, and press "Enter"
Apr 09, 2013 | Kenwood KCA-RC50MRB Remote Control
Muy buenas. Alguien conoce los codigos para programar un TV Panasonic con un control RM-Y916 de SONY. Gracias
If you wish to get more details, check this site. Pull up previous posts there. Setup code list and setup proceedings to many popular brand remote controls are given. Three digit, four digit, five digits and two-digit code list are there. Check the site with patience. Surely you'll get a solution to your problem. Search the site by 'Timeslide' option. It will make search easy. Or, type in the brand name to your device into its search box, and press "Enter."
Mar 30, 2013 | Sony RM-Y916 Remote Control
Webcam doesnt work
Just Restore it to previous date
Clk Start>All Program>Accessories>System Tools>System Restore
Select the desired date and restore point and clk ok.......do reply if it works
Oct 02, 2009 | HP Pavilion dv6000z Notebook
Is there a way to look up previous calls?
There is only a limited numbers of previous callers
in a phone, since this is automatically erase as
programmed. The answer to your question is yes,
if and when your caller is not yet erased. You can inquire your telephone company, how many callers can your phone hold, before it is erased.
Sep 21, 2009 | Nortel T7316E 2-Line Corded Phone
Computers & Internet Logo
70 people viewed this question
Top 10 10 Computer Computers & Internet Experts
Muntejaya Ginting
Muntejaya Ginting
Marvin
Marvin
Are you a 10 10 Computer Computer and Internet Expert? Answer questions, earn points and help others
