Question about Panasonic PT-47WX49 47" Rear Projection Television
I have a 1998 Panasonic PT-51G53W. We just moved and the colors are out of alignment and not just the convergence cause the tilt of the colors is off. Is there a way to adjust the tilt?
Posted by cknudstrup on
  • tsimmons4 Sep 22, 2009
    color is starting to darken what do I do?
Anonymous
    Scholar:
  • 60 Answers
Your set has a convergence problem which is a common issue.
Take a look at this solution posted earlier on Fixya. It worked for me.
http://www.fixya.com/support/t2703612-double_red_image
Posted on Aug 31, 2009
  • Anonymous Mar 12, 2010
    Just checking to see if the solution above worked!
I have a Panasonic Multimedia Projection HDTV when tv is turned on it has red & blue color spots & red verticle lines showing on the screen what could be causing this to be happening
Tv have a problems known as a convergence problems,it dead.The tv have colors lines R,G,B mis alignments,have shadows colors pictures or 3D pictures look alike?The tv convergence board have dead 2 STK convergence ICS and some or all it resistors are dead too.These parts on the convergence board,must be replaced to solved the tv pictures convergence problems.The shop,will cost u like $300-350 for parts and labors.
Nov 20, 2010 | Panasonic PT-50LC13 50" Rear Projection...
Yellow band on bottom of PT. Double image on news scroller at bottom of PT. Have tried convergence - no luck. Green will not align and will not come down.
Ur tv have any colors lines R,G,B mis alignment,have colors shadows pictures or 3D pictures.Ur tv convergence board the 2 STK convergence ICS and some or all it resistors are dead.The parts,must be replaced on the tv convergence board to solved the tv convergence picture problems.The shop,will cost u like $300-350 for parts and labors.
Oct 13, 2010 | Panasonic PT-47WX49 47" Rear Projection...
Colors are not aligned
Can't use the flash focus button or the convergence control crosses +s don't alignes red,blue,green colors.The tv have convergence problems,it dead.Must replaced 2 STK convergence ICS,and some or all it resistors to solved convergence problems.The shop will cost u $300-350 for parts and labors.
Jun 07, 2010 | Panasonic PT-53WX53 53" Rear Projection...
Panasonic PT-53WX42
convergence IC bad
http://cmpalmer.blogspot.com/2006/11/fixing-my-own-tv-part-ii.html
Jan 01, 2008 | Panasonic PT-53WX42 53" Rear Projection...
Panasonic pt-51g53w
Usually, when a Panasonic projection powers up for a few seconds and then shuts down, it is because one of the convergence IC's is shorted and drawing too much current. This is usually very easy to troubleshoot because the shorted IC causes one of the large reisitors near it to glow red hot just before the set shuts down. The set should be serviced by a qualified tech familiar with Panasonic projection sets.
Sep 02, 2007 | Panasonic PT-51G53 51" Rear Projection...
Panasonic pt-51g53w
Usually, in the Panasonic projection sets that start but then shut right back off, one of the convergence IC's has shorted out and is drawing too much current. When the TV is turned on, the computer senses the extra current and shuts the set back off. The set should be serviced by a qualified tech familiar with Pansaonic projection sets.
Aug 28, 2007 | Televison & Video
Panasonic PT-47wx49 47in
One of the resistors in the circuit connected to one of the ic's has burned out or changed value due to heat caused by short in previous ic before it was changed.
Mar 06, 2007 | Panasonic PT-47WX49 47" Rear Projection...
Can't converge the whole screen at once
A surround sound receiver wouldn't cause issues itself but the possibility that speakers could cause issues is there. Speakers usually are an issue with direct view CRT televicions more than CRT projections. Don't move any physical adjustments on the CRT's unless you understand what each magnet is accomplishing on it. It is a electrical alignment and most likely one that has to be done in the technicians convergence alignment settings not the consumers.
Feb 22, 2007 | Panasonic PT-47X54 47" Rear Projection...
Color guns out of alignment
It sounds to me like the convergence amps themselves have failed. Ic7001 and Ic7002, both are STK392-110 Sanyo built Ic's and not an expensive job for a qualified shop. When shopping around for a shop to repair it ask what they charge for replacement of the convergence amps in this unit. And take the unit to them to save pickup and delivery charges...
Have a great day!
Bill
Dec 21, 2006 | Panasonic PT-53WX53 53" Rear Projection...
Panasonic PT-47WX49 47" Rear Projection Television Logo
Top Panasonic Televison & Video Experts
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
