Question about Brother HL2170W, BRTHL2170W - HL2170W Compact Network Monochrome Laser Printer
How do I Connect the Brother HL2170w Printer to WiFi?
Posted by kate Winfield on
JonSnell Electronic
    Top Expert:
  • Brother Master
  • 31,221 Answers
Pair the printer with your router and then select your printer on your computer/smart phone etc.
Posted on May 23, 2020
5 Related Answers
Anonymous
  • 3 Answers
SOURCE: Wingdings prints on Brother HL2170W
When printing using Terminal Server, the print driver needs to be installed on the server itself. If you have a printer that doesn't have the driver installed on the server, it will either not print at all or it will use the "fallback driver", which is something set by the person who administers the server. Thus, it may be trying to use an HP driver to print to a Brother printer, which won't work. Ask the administrator to install the Brother driver on the server and it should work at that point.
Posted on Apr 24, 2009
Swarnava Palit
  • 114 Answers
SOURCE: HL-2170W Laser Printer: Brother printer hl2170w drum light...
drum light ended need to be replace drum.
Posted on Jul 18, 2010
Benjamin Jr Singson
  • 1570 Answers
SOURCE: I cant figure out how to take the toner cartridge
Hi
Here is the video on how to remove or replace the toner cartridge. http://www.youtube.com/watch?v=M2yGURXXW8E&feature=related
I hope it helps you.
Posted on Jan 13, 2011
Testimonial: "Merci!"
kywriter
Joe Haas
  • 25 Answers
SOURCE: do i need to use usb lead to install wifi on labtop use brother dcp j125
On most wifi printers, you need a USB cable to set it up the first time.
Posted on Aug 19, 2012
SOURCE: My printer brother HL2170W has toner, the toner light is not flashing but whet its prints it comes blank
Has anyone stood or sat on the printer. We recently had one of these machines in our workshop with this problem and the laser unit which is on the roof above the toner drum unit was bent (bowed down) so the laser was not focused on the drum. Removing the toner drum unit, grabbing the upper part of the machine with one hand and the lower base part with the other then bending the frame apart to straighten out the metal plate the laser is screwed to fixed the problem.
http://fixitfastelectronics.com/brother-printer-repair.htm
Posted on Jan 24, 2013
How to fix brother printer won't connect to wifi?
I have brother smart wifi printer and it keep disconnecting from wifi. Its connected and ince i gave command for print it won't print. I was very frustated. One of my friend advice me to search answer on http://www.fixotip.com/brother-printer-wont-connect-wifi/
and i fixed my printer by myself.Check out great article for Why Is My Brother Printer Wont Connect To Wifi Fixotip
Jan 02, 2018 | Brother Office Equipment & Supplies
This sounds like an issue with either the toner cartridge or the drum unit. Have either of these consumables been changed recently? This should help identify the likely cause.
If the drum has been changed recently I would recommend cleaning the corona wire. If however the toner has been changed there isn't masses I can recommend in terms of trouble shooting. it may however be worth running off 15-30 pages in the hope of pulling the toner through.
Failing this I would recommend calling Brother technical support in case the issue is hardware related and not the fault of a consumable.
Oct 31, 2012 | Brother Office Equipment & Supplies
Do i need to use usb lead to install wifi on labtop use brother dcp j125
Aug 17, 2012 | Brother Office Equipment & Supplies
Brother Hl-2040 laser printer
I think, you have selected the Fix to Page option in Print Preferences. You have to change this option.
In the Print Preferences, select the "Print at Actual Size" option.
Hope after this, you will get your problem solved.
Apr 24, 2009 | Lexmark JetPrinter Color Z33 InkJet
Feb 26, 2009 | Brother HL 5250DN Laser Printer
Brother HL2170W, BRTHL2170W - HL2170W Compact Network Monochrome Laser Printer Logo
CheckitRight
CheckitRight
James Cagle
James Cagle
Norman  J Weimar Jr
Norman J Weimar Jr
